Question about Homelite Mighty Lite Lawn Trimmer
Cant get the spool off homelite trimmer
I got a homelite trimmer zipstart from the pawn shope.2002 i think,runs good but i cant the @#&*spool off,its bump feed.HELP
  • 4 Answers
Unscrew the bump-knob and the rest pulls off. If it won't unscrew you could always cut it off and buy a new one from ALM Manufacturing 01423 797208
Posted on Jun 01, 2009
Starter cord will not recoil
Sounds like either something is caught in the spool or the recoil spring is broken or the rewind spool is broken. You have to disassemble the unit to see. Do that and I think you will find the problem. When you do find it and need more help, please ask. Good luck...Lee
Jun 11, 2010 | Homelite Mighty Lite Lawn Trimmer
Homelite will not start
the carb is probably plugged or gummed up or the diphrams are hard and not flexing to pump fuel.
Apr 30, 2010 | Garden
How do you refill the string on the homelite electric, straigh shaft, 13 in Trimmer?
Is the sting the cutting line at the bottom of the trimmer? If it is pull the spool out. At the bottom of the spool there is an arrow pointing in the direction that the line should be wound. When you first put in the line be sure to place the cutting line in the grove (V shape) and then when you put enough line around the spool. Thread the end of the line thru the hole on the side of the spool. Slide the spool over the shaft of the trimmer and it will click in. When the line is short just tap the spool lightly on the grass and it will feed out more line.
Good Luck.
Jan 06, 2010 | Homelite Garden
Was given a homelite zipstart versatool string trimmer (25cc). what is the proper gas to oil ratio for this tool?
between 32:1 and 50:1 should be OK.
The best bet is to buy the premeasured 2 cycle fuel/oil mix in the bottles. They come with 8oz for a gallon of fuel.
Sep 23, 2009 | Garden
How do you take the spool off the Homelite gas grass trimmer?
Push in on the spool & turn counter clockwise. This works for most trimmers. Careful though, the center spring may pop off with the spool. (I wouldn't do it on a hill)
Aug 12, 2009 | Homelite Mighty Lite Lawn Trimmer
Removing spool from homelite 13 inch electric trimmer
The entire cap does not come off. You push the buttons in on each side and only the very top of the cap comes off.
Jul 05, 2009 | Homelite Consumer Products 4.0 Amp, 13 In....
Homelite st-175g trimmer
This is for a duel line trimmer. I hope this will help.
Cut two separate pieces of string, about 7 ft. each.
Stick the end of the line in the hole on the inside of spool.
Wind clockwise onto spool, putting the line that is closest to the ground on first.
Once you have winded this piece on, lock the last 4 inches of line through the slits on spool.
Repeat process for second piece of line, locking the last 4 inches in slot opposite the other locked in piece.
Put the spool on the trimmer, feeding the end of lines through either hole on trimmer.
Before you push the spool all the way on, pull the strings out of the locked position. Put cap on and GO CRAZY!
Jim
Jun 17, 2009 | Homelite Mighty Lite Lawn Trimmer
Cant get the spool off to change the line
check for 2 or 1 push tabs on the side of the spool that might onlock it so it can be turned too replace string
May 10, 2009 | Garden
Homelite Mighty Lite Lawn Trimmer  Logo
474 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
