Question about Dell Latitude C610 Notebook
Hard drive issues
My dell c610 wont recognize my upgraded hitachi travel star hard drive the old was corrupt and the new one i have put in is not recognized by bios and i cannot load xp to format? Any suggestions
  • meteshadow May 11, 2010
    it is not in BIOS ? i mean not seen by bios ?
    Problem Solver:
  • 9 Answers
Make sure your dell c610 is compatible with HD... some older dell laptops can only read 40GB max
Posted on Jun 01, 2009
    Scholar:
  • 34 Answers
I'm assuming this is an internal drive since you are mentioning it not appearing in the bios. If the hard drive is not recognized by the bios check to make sure that the power and IDE or SATA drives are plugged in all the way. If there power, you will hear the unit spin up when you start the machine. If you do not hear the drive spin when the machine starts, make sure the power (for pin) plug is plugged in all the way and attached to the power supply.
If the drive does spin up, then verify the IDE cable (flat ribbon cable with long rectangular connectors at both ends) is plugged in all the way and that it is oriented in the correct direction. There is normally a key at the top (square pin) so that the cable only goes one way. If there is no "key," look at the drive. One end should be labled with pin "1". One side of your cable should have a line that is different than the rest of the cable (normally red). This corresponds to pin "1."
Make sure that the IDE cable is completely plugged in at both the drive and the mother board.
If this is a SATA drive, then you should verify that the SATA cable is attached firmly to the hard drive and the mother board. My guess is that your drive is an IDE drive.
Hope this helps - flub
I had the same problem. Here is what you need to do:
open your Bios, under configurations disable the SATA native support. Exit Bios. Insert your recovery cd and reboot the computer. Your recovery cd will start normally, keep in mind you might have to format the hardrive, don't worry the recovery cd will indicate if its necessary or not. Good Luck!
Posted on Jul 31, 2009
  • 374 Answers
Have u checked the jumper settings...make sure that it is set to Master.
I have a dell c610 laptop, and want to put in a 3d graphics card, what do you recommend and can it be replaced?
because this is a laptop you can only upgrade a couple things, and video is not one of them. You can upgrade memory or install a bigger hard drive but that is all the options you get.
Sorry
Nov 26, 2010 | Dell Latitude C610 16MB ATI Mobility Video...
Dell Latitude C610 doesn't recognize hard drive
when you took out the old hard drive
there is a black hard drive connector
this would have holes to push on to the new hard drive
without this, it will not plug into the motherboard
be careful if one of the pins breaks the hard drive wont work
Jul 21, 2009 | Dell Latitude C610 Notebook
I have a hitachi 4gb harddrive that is corrupted and my card readers or camera wont recognize. How can I retrieve the data on the card?
You can have the data retrieved from your hard drive by using this online company that I highly recommend:
http://www.gillware.com/
Jul 15, 2009 | Hitachi Microdrive (HMS360404D5CF00) 4 GB...
Hard drive not seen in dell latitude d600 after upgrade to vista
Your hard drive may need reseating.
If it still gives error hard disk not found then you have a faulty hard drive.
You need a new hard drive and then install Windows Vista
Mar 23, 2009 | Dell Lattitude D600 Notebook
Hard Drive Read Failure
No--I would say that the hard drive has gone bad on you.
The BIOS can see a hard drive, but it can't tell if it's any good.
If it's defective, well--you see what happens!
Mar 20, 2009 | Dell Latitude C610 Notebook
External hard drive
Yes, no problems, if the USB hard drive draws too much power you will need to attach an external power supply, usually the small laptop 21/2" drivers don't need external power supplies.
Jan 10, 2009 | Dell Latitude C610 Notebook
New hard drive latitude c610
The make does not matter - in fact Dell does not make their own hard drives.
Just be sure you get the right type, most have IDE type connectors with pins but some of the newer models are using SATA drives. Yours is an older model so it should take IDE.
Jan 08, 2009 | Dell Latitude C610 Notebook
Having problems upgrading my laptop hard drive !!!
From what I gather basically you want to copy everything off of your 40GB and put it on the new 320GB and the install correct? Why don't you do a backup (Start>All programs>System Tools>Backup to the external 500GB drive. Install the new 320GB drive and then load the operating system from your operating system disc, then restore the data from the 500GB you backed up, or am I missing something.I know it is not as convenient as cloning but sounds like you may need to do it the old fashion way..there is no good reason that the cloning software would quit reading your disc unless it's some kind of "only get one chance and throw away software".
Dec 27, 2008 | Dell Inspiron E1505 Notebook
Dell 2400 wont recognize harddrive
I don't know how old the Dell is but I have not seen a BIOS setup routine that did not automatically find and recognize a new hard drive for many years. Perhaps the BIOS is the source of the problem.  Did you try the removed drive in another system? Did you check the CMOS backup battery? If this needs to be replaced, it may not recognize much of anything.
Dec 22, 2008 | Dell Dimension 2400 PC Desktop
HDD prob
The machine should recognize that there is a hard drive there, if it doesn't then the hard drive has crashed or failed. You will have to replace it.
Jun 24, 2008 | Dell Latitude C610 Notebook
Dell Latitude C610 Notebook Logo
143 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
