Question about NexxTech USB External Floppy Drive (NEFD2) Floppy Drive
Light will not come on when floppy is inserted
This is a DOS program and it seems like I don't have power to drive
    Problem Solver:
  • 16 Answers
Being a dos was not designed with USB in mind i would bet that is your problem. I doesn't recognize that it is there and therefore doesn't turn on the port.
Posted on Jun 01, 2009
How to Create a Startup Floppy Disk?
Insert a floppy disk into your computer's floppy drive. Open My
Computer, and then click the floppy disk drive to select it. On the
File menu, point to the name of the floppy drive, and then click
Format. Under Format options, click Create an MS-DOS startup
disk .
Oct 19, 2016 | Computers & Internet
Fix error 301
Do you know how to access your computer's BIOS settings? It sounds to me like an advanced setting called "Hard Disk Boot Sequence" (or just "Book Sequence") may be mis-set. Normally,the setting would be HD first, then CD, then etc-etc-etc down to usually last of all, Floppy Drive. It sounds very much to me like yours is set to boot the floppy drive ahead of the HD.
When your computer is starting up, watch carefully for writing on the screen (usually top-left or along the bottom) that says "Enter Setup" - and press the key it says. I don't have my Thinkpad any more, and there were numerous contributors when I searched this for you, but most said "Hold down F1" while powering on and keep it down until a long beep" - Others said that if you can get to a DOS prompt do so and press CTRL-ALT-F11.
THE MAIN THING HERE IS THIS: BE CAREFUL IN SETUP. This is one place where you can cause yourself a lot of grief.. If you don't find the boot sequence screen (or if you do, and it's OK) write back with more information. BEST OF LUCK! We're here to help.
Jan 29, 2016 | IBM ThinkPad 380ED
Install windows 95 from floppy
Microsoft Windows 95 employs the use of a bootable floppy disk to begin the installation of the Windows 95 operating system or to troubleshoot problems with the system. Microsoft Windows 95 uses the MS-DOS system to boot the computer first and then loads the Windows 95 operating system onto the machine. Windows 95 Boot Disks may be created in one of two ways: The Startup disk may be created from within Windows or a boot disk may be created from a free downloaded boot disk image. After the boot disk is created the disk may be used to boot the computer and install or troubleshoot Windows 95.
Click "Start" and then click "Settings" in Windows 95. Click the "Control Panel" option. Click "Add and Remove Programs." Click "Startup Disk" and then click "Create." Insert the blank floppy disk into the disk drive. Click "OK." The operating system will create the Windows 95 boot disk. Click "OK" when the disk is finished. Create the Windows 95 Boot Disk using Downloaded Boot Disk Image Open a Web browser and navigate to the boot disk image site (See "Below"). http://www.bootdisk.com/bootdisk.htm Download the Windows 95 boot disk image and save the .EXE file to the desktop. Click the .EXE file to unzip the enclosed files. The formatting application will start. Insert the blank floppy disk into the disk drive and click "OK." The Windows 95 boot image will be created on the blank floppy disk. Use the Windows 95 Boot Disk Insert the Windows 95 boot up disk into the computer's floppy disk drive. Power the computer down by clicking "Start" and then clicking "Shutdown." Power on the computer with the Windows 95 boot disk in the floppy disk drive. The computer will boot up into MS-DOS to enable installation or troubleshooting of Windows 95.
Feb 13, 2013 | Dell OptiPlex GX270 PC Desktop
Floppy drive light on all the time
The floppy drive light permanently on can be caused by inserting the 4 pin power cable upside down.
Please check that the power cable is correctly inserted. There should be a raised part on the power plug that fits into a slot on the floppy drive power socket.
Hope this helps, please rate my answer :)
Thanks,
Chris
Mar 02, 2011 | MSI MS-6547 Motherboard
Panasonic JU- 257A686
The operating system you are using is pretty old....DOS uses commands that are typed without graphic user interface. It is probable that the drive is dysfuntional because of age/fatigue. You need to use newer technology. You can insert the same disc in a drive that is in a windows environment e.g Winows 95, 98 or XP. This disc will definitely be more expensive than your old dos-run drive, but am sure you will have a lot less stress. better still when you get this copy all your information on the system and use a better newer storage device like a flash drive, CD/DVD.....they are much better in terms of capacity and functionality.
Best
Sep 01, 2009 | Panasonic JU 257 (JU257A827P) Internal...
Floppy drive spins then gets stuck
This sound like fun. To get to the bios the common practice is to hold down the [Delete] key as soon as you turn it on. If it constantly boots to doss, that is likely the operating system. To explore what else is there, at the dos prompt, type in "dir" and press [Enter]. You should get a list of folders and files. If the dos prompt is A:> then you may have only a floppy drive. To check for a hard drive, type "C:" at the dos prompt. If it says not available, then you have only floppy. If the dos prompt changes to 'C:>" the you have a hard drive.
As far as dismantleing it is concerned, remove any screws in the bottom. Press you finger against any labes on the bottom and feel aroud for hidden screws. The plastic case also snaps together. Tying to unsnap it usually snaps pieces off. That is as far as i can help you right now. Need nore, ask away but supply enough info so I can image it in MY mind.
May 31, 2009 | Apple Laptop Floppy Drive (661-1651)...
Need a BOOT diskette
I am not sure if this will work. But worth a try.
http://www.allbootdisks.com/downloads/Disks/Windows_98_Boot_Disk_Download49/Automatic%20Boot%20Disk/Windows98.exe
download the link and create a boot disk (floppy)
Insert a blank floppy and run the exe file to create it.
You need to create this some computer having floppy drive.
Insert this disk into your laptop and boot using this disk.
You should be able to boot in dos prompt.
now, you could browse through the harddisk contents by accessing C: or D: or etc ....
I assume you know basic DOS commands :)
lemme know if it works .
Aug 06, 2008 | Computers & Internet
Im trying to install win xp on a used computer
Are you useing the windows xp cd?
Enter the xp setup when asked "press any key to start from cd.." (press a key here so you get into the blue windows installer)
And follow the steps, do you get problems there?
Jun 05, 2008 | E-Machines eMachines Desktop PC
NexxTech USB External Floppy Drive (NEFD2) Floppy Drive Logo
89 people viewed this question
Top NexxTech Computers & Internet Experts
Joe Goldman
Joe Goldman
Prashant M
Prashant M
Shehu Pro
Shehu Pro
Are you a NexxTech Computer and Internet Expert? Answer questions, earn points and help others
