Question about Texas Instruments TI-83 Plus Calculator
How do you put the fourth root into scientific calculator
I'm trying to figure out how to enter the fourth root into calculator. Thanks.
Do whatever the number is then ^(1/4)
Posted on Jun 02, 2009
How do I find the 4th square root of 16 on a datexx ds-700 scientific calculator??
Roots are called as follows:
square root
cube /cubic root
From 4th on, use the ordinal fifth, sixth, ... n-th
To calculate the fourth root you have two possibilities.
  1. Some calculators have the x-root key marked with an x followed by the radical symbol. See the screen capture on how to find your result.
    Usually the x-root is the SHIFTED function of the general power key that is marked ( [^], [X^y], or [Y^x] ). To use it, you inter the index of the root (the ordinal number). then you press the [SHIFT/2nd/ 2nd] [X^y] sequence and the number whose root you are calculating).
  2. Alternatively: Use the equivalence n-th Root (x)=x^(1/n), meaning that to extract the fourth root of 16, you raise 16 to the power of (1/4)
Sep 19, 2014 | DateXX DS-700 - 2 line LCD Display 224...
How do I enter radicals with variables to solve?
Put the calculator in the COMP mode. Use the ALPHA key to enter the X symbol in the square roots: ALPHA [)] to type X. Use the ALPHA key to type in the = sign (ALPHA CALC). Compose your expression
Sqr(50*X)-Sqr(8*X)=1
While the equation is still on the command line, press SHIFT CALC to (SOLVE).
You will see Solve for X.
Press the = sign at the bottom right. Wait for the solution to appear.
Jan 31, 2012 | Casio FX-115ES Scientific Calculator
How do I find the square root of a number? and how do I enter scientific equations?
For square roots, use the square root key just to the left of the divide key. For example, 4 square-root = will give you 2.
The calculator doesn't have any way to store equations, scientific or otherwise. If you mean scientific notation, use the EE key just above the 7 key to enter exponents. For example, to enter 1.23x10^6, press 1 . 2 3 EE 6. For negative exponents, make sure to use the +- key to the right of the decimal point instead of the - key.
Sep 22, 2010 | Texas Instruments TI-30XA Calculator
Cube root of a number
push 3
then push 2nd
then push the carot symbol ^ some calculators have this as y^x
then enter your number
If that fails use the calculator program in your computer and change its view to scientific. This has cube roots
Mar 25, 2010 | Texas Instruments TI-30 XIIS Calculator
How do you take the 3( square root) of 64 or the 4 root of any other number? im trying to take the 2nd button but still having trouble ? can u please help?
Hi shiny_diamon
Here is a picture of the powers and root functions of your calculator.
1.To calculate the cubic root of a number you use the key combination shown on line 5
Ex: Cubic root of 27
27 [2nd] [3 root x] [EXE]; Should get 3
2. You can use the general root key on line 7 [2nd][x Root y]
Ex: Cubic root of 125
125 [2nd][ x Root y] 3 [EXE] Should get 5
(-125) [2nd][x Root y] 3 [EXE]; Should get -5
3. You can also yse the general power key on line 6: [Y to x], but the degree of the root is entered as a fraction 1/3
Ex: cubic root of -125.
(-125) [Y to x]( 1/3) [EXE]; You should get -5
4. The [Y to x[ key is the one you use to obtain all other roots fourth, fift, tenth, n-th.
Ex: Fourth root of 256
256 [Y to x] (1/4) [EXE]: You should get 4
Hope that helps.
Nov 08, 2009 | Texas Instruments TI-30XA Calculator
How to set roots
On the calculator enter the root/index first, then hit the MATH key then number 5, then enter your radicand.
Mar 19, 2009 | Texas Instruments TI-84 Plus Calculator
How to use the square root button on TI-30XIIS
First press [2nd] button then [root button] then the number you want then [ ) ] close and enter.
For more about your calculator:
http://education.ti.com/downloads/guidebooks/scientific/30xii/30xiiqrg-eng.pdf
Rate me please, thanks.
Jan 16, 2009 | Texas Instruments TI-30 XIIS Calculator
To work out the cube root of a number
I am guessing, but, find the key that has a 3 to the left of the root symbol, looks like a check mark. Push it, then the number you want to take a cube root of, then enter.
Jan 08, 2009 | Casio FX-115ES Scientific Calculator
Inputing Scientific Numbers
If you mean using the "EE" key it's straightforward.
To enter scientific numbers, enter the number, then press EE, then the exponent value. The TI-30XA will stay in scientific display until you "clear" or turn it off. It will also switch to scientific notation if you multiply big numbers that exceed the display.
E.g. Input 3, EE, 10, X, 3, EE, 10, =, gives you the answer 9 times 10 to the power 20. Press the "square root" key and you will get back 3 times 10 to the power 10.
You can mix entries too, e.g. 3, EE, 10, X, 2, =, gives you 6 times 10 the power 10....
Nov 29, 2008 | Texas Instruments TI-30XA Calculator
Half-life exponential problem. Can't get the same answer as example
Here is how you enter it.
[+/-]0.693/8x4[2ndF][e^x][=] result is 0.7071588193 or as you wrote 0.7071
some calculators show an error message if you enter the [+/-] (the negative of a number before the number itself).
In that case enter 0.693 then press [+/-]. the calculator should put a small - sign before the 0.
You can try
0.693[+/-][x]4[/]8[2ndF][e^x][=]
Hope it clarifies things.
Sep 16, 2008 | Sharp EL-531VB Calculator
Texas Instruments TI-83 Plus Calculator Logo
2,720 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
