Question about HP Computers & Internet
Nedd to reset power on password, and I don't know the old one.
I took out the CMOS battery and it still won't reset....What do I do????
    President:
  • 948 Answers
You also need to move the CMOS jumper from its current position covering two pins to the other possible position, covering the currently open pin and the center pin. Leave it for a few seconds, then move it back and reboot.
Posted on Jun 01, 2009
Please can you tell me how to reset the cmos on a samsung R510 Laptop
Hello you just have to remove the cmos battery:
Press the release pad and the battery will pop out
DO NOT have any power on disconnect all power and usb cables
when you do that.
Wait for 10 min. or so with the battery out
and the bios will reset back to factory settings.
Replace the battery and boot up your machine and enter the bios
you kave to configure the boot order.
Here is some youtube videos how you do that:
http://www.youtube.com/results?search_query=Intel+D945GTP+bios+setting&oq=Intel+D945GTP+bios+setting&gs_l=youtube.12...55167.59517.0.61846.6.6.0.0.0.0.85.411.6.6.0...0.0...1ac.1j2.lSt1MwgqUkQ
But it depends what bios you have.
Good luck
Dec 04, 2011 | Intel D945GTP Motherboard
Toshiba satelite bios password recovery
On laptops there isn't an easy way to recover passwords in the BIOS. Sometimes you can reset the password. Other times, you'll have to contact the manufacturer to get it reset.
Some laptops will allow you to reset the BIOS password by pulling the CMOS battery. The CMOS battery is typically located under one of the bottom panels for access to the memory or wireless cards. Some models have the CMOS battery connected by a small wire with a clip connector, others have the CMOS battery placed directly on the motherboard with a metal retainer clip.
Here is a link to a removable CMOS battery with wires: http://www.laptopparts101.com/wp-content/uploads/2008/12/removable-cmos-battery-560x420.jpg
Here is a link to a CMOS battery that is directly on the motherboard: http://www.laptopparts101.com/wp-content/uploads/2008/12/coin-cmos-battery-560x420.jpg
On a laptop, if you unplug the power cord, remove the laptop main battery and then remove the CMOS battery - and then wait at least 5 minutes, some models will blank out the BIOS password. Not every BIOS password can be erased by removing the CMOS battery - but if you are comfortable working on the laptop parts it is worth a try.
If removing the CMOS battery doesn't fix the BIOS password, the only option left is to contact the manufacturer for a reset. (If you took your laptop to a certified technician - they would just contact the manufacturer for the reset, and then bill the time to you!)
The number to contact Toshiba is 1-800-457-7777.
Nov 19, 2011 | Toshiba Computers & Internet
I don't know my security code
if you are referring to a password protected hard drive
When you boot up to the log in screen type in administrator as user to log in if you cant log in
during the boot up process you will see on the screen for a short amount of time press a certain key to enter set up press and hold that key during the boot up process to enter BIOS scroll down to set user password or supervisor password you can change or remove your password from there
also
The most common way that we know on how to reset or clear the BIOS password is to physically remove the power from the computer by disconnecting the power plug and then removing the Cmos battery for 30 minutes from the motherboard. Another way is to reset the clear CMOS jumper on the motherboard itself. Both of the 2 methods mentioned works because most motherboards use a battery to sustain the BIOS/CMOS settings for the motherboards PROM chip. So by cutting off cmos the battery power, the BIOS/CMOS settings will be erased.
cmos battery Under the keyboard or bottom of laptop - If you are working on a laptop computer the location of the dipswitch (almost never a jumper) can be under the keyboard or on the bottom of the laptop in a compartment such as the memory compartment. Although on some motherboards the Cmos battery is soldered in Hope this helps you
Sep 13, 2011 | Computers & Internet
I don't have a password for the set up utility screen!
BIOS password to enter set up?
if no luck with this
Hope this helps you
Sep 07, 2011 | HP Computers & Internet
also
hope this helps you
Aug 26, 2011 | Computers & Internet
I have a Lenova laptop and a intel MB I am having a problem. Trying to login but the supervisor password won't let me in no matter what i try Lenova G550 2958
also
The most common way that we know on how to reset or clear the BIOS password is to physically remove the power from the computer by disconnecting the power plug and then removing the Cmos battery for 30 minutes from the motherboard. Another way is to reset the clear CMOS jumper on the motherboard itself. Both of the 2 methods mentioned works because most motherboards use a battery to sustain the BIOS/CMOS settings for the motherboards PROM chip. So by cutting off cmos the battery power, the BIOS/CMOS settings will be erased. Hope this helps
Aug 13, 2011 | Intel Motherboard
My laptop HP ProBook 4510s prompt computer open password befor going to BIOS or OS. And i don't know what is the password? So how can i reset the password to boot the computer.
also
The most common way that we know on how to reset or clear the BIOS password is to physically remove the power from the computer by disconnecting the power plug and then removing the Cmos battery for 30 minutes from the motherboard. Another way is to reset the clear CMOS jumper on the motherboard itself. Both of the 2 methods mentioned works because most motherboards use a battery to sustain the BIOS/CMOS settings for the motherboards PROM chip. So by cutting off cmos the battery power, the BIOS/CMOS settings will be erased. Hope this helps you
Jul 25, 2011 | HEWLETT-PACKARD 574508-001 - Original HP...
Hello, My name is Vahe and I have got the following problem, I have forgot my BIOS password and I can't to turn on. Laptop model Toshiba satellite A200-13M. So I have got some solution to delete...
The most common way that most of us know on how to reset or clear the BIOS password is to physically remove the power from the computer by disconnecting the power plug and then removing the cmos battery for 30 minutes from the motherboard. Another way is to reset the clear CMOS jumper on the motherboard itself. Both of the 2 methods mentioned works because most motherboards use a battery to sustain the BIOS/CMOS settings for the motherboards PROM chip. So by cutting off cmos the battery power, the BIOS/CMOS settings will be erased. Hope this helps
Jun 02, 2011 | Toshiba (K000002020) Motherboard
Cmos password not resetting even after replacing new battery
sometimes you have to leave battery out up to 24 hours for it to reset. Make sure it is unplugged from any power too.
Apr 03, 2010 | Intel Dot Station (INTC300AIO) PC Desktop
Power-on password to reset
just remove CMOS battery and it will reset all bios settings to factory defaults
Nov 30, 2008 | Compaq Evo N610C Notebook
Computers & Internet Logo
47 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
