Question about HP Pavilion dv9000z Notebook
HP DV9000 Wireless Card Not Working
I own a new HP DV9000 Laptop Computer with a 17" monitor. I have not had any problems with it since I purchased it several months ago. Well today when I turned it on it started without any problems except one the Wireless connection never came online. I did several restarts I flipped the wireless switch several times still nothing. if I plug it directly into the DSL Modem the internet works fine but the Wireless capabilities are non existant. can anyone tell me what I can do to try and fix this issue The problem is much the same. The wireless light(ORANGE)stays on whether the switch is turned on or off. Replace the wireless card but, no change.
    Habit-Forming:
  • 75 Answers
You may need to reinstall the drivers for the wireless card or repair the connection in the control panel under network connections.
Posted on Jun 01, 2009
3 Suggested Answers
Geekman
  • 32281 Answers
SOURCE: I own a HP DV9000 my wireless quit working
Check the Device Manager to see if the Wireless LAN device is working and enabled. If not reinstall the Wireless LAN driver.
If the Wireless LAN is OK and enabled then sometimes when you bootup the Wireless LAN card doesn't get an IP address from the wireless router. This usually has a red X on the wireless connection icon and sometime you get an error message "Limited or no connection".
To get the router to issue the wireless LAN card with a new IP address, righr click on the Wireless icon and click on Repair.
You can also power down the router wait 15secs and power up the router again then reboot the computer.
If it still doesn't work you could have a faulty wireless card, see it your friendly computer shop can test it for you.
Posted on Jun 30, 2009
SOURCE: HP DV9000 Wireless Card Not Working
this is not a solution, but it isn't helpless info either like "push the button all the way".. the thing with our laptops (dv9000) it's that our chipset, nVidia, it is often too hot for the motherboard, that makes something melt in it or something and stop working, unless you can get it fixed before everything else stop working you should get that fixed PRONTO. it's around $150,00 or call tech support cause i was told that some of this problems are being fixed by HP dependig on the purchase date .. right now i'm using a wireless internet d-link pendrive. try to get that fixed cause next thing it's going to stop working it's goig to be the entire motherboard.. and we don't want that to happen.. right?
Posted on Aug 31, 2009
My computer monitor changes from red to green and then somtimes it goes completly black. but when I reset the whole system its ok for a little while
try to connect another CPU on your monitor to check if your monitor running in good condition, if the display same problem,your monitor have a problem, you need to troubleshoot or as an assistant of a technician to repair your computer....if this monitor connect to another CPU is working, check your Video card if you have if none try to purchase a new video card because in your case the problem is video card adapter...
Mar 02, 2011 | HP Vs17 17" LCD Flat Panel Monitor
My computer not booting up
i in stalled windows 7 on my dv9000 laptop, been monitoring it for about a week now, i uninstalled clear wireless card.restarted my computer, it would'nt boot back, it powered up,but cut back off, that all it does over and over.www.lilmick42@aol.com
Nov 02, 2010 | HP Pavilion dv9000z Notebook
HP Pavilion dv9700 laptop, Wireless stops working at random.
It is because your wi fi network adapter not getting ip addresses from router.
For that connect your router to computer with ethernet cable then access it with following link.
http://192.168.1.1
or
http://192.168.0.1
type user name as "admin" and password as "admin" or blank or "password"
then go to advaced and enable DHCP .
Then save and restart router.
Then go to your laptop go to my etwork places proeprty then right click on your wi fi adapter then proeprty then tcp ip and set ip get automatic.
Then it works fine.
Let me know if you need more assistanse.
Thanks.
Sep 23, 2009 | HP Pavilion dv9000z Notebook
Jun 30, 2009 | HP Pavilion dv9000z Notebook
Space bar missing on hp dv9000 laptop
hi go to this site and absolutely u will be able to change ur keyboard with new one http://www.insidemylaptop.com/remove-hard-drive-memory-wireless-card-keyboard-hp-pavilion-dv9000/
Jun 06, 2009 | HP Pavilion dv9000z Notebook
Did the wireless icon from your machine light up? If no, you need to re-install your wi-fi driver. If you have the cds with you, re-install the driver then switched on your wi-fi. If you dnt have the cds, try checking on the HP site and look for the wi-fi driver.
Jun 02, 2009 | HP Pavilion dv9000z Notebook
Laptop hinge broken
You may be able to purchase parts from :-
www.lcdparts.net
Also from
www.ccflsurplus.com
May 27, 2009 | HP Computers & Internet
Display Failure for HP dv9000 Laptop 17"
pls first check thru connecting normal pc Monitor as output from notebook see if monitor displays image if it doesnt then , do following
u should try replacing RAM if the system is not booting at all just fan is running and some light are blinking , then RAM is most likely giving problem try re fitting RAM , if u dont know how to let me know i will give u a tutorial for that . try taking out the RAM chips and then re fitting them individually i mean if u have 2 chips of suppose 512 mb each try one of them at a time
first take out both RAM chips and then re fit both and see if it works, if it doesnt then
try each one of them at a time se if u find the faulty one if it doent help then try a thrid one borrow it from someone and try but ur laptop needs to be same generation one u can ask me about the RAM model support and then try if it helps
other wise let me know
i will see more deep in the problem but i think it will resolve ur problem
pls rate me fixya if i fixed ur job
regards
zohail
Feb 28, 2009 | HP Pavilion dv9000z Notebook
DV9000Z beep codes
1 long, 2 short on the HP DV9000 is "bad video adapter". Since your video card is integrated into your motherboard, you're looking at replacing the entire board (between $200-$400 on average) + labor costs. It would be more cost effective to purchase a new laptop for $100-$200 more, with full warranty.
Hope this helps, and remember to rate those that offer free help :)
Sep 28, 2008 | HP Hewlett Packard Pavilion DV9000Z 17"...
Contact HP for Care at ((+ 1-800-585-2494 ))
Toll Free Number
Apr 22, 2008 | HP Pavilion dv9000z Notebook
HP Pavilion dv9000z Notebook Logo
562 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
