Question about Kenmore 22642 Top Load Washer
Kenmore 110.4418 washer water overflowing
What is the problem
SOURCE:
jsrock516
  • 5911 Answers
SOURCE: Kenmore Series 80 Washer - Water will not stop running
If the wash tub overfills without stopping unless the washer is stopped, this is usually caused by a defective pressure switch or loose air hose going to the pressure switch. The pressure switch is located behind the water level knob inside the console. It is common for the rubber air dome hose to come off and cause a washer to overfill. The console can be accessed the following ways:
If you have removable end caps, the will lift of by prying up from the ear of the console and pulling from the front. Sometimes inserting a screwdriver in the slot in the top of the end cap on the back of the washer and giving the screwdriver a slight twist can help to pop the end cap loose. There will be a philips screw under each end cap that will need to be loosened.
If the end caps are not removable, you will need to slide a putty knife under the front corner of the console where it meets the top of washer on each side and push in to release the retaining clip that holds it in place.
Once you have the console loose, you can flip it up over the back panel to its resting position. Use care not to damage the small plastic hinges that hold the console to the washer.
With the console in its resting position, examine the pressure switch. It will be a round plastic switch located on the left hand side (sometimes located in the center) of the console. There will be an electrical connection and a rubber hose attached to it. More common than not, the rubber hose comes off. If this is the case, reattach the hose to the small nipple on the switch. Use care not to break the nipple. You can take a small zip tie and place it over the hose where it is attached to the nipple and secure it snugly to help keep the hose in place. Do NOT over tighten as you can damage the nipple. The zip tie creates enough resistance the keep the hose from sliding off from vibration over time.
If the pressure switch hose is still attached, double check your electrical connection. If the connector is intact, replace the switch as a last resort. If you can provide me with your model number (located under the lid along the wash tub rim) I can get a part number for you and let you know how much the switch would cost. I hope this helps you.
Posted on Dec 09, 2007
  • 62 Answers
SOURCE: Kenmore 80 series washer
not normally. Sounds like the level pressure switch is not operating.
There is a chamber on the side of your outer bowl...this has a tube attached heading off to the pressure switch.
Check tube for chaffing; check for blockage in chamber and tube assembly;
if none of the above could be the pressure switch this is thou.
Posted on Jan 04, 2008
  • 21 Answers
SOURCE: Kenmore 70 series washer
if the water was overflowing from the top of the tub it sounds like the pressure hose came loose. tilt the control panel back and you will prob see the hose that connects to the left side (where you adjust the water level) has come loose. cut about 1/4 inch off of it and re-connect it.
Posted on Dec 29, 2008
Thunder55
  • 318 Answers
SOURCE: Kenmore 80 Series top loader washer overflows
It will not be a sensor,,,it will be what is called a "Ball **** valve" and they are pretty cheap to replace.
This same valve is in your toilet tank.
Posted on Jan 19, 2009
  • 65 Answers
SOURCE: Kenmore washer overflows during rinse cycle.
SOME OF THESE MACHINES HAVE TWO PRESSURE SWITCHES IN THEM, ONE FOR THE MAIN WASH WATER LEVEL AND ONE FOR THE RINSE WATER LEVEL. CHECK FOR A PLUGGED AIR PRESSURE HOSE FIRST AND THEN CHECK THE PRESSURE SWITCHES.
Posted on Jan 27, 2009
Kenmore Washer only leaking from one area
Ive never worked on a Kenmore but it may just be the overflow outlet. All washing machines have an overflow which will dump water out from the top of the tub if it overfills but sometimes on high fill water level, clothes can splash around and cause a "wave" of water to splash out over the overflow outlet. Check to see if the leak only occurs when you have selected high level fill.
Nov 23, 2017 | Kenmore Energy Star 44092 Front Load...
Fabric Softener Dispenser Overflowing
Sounds like you have a blockage check/ clean remove dispenser to do
Apr 06, 2010 | Kenmore Oasis HE 27082 Top Load Washer
The water drains too fast and overflows
Any washer cannot drain too fast, the problem is in your drainage pipework, there is likely to be a partial blockage or restriction of some kind, it means rodding the pies, or taking it apart to clean it.
Mar 23, 2010 | Kenmore 23822 Top Load Washer
Washing machine is overflowing, even set at low water level.
sounds like your pressure tube is not functioning correctly.
Aug 22, 2009 | Kenmore 23822 Top Load Washer
Washer water wont stop running and switch to wash. It overflowed
sounds like a bad water valve. Try disconnecting for a few minutes. If problem continues, the solenoid on the water valve is staying open which means the circuit is not opening. Replace valve.
Jun 29, 2009 | Kenmore 22422 Top Load Washer
Tub overflow
Remove the hose from the water level switch and blow air through it.
The water level switch air hose has a clog in it.
Feb 22, 2009 | Kenmore 24032\24036 Top Load Washer
Jan 19, 2009 | Kenmore 22422 Top Load Washer
Dec 29, 2008 | Kenmore 22422 Top Load Washer
Kenmore washer
this could be the water level switch or the small flexible plastic tube that goes from the water level switch to the side of the tub. this tube may have worked loose if the washer is vibrating too much.
Jun 30, 2008 | Kenmore 22422 Top Load Washer
Kenmore 22642 Top Load Washer Logo
fordexpert
Kristen Denison
Kristen Denison
Level 1 Expert
Jim Chinnery
Jim Chinnery
Level 1 Expert
