Question about Gaggenau Cooktops
Gas gagennau cooktop very difficult to light
Sometimes will also not stay lit
    Brigadier General:
  • 3,614 Answers
for clarification of the problem: may i know what exactly the model that you have??
thanks
Posted on Jun 01, 2009
Will not stay lit
There is a piece that senses the pilot that can go bad. Usually a piece of copper with a bulb right in front of the pilot on one side that screws into the gas valve try replacing that
Sep 06, 2014 | Wedgwood Wedgewood RV Range 21 In. With...
The burners light, but it takes an inordinate time for them to stay lit. One of the burners will not stay lit when the knob is released, regardless of how long you depress the knob.
Need a new fsd ( looks like a small brass pencil) for the burner that won't light. The alignment of the ignition electrodes needs looking at and there over all condition I. E broken , worn , misaligned ect
Jul 13, 2011 | Bosch PGL985UC 36 in. Gas Cooktop
I have bosch pgl985uc burner problem. The center burner will not stay lit.
I have the same problem especially with the center burner, but now am having increasing difficulty with two other burners. Those will eventually stay lit if I depress the knob for 20 - 30 seconds. The center burner will not stay lit, even when keeping the knob depressed for 2 - 3 minutes!
Mar 19, 2011 | Bosch PGL985UC 36 in. Gas Cooktop
Gas cooktop igniting and lighting but when you stop the igniting the gas does not stay lit
It seems like one of your burners is clogged. You made need to use some oen cleaner and a small toothbrush to clean the burner. If the problem occurs with all the burners, then you have a blockage in the gas supply line. you willm have to take it apart at the stove and clear it out. Check the main gas connection and at the burner(s) to spot the debris clogging. Make sure to shut your gas valve off behind the stove. Good luck... hope this helps.
Feb 14, 2010 | Fisher and Paykel GC36 Gas Cooktop
The oven on my gas cooker will light but wont stay lit
Thermo coupling needs changing, unless you are Gas Safe, let someone else repair for you, its a common problem, shouldn't cost much, good luck , the Yeti
May 20, 2009 | Miele 20 in. KM405 Gas Cooktop
Gas cooktops
Go for ease of cleaning. Avoid any light colors expecially the grates. White cooktop, light grey grates, AWFUL I replaced it within 6 months. Stainless or black is fine, very easy to clean. Make sure the drip area can contain a spill . Another importent thing, If you can see it connected, turn the flame down as much as possible and see if it stays lit. Pusling and relighting is a plus some higher end units do this. It is very hard to get a true low flame on a high BTU unit. Another big plus. See if the grates are arranged so you can slide a pan over without lifting. This seems a minor point but what a luxury.
Jun 12, 2008 | WindCrest 35 in. CTG365D Stainless Steel...
Burnes extinguish once lit.
These have flame failure technology so the gas will cut out if there is no flame. The thermocouples do this by keeping the gas valve open once they have heated up. This should only take 5-10secs though so any longer is probably an issue with the thermocouple
Apr 16, 2008 | Fisher and Paykel GC913 - Stainless Steel...
Rv cooktop range 22 series
hi,
it sounds like the oven safety valve is bad, it will reach a point when the pilot will make enough energy to keep itself lit, but not enough to open the gas valve to light. it will need to be replaced. if you are handy you can do this, but make sure you shut off the gas to the range first. you should be able to find a replacement online, if not check with a local LP gas company that sells parts to the public.
Feb 25, 2008 | Cooktops
Burners will not light or stay lit
lhs burner - problem is probably thermo-couple. this is a safety device which prevents gas escape if flame blows out. rhs burner - you do not say if it can be lit by a match. if so then it is a problem with the electrode or the wire to it chaffed thro. if can't be lit by a match, then a problem with the gas valve which is unusual not a diy fix unless you are experienced
Apr 11, 2007 | Miele 30 in. KM320G Gas Cooktop
Cooktops Logo
35 people viewed this question
Top Gaggenau Cooktops Experts
Paul Carew
Are you a Gaggenau Cooktop Expert? Answer questions, earn points and help others
