Question about Pioneer VSX-D509S Receiver
Screeching w/ sound loss
Pioneer VSX_D509S
Currently have a simple set up - iPod to receiver (via video input), then receiver to speakers/sub.
I've had this set up for years now, and just recently have the screeching noise w/ simultaneous sound loss.
I am going to say it's probably heat related now, when it happens I can use a can of compressed air (duster) to blow out the casing and it goes away for a while (I originally found this out because I thought it may have been dust inside)
This is my garage unit, so I'd like to fix it versus buying a brand new one. This was a hand me down so I don't have any manuals, I would like to know if there is a component inside that would cause this to happen.
Thanks
3 Suggested Answers
  • 256 Answers
SOURCE: Overloads all the time under 40db.
Hi Glen. The thing with these new units is that they are so fussy when it comes to frequency range on the speakers. The frequency has to be within the range that the amplifier specifies, or you'll have problems. I suggest that you check your manual to see what the required frequency shuold be and take it from there. I have one myself and love Pioneer
Posted on Aug 03, 2009
dunnbiker
  • 8546 Answers
SOURCE: pioneer receiver vsx-d510 sub not working
Rear Surrounds are not supported on this unit, they would be the 6th and 7th channels in a 7.1 rig. I think you mean Surrounds (channels 4 and 5 in a 5.1 rig).
Lets ponder: How is there any relationship between Surrounds and your separately-amplified Subwoofer? I don't see it, unless you inadvertently chose OFF for the Sub definition when you were in the Speaker selection menus adding the Surrounds. Look again.
Posted on Jan 19, 2010
I've got a vsx-920-k Pioneer receiver with s-11 Pioneer speakers and a s-21w Pioneer subwoofer. All of a sudden my sub stopped working and it seems like it's stuck in standby mode (blue light...
The manual is here...
http://www.pioneerprodj.eu/eur/products/42/99/S-21W/media.html
Flashing Blue is not defined in the manual.
Have you tried changing the Auto Standby switch to ON?
You can prove if the sub amp will respond to a known good input by TURNING ITS VOLUME DOWN tp start and just feeding it ANY RCA output from the receiver while playing, say, FM (to keep it simple). That way you would known in which direction the problem actually lies (internal or external).
Jul 05, 2011 | Pioneer VSX-C300 Receiver
Pioneer VSX-D509S 5.1- No voice audio on DVDs
try the dvd player settings to bitstream out in setting menu ok not pcm best to use coxal cable to get fiull 5.1 suround
Jan 20, 2008 | Pioneer VSX-D509S Receiver
Digital signal only works on tv output not on cd,dvd,or any other setting
TV output? Do you mean the audio coming in from the TV?
Have you looked at the manual and assigned each digital input to the appropriate device? What other devices are involved and have you tried moving it/them among the working/non working digital inputs?
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Pioneer-VSX-D509S-Receivers-manual/id/385ci970/t/2/
Apr 23, 2011 | Pioneer VSX-D509S Receiver
I can't get anything out of the speakers when I switch to 5.1
We can't make assumptions. Did you set it up in accordance with the manual(s)?
Mar 15, 2011 | Pioneer VSX-D509S Receiver
How do i conect my tv to this receiver
That would depend on the capabilities of the TV.
The VSX-D509 manual is avalailable for free at retrevo.com.
http://www.retrevo.com/s/Pioneer-VSX-D509S-Receivers-review-manual/id/385ci970/t/1-2/
The receiver only needs a simple composite monitor output using a standard RCA cable so you can use the TV to operate it through its menus.
My TV has many video inputs of the various technologies, so I connect each Hi-Def video source's video directly to the TV and run the audio from them to the appropriate inputs on the Receiver.
If you feel the need to have the TV's minimalist audio run into the receiver just run an RCA pair from its audio output to any available analog input, but the sound will be limited to analog stereo. In the TV's setup find a setting for the audio output and select whatever closely resembles a 'fixed' level so you can mute or turn its volume down without affecting the audio out to the receiver.
Jul 16, 2010 | Pioneer VSX-D509S Receiver
I have receiver VSX-D509S. Have had it for
Check for a bad ground on the input circuit board. you will need to re-solder them. Remove top cover and rear panel (many screws on rear panel) The input board can easily be accessed and resoldered. you should also check for a bad ground on the speaker jacks. If it is not repaired, sooner or later you will probably need an output IC. good luck.
Oct 16, 2009 | Pioneer VSX-D509S Receiver
Pioneer VSX-D509S keeps shutting off
Aside from any intrinsic problem with your receiver, the usual suspects are;
1) Poor receiver ventilation. 2) Very high levels of bass. 3) Shorts in the speaker wiring. 4) A rubbing loudspeaker voice coil.
Sep 20, 2009 | Pioneer VSX-D509S Receiver
No Sound on TV/SAT setting on Receiver.
Most TV has Audio Out RCA jack at rear and it gives same TV Sound as coming from its speakers.
Hook audio wire red white RCA pins at TV Out and plug these pins to TV/SAT input of receiver. Select TV/SAT input in receiver to get TV program sound coming out from TV.
Hope that info will help you.
Sep 15, 2009 | Pioneer VSX-D509S Receiver
Subwoofer
Depends on what you have it hooked up to. Check wiring and controls if it is self powered. Check receiver/amp to see if it is outputting to subw.
Apr 12, 2008 | Pioneer VSX-D608 Receiver
Pioneer VSX-D509S Receiver Logo
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
T-Comtech Repairs
T-Comtech Repairs
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
