Question about Dynex DX-LCD32-09 LCD TV
Dynex 19Inch Vga no signal
I'm connecting my Dell desktop to Dynex 19 Inch LCD TV thru the VGA port provided and when I turn ON the TV and select VGA as my source. I'm getting ''No input Signal'' on the screen.
I removed the VGA cable and gave back to my old monitor and it works fine.
On the Setup in Dynex TV, VGA is grayed out.
How can I get this fixed?
    Habit-Forming:
  • 75 Answers
You may need to set up the video card to see the TV so you can display the computer on it.Somewhere in the setting for your video card should be settings for that.
Posted on Jun 01, 2009
Can i connect my tv thru a dell optiplex745
Does your TV have a VGA port? If not it most likely has an HDMI port. Does your PC have an HDMI out on the video card? If not then you will need a VGA to HDMI adapter, OR a DVI-D to HDMI adapter, depending on if your GPU output is VGA or DVI-D. Then you will need an HDMI cable to go from the TV to the adapter.
Oct 17, 2013 | Dell OPTIPLEX 745 PC Desktop
Can I connect the LC19DV22U to my computer to use only as a monitor? And if so, how. I have misplaced the manual.
where did you hooked up the cable at the tv, what component input did you use like HDMI or VGA port? if your pc has the vga output you will use the vga port input of your tv then select in the source PC to get the signal from pc.
Oct 16, 2012 | Sharp LC19DV22U 19 in. LCD Television
Dell laptop to samsung tv using vga no signal
replace the vga port then recheck settings in your tv select pc option in the source. and then at the same time the output settings in the laptop which you are using another display.
Jul 08, 2012 | Dell Computers & Internet
I am trying to hook up a 26 inch viZio to my hip desktop utilizing the VGA cord. It won't come up? I am on the comp screen on the tv also.
Once you plug the VGA cable from the computer to the VGA port on the tv, get the remote for the TV and go to the Select Input function so that you can select PC or Computer as the input source. Then Reboot the Computer.
Once the computer reboots it will probably display on the tv. If not, Press and Hold the FN function key on the computer then hit the correct key (F1 thru F12) that toggles the display. The correct key (F1 thru F12) will have LCD/CRT on it or it might have the icon of a display.
Once it is pressed the video should toggle each time you hit it from showing on the Computer only, TV only, both the TV and Computer.
Apr 14, 2012 | HP Computers & Internet
Link ASUS laptop to Sharp Aquos LCD TV
No, a DVI to VGA adapter will not work. (The TV is looking for the digital signal from a set top box. This is different from the analog signal on the VGA cable.) You need a converter. Your best bet would be a VGA to component video converter. (I am assuming that the Sharp TV has a component video input.) This page has some examples: http://www.ramelectronics.net/audio-video/video-converters/vga-rgb-hv-to-component-video/c10000-c11200-c11215.html?sorter=productname-en-asc . Note a VGA to component video cable will not work. The VGA to component cables are for projectors that read the RGB signal. The component video signal is YPbPr.
Connect the VGA cable to the converter and the component video cable to the TV and the converter with the computer and TV off. Turn on the TV first and set it to the component video input and then turn on the computer. Then (assuming the VGA port is enabled - adjust in the BIOS if needed) set the computer's video output to the VGA port. (On my Windows 7 laptop, this can be done by right-clicking on the desktop. Choose Graphics Properties and set the display to the external monitor or both. Click Apply and then confirm the change (on the external monitor if using the single monitor). (VGA to Composite video converters also exist if you do not have an available component video input on your TV.)
If your computer is fairly new, you may have an HDMI port. Your TV may be able to read the signal with a DVI to HDMI cable. (It depends on the TV. Not all of them will read the computer's signal on the DVI port. Check the documentation for your model. TVs without a VGA port are less likely to support this feature.)
I hope this helps.
Nov 28, 2011 | Televison & Video
Dynex 19 LCD
I went over the specs of the TV.
The max input for the VGA is 1360x768 at 60Hz. Anything higher will make the TV go bonkers.
I would try to get the resolution at 1360x768, then change the frequency to 60Hz.
May 29, 2009 | Dynex 32 in. LCD Flat-Panel HDTV
Trying to get computer to display on my tv
you mean your tv doesnt recieve signals from your computer try using a monitor and a tv first at the same time then go to the graphic video to change it from monitor to lcd tv.
Apr 29, 2009 | Computers & Internet
My screen is x X y inches. The windows page doesnt fit into it. There is one inch of black space on the monitor on the left and one inch of my windows screen is lost on the right!!!!!!!
With the on-screen controls, select Auto-Adjust. This should set suitable defaults based on the incoming signal. If you are using the VGA connector and the position still needs to be adjusted, use the on-screen controls to shift the displayed image to the proper location (under Display Settings -> Horizontal Position).
Apr 17, 2009 | Dell UltraSharp 1908WFP 19inch Black...
Dynex DX-LCD32-09 LCD TV Logo
1,691 people viewed this question
Top Dynex Televison & Video Experts
Jaime Hernandez
Are you a Dynex Televison and Video Expert? Answer questions, earn points and help others
