Question about Ruud UAMB Air Conditioner
Hunter thermastat, model 44860 not working
I have a Hunter Universal Programmable for heating and cooling, model #44860, and I have a heat pump. I installed thermostat last summer and it worked, it also worked this winter. However, I can't get the air working now. The outside unit is about a year old. Thanks for your help!
  • 52 Answers
Is the compressor running? is the outside unit clean and free from debris? does this unit work in the heating mode during the winter, and is it still capable of that now.
Posted on Jun 02, 2009
Air handler fan runs continuosly. Will not shut off.
There should be fan options "automatic" which will turn on with heat or cool. , continuous, and perhaps "circulate" which is a randomized turn and off. Double-check your Thermostat programming manual. If no manual,
Try this: http://www.manualslib.com/
Mar 04, 2015 | Hunter Universal Touchscreen Thermostat...
How do I set my hunter thermostat so when the heat pump comes on, how to set so the thermostat and heat strips from the heat pump sinc with each other. The model number is 44860
call a service tech, this sounds complicated. To avoid using too much energy or burning down your life savings in heating bills, a certain sequence should be followed when the thermostat operates. The actual sequence will differ depending on what equipment you have available to control, as well as your location and heating and cooling loads. The money you could save by having it done right the first time will quickly pay for a service call, then keep on saving you money after that.
Feb 21, 2015 | Hunter 44860 H Univ. Touchscreen...
I have an old Bryant heat pump. I got a Hunter 44860 2 stage heat/2 stage cool but I am having problems with the wires. These is the Bryant set up (the wire colors do not match)...
This should help you. You need to know if your thermostat is powered by the unit or independently and which way your reversing valve switches (I,m not sure on a Bryant, but probably Your old O wire goes to your new O terminal. They should pretty much match up, the new stat just has more options. Thermostat wiring
Jun 09, 2017 | Hunter Fan Company 5/1/1 Programmable...
Auto recovery mode raises the temperature above
Hummm... how far is your Thermostat from your heater? I am reading your extensive manual but there is no mention of that distance? There was a early mention of batteries? Are yours fresh?
Is this a 'new' problem? Has it worked properly before?
Then there is this from the manual:
The installer can set SYSTEM functions once the thermostat is installed. The
default settings are shown in bold in the following list. Options are listed inside the
parentheses. Example: the default SYSTEM TYPE is CONVENTIONAL with (HEAT PUMP) as a second option. See pages 28-29 to change these settings.
Have you tried resetting your Thermostat?? Sometimes these basic 'onboard' computers get confused... especially true with lots of 'options'...
It's a little hassle to get a DIGITAL copy of your manual (I am not a Robot ~ etc) ~ but here it is:
Download manual
TROUBLESHOOTING begins at Page 68
Anthony
Dec 22, 2017 | Hunter Fan Company 5/1/1 Programmable...
White-Rodgers 1F58-58 to Hunter 44660
This is the corrcet wiring:
G - G fan relay
R - RC1, RC put a jumper RH ( to supply power to the cool and heat)
L - no wire connected (malfunction indicator) tape- off that wire
E - Emergency heat relay
B - W/B ( reversing valve in your heat pump energized during heat )
W2 - Auxilliary heat
Y - Y1 ( compressor contact)
O- Y/O ( reversing valve is energized during cool)
make sure that the system selector is on heat pump position.
Apr 30, 2009 | Hunter Fan Company 5/1/1 Programmable...
Trouble Installing Hunter Brand Thermostat
on the back of the packaging for the HUNTER MODEL 44155C it states that it is not compatible with heat pumps
Mar 01, 2009 | Honeywell Programmable Thermostat Heater
44860 thermostat won't activate in heat mode
I had the same set and problem. I had a RC wire which is the power to the AC. But didn't have an RH wire which is the power for the heat. To fix this just use the jumper wire and insert it in with the RC wire and hook it up to the RH. Fixed my problem.
Oct 20, 2008 | Hunter Fan Company 5/1/1 Programmable...
Ruud UAMB Air Conditioner Logo
713 people viewed this question
Top Ruud Heating & Cooling Experts
Bill Long
Tim Whalen
Dennis Boxerman
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
