Question about Maytag Neptune MDG5500AW Gas Dryer
No heat and can't get front off
I have a Maytag Neptune MDG4000 Gas Dryer and it has stopped heating. No gas smell. Little mechanical skills. I took out 5 screws from the back to take off the back and look in but it is solid as ever. can't figure out how to get inside at all
  • ith0 Jun 01, 2009
    I have now learned that it makes noise when the ignitor lights up but no heat occuring'
  • 149 Answers
Remove the door and the screws on opposite side pull front away and down remove corner brackets "L"s and raise top..unplug of course !
Posted on Jun 12, 2009
Maytag Neptune wont heat up what is problem
We just converted my neptune gas dryer to propane. It ignited yesterday but we could smell propane. So, my husband fixed that ,now it won't ignite and heat up
Nov 10, 2011 | Maytag Neptune MDG5500AW Gas Dryer
Our maytag dryer mgd4000aww is not heating up...any suggestions?>
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 06, 2011 | Maytag MDG4000 Dryer
Our Maytag Neptune gas dryer is exhausting a natural gas odor now... This smell only occurs when it has been running for awhile and never when it's turned off. Also, it ONLY smells outside the house via...
The burner is not lighting right...
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Dec 31, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Maytag pygt344aww gas dryer not heating and has burnt smell
heatman101
Dec 13, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Why my maytag Neptune gas dryer stopped heating up?
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Oct 10, 2010 | Maytag Neptune MDG5500AW Gas Dryer
I have a Maytag LDG 4000 gas dryer with electronic ignition. The igniter glows, but does not ignite the gas. I can not smell any gas, so I'm assuming a valve of some sort, internal to the dryer, is not...
Igniter glows - No gas ignition. If the igniter heats
up but the main burner flame is not ignited, remove
power and using an ohmmeter, check the following:
• Open secondary coil
• Open holding coil
• Open wire harness
• Stuck flame sensor (Stuck closed)
Most likely bad gas valve coils.
Sep 07, 2010 | Maytag MDG4000 Dryer
The gas was turned off for a 24 hour period neptune mdg4000
Here's a stab in the dark at your problem:
You moved your dryer to paint or re-do flooring. Handled the dryer a bit rough, so the ignitor broke. (they are fragile, especially after they have been used awhile) You may be able to confirm this by tipping the dryer from side to side or front to back a few times (easy, not violently) to see if you hear anything rattle in the bottom of the dryer. That rattle would be a part of the broken ignitor. (it still might not rattle, but the ignitor is the most likely suspect)
Jan 26, 2010 | Maytag MDG4000 Dryer
Gas will not stay lit.
sounds like a bad coil
they are on top of the gas valve
Jul 03, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Maytag Neptune MDG 5500 AWQ heats sporatically
your dryer has a safety feature that it will not run or heat when the door is opened. It is so no gas fumes are exhauseted into your home. Once the safety is engaged, It will not allow the dryer to restart for a short while. It should clear itself after only a few minutes. Hope this helps, good luck.
Apr 18, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Maytag Neptune MDG5500AW Gas Dryer Logo
192 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
