Trying to print cardstock but cannot find the setting on my HP Photosmart C4580 printer
SOURCE: Printing on heavy cardstock
HP recommends papers with ratings of at least 90 for brightness and 75 g/m2 (20 pound) weight. before u proceed....remove the rear access door to reveal the rollers.Take a slightly wet cotton cloth and wipe the rollers in the upward direction 4 times.Close the rear access door. now do as said - START -PRINTERS & FAXES -CHOOSE THE PRINTER ICON THAT HAS BEEN HIGHLIGHTED WITH A CORRECT MARK. - RIGHT CLICK - PRINTING PREFERANCES - PAPER/QUALITY TAB - CUSTOM -Create a new custom paper size that is dependable on the paper you are using - type a name & SAVE -ok -ok -try printing if the problem still insists the report back and do mention which tool you are using for the printout. if its heavy pearlized paper then i do not think th eprinter would accept it . it maintains its own standard weight to detect the paper.
SOURCE: Word Settings for Printing Postcards
I found the fix!! Once you have your size settings typed into your page layout screen and applied to the document, click print. Once you select your printer, click on properties (or printer preferences) click on the features tab (the tab next to printing shortcuts) and go to the resizing options section. click on paper size bar and scroll down to custom. once in the screen, give the shortcut a name you'll recognize, type in your dimensions in the provided spaces click save. once you go back to the features screen, scroll back down to custom and select your shortcut that you just created and apply it to both the paper type and paper size. click ok and go back and click ok to print! Hope this makes sense..if not, go to HP's website and type in your product name, type paper mismatch in the keyword search bar and click ont the first link in the found section. It will give you the same step by step instructions....
SOURCE: my HP Photosmart C4580 wireless printer will print
you gotta go into the printers folder in control panel and and right click on you printer icon and then select use printer online ,just to check if you printer has been connected wirelessly properly or not insert the cd and click on add a device and then try to install your printer in the wireless network if you printer is detected then install it and complete the installation ,it means that your printer was not installed but only configured to work on the wireless network thats why you keep getting the printer offline
SOURCE: I HAVE A HP PHOTOSMART C4580 ALL IN ONE PRINTER
please follow the onscreen instructuions from the below mentioned URL and hopefully this should fix the problem
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01442936&cc=us&lc=en&dlc=en&product=3418707
If still your problem is resolved please follow the below instruction
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01672980&cc=us&lc=en&dlc=en&product=3418707
hope this should resolved your problem if not then call
HP toll free number 1800-474-6836 they will change the printer if the warrenty period is there.
hope your issue gets resolved
thanks
regards
hamid
SOURCE: HP Photosmart C4580 Print cartridge(s) missing
This error message usually happen if the cartridge is not properly seated or the copper-colored electrical contacts have problem. Check this website for proper cleaning and installing ink cartridge.
If the problem is resolve try replacing the ink cartridges.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01442936&lc=en&dlc=en&cc=us&lang=en&product=3418707#N68
TNX
