Question about Toshiba Satellite P105-S6104 Notebook
Will not boot up
I have a toshiba p105. When I press the power button the laptop comes on to the toshiba start up screen but then the screen just turns black and windows does not boot up. I can get into to the bios but that's about all I have tried to use a recovery disc and I've even tried to use the vista install disc to run a fresh install but, when I tried to do a fresh install the partition is not available.
  • meteshadow May 11, 2010
    it is complitly shotting down? i mean no power?
  • 374 Answers
I think the problem lies in ur HardDisk.Either it is gone bad or their is loosening in the wires or might be a dust problem.Laptops r a bit complicated things,I suggest u to show it to an expert.
Posted on Jun 01, 2009
    Guru:
  • 597 Answers
So I"m assuming that you're able to boot up off a Windows disc? If that is the situation then your hard drive is bad. That is the reason it is hanging when you first start the computer is that it can't find a bootable device. When you try to install Windows and it can't find a partition is because your hard drive is bad and can't be seen. Need to buy a new one.
How do I take my pc back to factory settings
Restore Toshiba to Out of the Box Condition
If your model Toshiba laptop has a Restore partition on the hard drive then follow these steps to restore your Toshiba to the Out of the Box condition.
1. Press and hold the 0 (zero) key and at the same time, tap the power button once to switch on
your notebook.
2. When the machine Starts beeping; release the 0 key.
3. When prompted by the warning screen; select Yes to continue with the system recovery.
4. Select Recovery of Factory Default Software; click Next.
5. Select Recover to out-of-box state. 6. Click Next again.
7. Click Next to Start recovery.
8. Restart the Toshiba laptop when there restoration process finishes running. Follow the prompts that appear on the screen to set up the laptop's date, time and language settings.
Dec 31, 2012 | Toshiba Satellite P105-S6197 Laptop
My screen want come on
Please unplug the power adapter from your laptop then remove the battery, then press and hold the power button for 30 seconds, after doing that, please plug the adapter back in then press and hold the power button until your laptop will turn on. Thanks.
Sep 28, 2011 | Toshiba Satellite P105-S6197 Laptop
I shut down the laptop at once and i turned it on immediately.so only power light is on and the computer is not working.only black screen is seen.
Try this :
1. unplug the ac adapter and remove the battery .
2. press and hold power button for a minute
3. now put the battery back and plug in ac adapter
4. turn on the laptop now
it should work.
if not, try removing hard drive and memory modules then reinstall them back.
if the issue persists, your motherbord has gone bad.
Jul 11, 2011 | Toshiba Satellite P105-S6084 Notebook
Computer restarts every time screensaver comes on
try to turn off the laptop, remove the cables and battery, then press and hold the power button for 8 secs. Reinsert the cables and battery and turn on the pc. Observe if the screen saver works...
Aug 03, 2010 | Toshiba Satellite P105-S6197 Laptop
Screen will not come on.
If the Toshiba appears to boot up but the screen is black then it could be a back-light problem. For instruction to determine the fault and fix please follow my instructions - click on this link :-
http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Dec 24, 2009 | Toshiba Satellite P105-S6104 Notebook
Toshiba preparing to hibernate
Shut it down and start over. That would be the power button for 5 or 6 seconds.
Mar 17, 2009 | Toshiba Satellite P105-S6227 Notebook
I have a Toshiba satellite p105-s6147 when i press the power button the blue light comes on but nothing happens even when i have it pluged in the wall with and without the battery.
Majority of the time with the P105 it's the motherboard that is at fault.
You can try reseatting the memory modules to see if that makes a difference but other than that there's not much you can do but replace the board or send it into Toshiba for repair.
Mar 09, 2009 | Toshiba Satellite P105-S6147 Notebook
I'm getting a Black Page
try to boot in safe mode when prompted on startup when u forcibly shut down ur operating sys it will present u with a screen to select safe mode on startup just go thru safe mode and try using system restore in the Start> All programs> accessories>system tools>system restore try to restore on the earlier date when ur sys was ok see if it helps pls vote if u think i was helpful
Jan 29, 2009 | Toshiba Satellite P105-S6227 Notebook
How can i recover my laptop to factory settings?
Applicable Models: Satellite L15-S104, L15-S1041, L20-S310TD, L20-SP231, L25-S119, L25-S1194, L25-S1217, L25-S1213, L25-S1215, L25-S1216, L25-S1196, L25-S1211, L25-S1214, L25-S1212, L25-S121, L25-S1193, L25-S1192, L25-S1195, L35-SP1011, L35-S2366, L35-S2316, L35-S2206, L35-S2194, L35-S2174, L35-S2171, L35-S2161, L35-S2151, L35-S1054, P100-ST7111, P100-ST9212, P100-ST9712, P100-ST9742, P100-ST9772, P100-ST9762, P100-ST9752, P100-ST1072, P100-ST9732, P100-ST1071, P100-ST9412, P100-ST9612, P100-ST9012, P100-ST7211, P105-S921, P105-S931, P105-S9339, P105-S9337, P105-S6227, P105-S6217, P105-S6134, P105-S6124, P105-S6114, P105-S6104, P105-S6102, P105-S9722, P105-S6062, P105-S6022, P105-S6084, P105-S6064, P105-S6034, P105-S6024, P105-S6158, P105-S6148, P105-S6207, P105-S6197, P105-S6187, P105-S6177, P105-S6167, P105-S6157, P105-S6147, P105-S6074, P105-S6054, P105-S9312, P105-S6014, P105-S6002, P105-S6004, P105-S6012 << hideThe printed instructions included with the Recovery and Applications/Drivers Media disc are correct for most computer models. For some models, however -- including those listed above -- booting from the Recovery disc requires pressing the F12 key, rather than the 'C' key. The instructions below are correct for these models.
CAUTION: The Recovery process reformats the computer's hard disk drive, which completely erases its contents -- including all applications, all documents, and all other data stored on the drive. Be sure to back up your documents and other data before following the instructions below.
Follow these steps to erase the current contents of the hard disk drive and to re-install all of the software that was installed on the computer when it was manufactured:
1. With the computer on, insert the first Recovery disc into the optical drive.
2. Shut down the computer (click the Start button, click Shut Down, select Shut Down, click OK).
3. Press the computer's power button to turn the computer on, and then immediately press and hold the F12 key. Release the F12 key when the menu of boot options appears.
4. Use the arrow keys to navigate to the CD/DVD option. Press the Enter key to select it.
The computer will restart, and will boot from the Recovery disc.
5. Follow the instructions on the screen to start the Recovery process.
CAUTION: Once the Recovery process has begun, do not interrupt it.
The computer's hard drive will be formatted, erasing its contents. All of the software that was installed on the computer when it was manufactured will then be re-installed.
6. Once the Recovery process is complete, remove the Recovery disc, and press any key to restart the computer.
- mc/wa
Jan 27, 2009 | Toshiba Satellite P105-S6207 Laptop
Toshiba Satellite P105-S6104 Notebook Logo
154 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
