Question about Little Tikes Adventure Wagon
Where to find bushings for front wheels of little tike wagon?
Front wheels wobble really bad & are loose. Need someway to tighten them up. Any suggestions? Where find the parts?
    Habit-Forming:
  • 156 Answers
You can try these push nuts from this site:
http://www.shopjandl.com/0801-0226.html
I don't know what size of axles you have on your toy, but these fit my little tikes hummer wheels.
Hope this helps
Posted on Jun 01, 2009
I own a 23 Ford t bucket,i had a new front spring and shocks put on and now sometimes when I take off the front wheels start to wobble and I have to slow down for them to stop,what should I have done
first check the lug nuts on the wheels. if tight raise the car and try to turn the tires by hand. if a noise or wobble you have bad suspension parts or loose part.
Jan 19, 2015 | Ford Cars & Trucks
Front rt wheel wobbles
If it is a front wheel drive, check & see if the axle nut is tight, if not tighten to spec's, if it is you may have a defective wheel bearing or steering rod, also check the ball joints.
Apr 29, 2014 | 2000 Dodge Caravan
1996 Kawasaki ZZR 1100 front end wobble
Hi, Anonymous and the usual suspects are:
1. Improperly loaded motorcycle. Non-standard equipment on the front end such as heavy radio receivers extra lighting equipment or luggage tends to cause unstable handling.
2. Incorrect air suspension pressure.
3. Damaged tires or improper front-rear tire combination.
4. Irregular or peaked front tire tread wear.
5. Incorrect tire pressure.
6. The shock absorber is not functioning normally.
7. Loose wheel axle nuts. Torque to recommended specifications.
8. Excessive wheel hub bearing end play.
9. Improperly vehicle alignment.
10. Steering head bearings improperly adjusted.
11. Tire and wheel unbalanced.
12. Rims and tires are out-of-round or eccentric with the hub.
13. Rims and tires are out-of-true sideways.
14. Loose spokes.
15. Shock absorber improperly adjusted.
16. Worn engine stabilizer links.
17. Damaged rear engine isolation mounts.
18. Swing arm pivot shaft improperly tightened or assembled.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
How to cure ZZR1100 wheel wobble
Front End Wobble At Low Speeds KawiForums Kawasaki Motorcycle Forums
Kawasaki Ninja ZX 11 Service Manual
OEM Parts for Kawasaki
Kawasaki Ninja Owners Manuals
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Apr 17, 2014 | 1996 kawasaki ZZR 1100
Front wheel wobbles
A bent wheel, a lost wheelweight, loose lugnuts, front end misalignment or any of a dozen other serious problems. Take it to an alignment shop, NOW, before you do need a new tire.
Jan 14, 2014 | 2005 Pontiac Grand Prix
My 2002 honda shadow's front end wobbles badly when I take my hands off of the handle bars.
14. Loose spokes.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Handlebars wobble when take my hands off Anyone know why motorcycles
Wobble
Honda shadow vt1100 Owners Workshop Manual
http://www.partsfish.com/page/oem-parts-for-honda
Honda VT1100C2 Owner Manual Page 3
Oct 24, 2013 | 2002 Honda VT 1100 C Shadow Spirit
Kawasaki W800 front end wobbles
Hi, Dave and the usual suspects are:
14. Loose spokes.
Need advice on front end wobble Kawasaki Forums
Front end wobble expose
https://biker.ee/manuals/kawasaki/Kawasaki_w800_service_manual%202010-2011.pdf
Kawasaki W800 Owners Manual EN pdf
Sep 16, 2013 | kawasaki Motorcycles
Steering wheel is loose and wobbly
If the loose motion is coming from the tilt part, there are three bolts inside the column that need to be tightened up.
Someone would need to remove the steering wheel to access the bolts.
Oct 07, 2012 | 1991 Oldsmobile 88
My front left rotor is loose how do i tighten it
It would help to know a model at least. Chances are, if the wheel wobbles because the rotor is loose, unless you did something to loosen it, its may be a bad wheel bearing. To tighten that you need to replace it.
Sep 22, 2011 | Ford Explorer Sport Cars & Trucks
Front wheel wobbles on urban detour Extreme
Check that none of the wheels are loose or out of round.
Aug 11, 2009 | Maclaren Quest Sport Stroller
Front wheel
http://www.babytrend.com/contactUs.php
Contact us by mail:
BABY TREND INC.,
1607 S. Campus Ave. Ontario, CA 91761 U.S.A Contact us by phone:
Customer Service: 1-800-328-7363
Apr 24, 2008 | Baby Trend Expedition LE Jogger
Little Tikes Adventure Wagon Logo
1,034 people viewed this question
Top Little Tikes Toys Experts
Jim Goldsmith
Jim Goldsmith
Adam Fjeld
Adam Fjeld
Are you a Little Tikes Toy Expert? Answer questions, earn points and help others
