Question about GE DVLR223 Dryers
Dryer screeching noise GE - DVLR223ET1WW
When drying clothes the dryer screeches every 3 seconds
  • bolfms Jun 03, 2009
    I have removed the back panel but am unsure where the brake is located or what exactly I am looking for.
    President:
  • 1,902 Answers
Remove the back panel and check the brake to make sure that it is not staying locked to the drum.
Posted on Jun 01, 2009
  • Jeremy Reddick
    Jeremy Reddick Jun 03, 2009
    The brake is a metal piece that looks like a arm or a handle that is located on one of the sides of the drum. Different for all models. You will be able to see like black marks or scratch marks on the side of the drum
Model 69822 is less than 8 years old. Screeches loudly for about a minute on startup. Runs fine after that and dries the clothes.
The screeching is probably a slipping belt. This can be caused by"
1. Glazed or worn out belt.
2. Improper belt tension.
3. Overloaded dryer
4. Bad drum bearing
If it is used heavily (often), I would assume #1 which is the cheapest and quickest fix. You can investigate #2 at the time of replacement.
Jan 26, 2016 | Kenmore Dryers
My maytag neptune dryer mdg5500aww is making a screeching sound. It is drying the clothes but it is getting louder by the day. What part needs to be replaced?
There are 2 wheels in the rear that the drum rotates on - one could be binding. The tensioner has a wheel, check it for rotation. Belt slipping? Check motor for operation - check that plastic blower isn't rubbing in its box. Dryers are easy to disassemble - check YouTube for procedure.
Jul 24, 2014 | Maytag Neptune MDG5500AW Gas Dryer
GE DRYER MAKES A HIGH SCREECHING NOISE WHEN DRYING BUT NOT EVERY TIME AND SOMETIMES DOES NOT START TILL HALF WAY THRU DRYING OR SOMETIMES NOT AT ALL?
More than likely a bad wheel and or drum support. However there are a lot of different GE dryers so the model might help to narrow down your problem. The model number should be inside the door of the unit.
Feb 25, 2011 | GE Dryers
The MDF300AYW dryer screeches at at high pitch when clothes are drying
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Oct 14, 2010 | Maytag Dryers
Obnoxious screeching sound when the drum turns. Short consistent screech on revolution, which turns into one long non-stop screech. Stops after 45 seconds or so, then starts all over again with longer...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Sep 05, 2010 | Fisher and Paykel DEGX1 Electric Dryer
Dryer makes screeching noise..dries the clothes ..seems the tub is loose
at the top of the drum there is a felt pad with 3 white nylon glides attached to it. if this is worn, and it does wear, it will make a screeching noise like you described because it changes the postion of the drum and it will also appear like it is loose. you can purchase this part as a kit along with the glue to hold it on and it is not an expensive part. hope this helps.
Oct 14, 2009 | Frigidaire FEX831CS Top Load Stacked...
Squealing/Screeching Noises
well hi,i think it sounds like the belt,it will do it when clothes are wet,but as they dry it don,t do as bad. or dose it get worse when it runs for a while. either way it sounds like the belt.
May 30, 2009 | Dryers
Loud noise when running
Roper RGV4634KQ1 gas Dryer Starts to dry, turns 2-3 seconds, stops turning and makes loud screeching sound. Turn off to stop noise. Retry same situation.
Apr 16, 2009 | Roper RGX4634KQ Gas Dryer
Dryer makes screeching noise runs for awhile then shuts off.
The 1,5 year new dryer makes a terrible screaching noise when it has a load of clothes in it. It still dries fine, no problem with the heating element. No noise without clothes, only when it has a load.
Nov 23, 2008 | Dryers
Ge select electric dryer
it may be clogged on the inside of the machine not just the exhust tube.
Jan 10, 2008 | GE DCSR483EA Electric Dryer
GE DVLR223 Dryers Logo
320 people viewed this question
Top GE Dryers Experts
John Tripp
John Tripp
Sal DeAngelo
Are you a GE Dryer Expert? Answer questions, earn points and help others
