Sharp PHOTO COPIER MODEL No AR163
I HAVE MOVED MY COPIER FROM ONE ROOM TO ANOTHER HAVING SWITCHED IT ON IT IS NOW FLASHING U2 AND WILL NOT ALLOW ANY COPIES HOW CAN I FIX IT
  • 3 more comments
  • brianenglish Oct 25, 2007
    MANY THANKS FOR SOLVING MY PROBLEM I HAVE A FURTHER PROBLEM WITH ANOTHER COPIER I WILL POST LATER.
    BY THE WAY I AM NOT THE KILLER OF ALL COPIERS ONLY THE TWO THAT I OWN.
    KIND REGARDS
    BRIANENGLISH
  • romaric Jan 05, 2008
    WHEN I SWITCHED ON my Sharp Ar-163
    IT IS FLASHING F1 AND WILL NOT ALLOW ANY COPIES HOW CAN I FIX IT.
    Please help me
  • visioncafe Jun 02, 2008
    flashes u2
  • Anonymous Sep 09, 2008
    I have a Sharp AR163 photo copier. After i replaced the Heat Roller drive gear I tested and got a copy. Then I did the final assembly of the cover and tried again, Now it show '2' and ' H ' alternately. Pleasehelp me.
  • cnplatz Dec 03, 2008
    I own the same copier (sharp AR-163) with the same problem.
    thanks Clyde
  • 121 Answers
That is a E prom error. You will have to reset it with code 16.Go into the simulation mode.Press clear,interrupt,0,interrupt.Then press 16 and start.You will okay after that if not  opps bigger problem.
Posted on Oct 24, 2007
  • hbantawa Jul 08, 2011
    it worked thank u,
Hi all
I posted the original problem and the 1st answer corrected the problem, however it happened again later and the first fix did not work on this occasion but the toner cartridge eeprom answer did work.
But instead of changing the cartridge i took the circuit sensor off of the end of the cartridge (two small screws) and replaced it with a sensor off of an empty cartridge problem solved
RATING FOR SECOND FIX "Fixya"
best wishes all BRIANENGLISH
Posted on Feb 13, 2008
  • 26 Answers
U2 is a fault with the toner cartridge eeprom, if the reset doesn't help at a later stage replace the cartrdge
Posted on Nov 03, 2007
Error u2 ar163
EEFROM read write error.Clean motherboard
Apr 17, 2014 | Sharp AR 163 Copier
Copiadora sharp al1645cs aparecendo cod.u2
Press c photo c photo 16 press print key
Feb 10, 2010 | Sharp AL 1631 Copier
Having commercial photo copier sharp arb 320 having error code u2-11 on disply not able to print at all
Hello sir; Here is the way to reset it, the procedure as follow;
press "#", "*", "clear", "*", keys by orser,then enter 16 press start key then 00 press start again, that simple.
Oct 08, 2009 | Office Equipment & Supplies
ERROR CODE U2-40: SHARP AR 5127
ERROR CODE U2-4 COULD BE RELATED TO THE MEMORY BATTERY BEING DEAD ON TEH MAIN BOSRD IF IT IS AN OLD MACHINE SO YOU COULD CHECK THSI OR REPLACE AND TRY WITH NEW
Jun 12, 2009 | Sharp AR-5316 Advanced Digital Imager...
Sounds like a loose connector. "H" code on Sharps indicate a heater fault, if I remember correctly "2" indicates it's a thermistor.
So, if it was working before you took it apart, I'd be looking at the connectors, good luck & happy hunting....
Sep 09, 2008 | Sharp AR 163 Copier
Communication error
I assume this is a sharp??????????
U2 Backup memory problem
Aug 25, 2008 | Office Equipment & Supplies
U2 CODE FLASHING ON PANEL
U2 is usually a memory type issue, have you unplug and then plug back in after 1 hr.
Jan 04, 2008 | Sharp AR-207 Copier
621 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
