Question about Kenmore Dryers
HOW DO I TIGHTENED UP A LOOSE BAFFLE IN MY GAS DRYER
One of the drum baffles inside the tub came loose and is catching clothes when it drys. I thought I would just pop up the hinged top and out some sort of fastener in there to hold it - but I can't get either of the front cabinet latches to release so I can open it to fix the baffle problem - any ideas ? HOW DO I OPEN MY DRYER TO REPLACE ONE OF THE BAFFLE THAT CAME LOOSE ON MY KENMORE SERIES 80 GAS DRYER.
    Genius:
  • 1,122 Answers
If you have the model with the lint filter on top,remove the 2 lint filter screws,pull the top toward you and up and your in-mike
Posted on Jun 01, 2009
Kenmore elite steam dryer replacing a baffle
Remove the top and you will be able to see the side of the drum- rotate it until you expose the screws to the loose baffle.(tighten them all while you are in there) Drum Baffle WPW10112972
Jul 09, 2016 | Kenmore Dryers
How do I take the top off of the Maytag Atlantis dryer?
they are called baffles. and can only be accessed by getting to the outside of the drum. have to remove the body but u may have a bad baffle if the screw hole is busted up?
Sep 14, 2014 | Maytag Atlantis MDE7400AY Electric Dryer
Our dryer has a banging noise. what do we start looking for
remove the top cover,then on the inside look for a loose clothes baffle inside the drum that turns the clothes,then from the top you can replace these baffles or tighten them
Jan 25, 2011 | GE Dryers
We have a neptune front dryer and a baffle came loose inside the drum. How do we repair it
an easy way of reinstalling the baffle is remove the top cover or rather flip the cover upward this will show you the dryer drum in which u can spin the drum to the proper spot where u can retighten the screws that hold the baffle on hope this helps
Jun 25, 2010 | Maytag Neptune MDE5500AY Electric Dryer
As dryer rotates, with clothes drying, it sounds like loose pocket change is loose in between the two tubs.........help!
the change gets caught in the three baffles that are attached to the drum.unplug the dryer,open the door and remove the two screws that hold the in place,remove the door,then remove the other two screws opposite the door screws and pull the front panel off.rotate the drum so one of the baffles are down in the right hand corner so you can get at the screws that hold the baffles onto the drum.try loosening the screws but you might have to remove the baffles to get to the change.let me know how you make out
Apr 19, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Baffle is loose on drum. How do we get access to fix the baffle
The screws that hold the drum baffles in place are located along the outside of the drum. Usually, you need to lift the dryer top in order to access them, and they can be tightened without removing any components. However, all dryers are not contructed the same and access to the drum can vary. If you would please post a brand name and model number it would help in being able to determine exactly how your dryer is configured.
Aug 31, 2009 | Dryers
Inside of drum baffles coming loose on maytag neptune dryer
Hello.
Remove the door and the plastic pieces on the opposite side. Take the front panel off. There will be one metal bracket on each side holding the top panel down. Remove those brackets and lift the top. Turn the drum where the loose baffle is up top and tighten loose screws or replace missing ones.
Jul 18, 2009 | Dryers
I have an LD9334 Dryer with a noise when the drum turns. One of the fins inside has a loose screw and is hitting the top as it goes around. Does the top of the dryer come up or do I have to fix from the...
I fixed mine it by opnening up the gray vent panel in the lower right corner on the rear of the dryer. By spinning the drum, I was able to loom inside with a flashlight and see the loose screws holding the loose baffle in place. I was then able to tighten it.
Jul 02, 2009 | Maytag HYG2460AWW Gas Dryer
Maytag drum baffle came loose and catches clostes when drying
I had the same problem and just fixed it. First, open the door and remove four screws, two are holding the door on and the other two are in the same place on the opposite side. Lift the door up and pull it out to remove it. Set it aside. Pull the front panel down. Admire all of the **** that has collected inside the dryer. Next, there are two dark colored metal clips holding the top down on the upper right and left. Remove the hex head screws holding these on. Wiggle them to release them and take them out. Now the lid will lift to reach the screws holding the fins on. Tighten as necessary. Now would be a good time to get the shopvac and clean the lint and junk out of the dryer. Reverse the process to put it back together. Problem solved!
May 24, 2009 | Maytag Dryers
Banging noise
You may have had a foreign object slip under a loose drum baffle. Manually rotate the drum to locate wwhich baffle it is in.
Apr 06, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
Dryers Logo
308 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
