Question about Lexmark Color JetPrinter 3200 InkJet
I want to hook the printer to my computer
I want to hook up my 3200 printer to my home computer
What brand printer? Is it an HP laserjet/inkjet?
If the printer is relatively new, there should be a USB Type B port on the printer. You'll need a USB cable that can connect the printer to the PC.
Once you have the USB cable plugged in, make sure the printer is turned on. If running Windows 2000/XP/Vista the hardware manager should automatically try to install the printer for you.
You can check that the printer installed by going to Start > Control Panel > Printers and Faxes. You should see the printer listed.
Posted on Jun 01, 2009
SOURCE:
Gateway lx6200 plugged in vga and hdmi cables to various monitors and no video on startup
Is the video card any good? Chances that all three monitors are defective are slim.
Mar 15, 2014 | Gateway LX6200-01 Phenom X4 9500 8GB DDR2...
Can I install a Kodak ESP 3200 Series printer with Windows XP
yes, but you should look for the cd that came with your printer (if you have it) and install that first before you hook up the printer or turn it on. Also, if you already have this printer in your system, delete it and its software before you do a reinstall.
Mar 11, 2011 | Computers & Internet
Hello p.c. proffessional's: my name is Harold, I just recieved a Kodack ESP 3200 series...All in one printer for Christmas. My two questions for now are, Can i hook this printer to my xp window...
Question 1: You should be able to hook it up to that.
Question 2: It's rather simple - here are the steps (these will work on any USB printer):
1. Install the drivers from the CD.
2. Plug in the printer's power (If it hasn't told you to already).
3. Plug in the USB cable (If it hasn't told you to already).
Dec 25, 2010 | Computers & Internet
Cd driver faild
Try unpluging the printer and removing any previous printer software. Any anti-virus software off or disabled. After you uninstall old printer software , reboot the computer then install the new drivers. Then turn back on your anti-virus software.With the computer off, plug in your printer and then turn on the computer. The computer should find the new driver and install it. This is for Windows systems. Let me know if it works for you.
Jun 02, 2009 | Lexmark 3200 Color JetPrinter InkJet
How to hookup my printer to my computer
Here is a link to Lexmark. It provides installations instructions and drivers if needed.
http://support.lexmark.com/perl/support/support.cgi
May 31, 2009 | Lexmark Color JetPrinter 3200 InkJet
Maxtor 3200 power indicator lights but computer won't recognize
ooooh, that sucks.
I assume you have tried unplugging it and plugging it back in?
Have you tried to see if it will work on a different computer?
I hop you had it all backed up.
If nobody else's suggestion beat mine...then I give you 2 options.
You have to take it apart (might have to break the shell, since most aren't designed to be user friendly), once you have the actual hard drive out of its housing, open up the side of your computer, and hook it up.
it will have to diferent connection points. One will be power (thats the plug that has (i believe) 4 pins in it...hook that up so your drive has power...the other plug is for data (read/write), its either a sata or ide (depending on how they (maxtor) made it). I assume you dont know what sata or ide is...just google pics it...once you see a picture...you'll know.
anywho, once its hooked up...start you computer back up (FYI, when you do this 'operation', shutdown your pc...and then unplug it)
once you have it all done and loaded back into windows, it should automatically detect it (give it a few minutes).
that scenerio I just laid out for you, is assuming its anything but a hard drive issue.
if it is indeed a hard drive issue....then apart from sending to to some VEEEERY expensive palce that could extract the data for you. theres only one more option. Put the hard drive in the freezer for several hours, then take it back out and hook it up to you computer, if it detects it...move fast, and start transfering all your files off it...cause now its living on borrowed time.
the reason this works **sometimes**, is because of the hard drives heat, its its platter actually expands over time a (very very very tiny bit), enough to mess it up, and when its chillin in your frezzer, the platters contract a little bit...making you able to get your data back...hopefully.
hope all goes well.
Mar 20, 2009 | Maxtor Personal Storage 3200 (U01E200) 200...
Hook up Avertec 3200 to Sharp Aqueous TV
After I found the manual somewhere on the internet, I realized that it is already available here. (Lucky you!)
I could not find a specific manual for your Aquos TV (which model?). Look into your manual, and see if there is an option to connect via VGA of HDMI for video
If you want to use your TV speakers, it depends what audio input options you have on your TV. You might need a cable like this:
The red/white connectors into your TV, the 2.5mm plug into your computer.
Jan 11, 2009 | Averatec 3200 Notebook
Lexmark Color JetPrinter 3200 InkJet Logo
65 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Clive
Clive
Thomas F. Schneider
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
