Question about Aardvark Direct Pro LX6 Sound Card
Aardvark Direct Pro LX6 won't work on Windows Media Player/Quicktime but can do recording/playback in SW like Acid Pro
I have an Aardvark Direct pro LX6 with v.7.13 driver installed.It works well for recording using Sony Acid pro but the problem the card is not visible in the Sound and Audio Devices in Windows so that I could choose it as the default playback device. The card appears though in the Device Manager.Is there any work around to be able to make it work in windows based media player?Why can't I see it as an Audio/midi device?Pls help.Thanks
2 Suggested Answers
SOURCE: aardvark direct pro lx6 on vista
Hy Idont I can help you with vista but I`ve got Aardvark direct pro lx6 and no drivers for XP. I cant find it in the internet. Could you tell me where can i find it?
Posted on Jun 15, 2008
The file format is not supported
Hi driddle00...
This information came from the Microsoft WebPage:
"Cannot play back the file. The format is not supported. This behavior occurs because PowerPoint can play back only QuickTime movies (.mov and .qt files) that use compression schemes with corresponding Media Control Interface (MCI)-compatible codecs.
A codec (compressor/decompressor) is an algorithm or scheme that is used to record digital video or audio. For example, when you transmit video over the Internet, the video must be compressed on the sending end and decompressed on the receiving end. A codec can be chosen based upon the user's audio or image quality and image size preferences.
When you read a QuickTime movie, a Video for Windows decompressor decompresses the QuickTime files. If the decompressor does not support the compression method used by the QuickTime movie, the decompressor cannot display the movie on the screen.
To work around this behavior, use one of the following methods. uparrow.gifBack to the top Method 1: Create a hyperlink to the .mov file loadTOCNode(2, 'workaround'); Create a hyperlink to the .mov file, and then let the QuickTime Player for Windows play the file instead. To do this, follow these steps:
  1. Select the object or text that you want to assign the hyperlink to.
  2. On the Insert menu, click Hyperlink.
  3. Under Link to, click Existing File or Web Page.
  4. Select the QuickTime movie that you want to play, and then click OK.
    Note Under Look in, click Current Folder to see a list of files, click Browsed Pages to see a list of recently viewed Web pages, or click Recent Files to see a list of recently used files.
During the slide show, click the linked object or text to play the movie. If a valid player is available, the player starts, and then the player plays the QuickTime movie. uparrow.gifBack to the top Method 2: Convert QuickTime movies to AVI format loadTOCNode(2, 'workaround'); Note In the following steps, you must use QuickTime 4.0 Pro. You cannot follow these steps with the basic version of QuickTime 4.0. The steps are the same for both Windows and Macintosh versions of QuickTime 4.0.
You can use other QuickTime editing programs instead of QuickTime 4.0 Pro. To do this, see the QuickTime documentation for the relevant steps.
To convert the QuickTime movies to AVI format, follow these steps:
  1. Start QuickTime Pro, and then open the file that you want to convert.
  2. On the File menu, click Export.
  3. Set the Export file type to Movie to AVI.
  4. Click Options, and then click Settings.
  5. In the Compressor group, click the list of compressors, and then select one from the previous list. Cinepak is a popular format. Select the format that you think works best with the movie.
  6. Make sure that you change the extension on the file name to .avi, and then click Save.
uparrow.gifBack to the top Method 3: Recompress the QuickTime movies with compatible codec loadTOCNode(2, 'workaround'); Note In the following steps, you must use QuickTime 4.0 Pro. You cannot follow these steps with the basic version of QuickTime 4.0. The steps are the same for both Windows and Macintosh versions of QuickTime 4.0.
To recompress the QuickTime movies with compatible codec, follow these steps:
  3. Set the Export file type to Movie to QuickTime Movie.
  6. Click Save.
uparrow.gifBack to the top Verify that QuickTime movies are compatibleYou can use Microsoft Media Player to... loadTOCNode(1, 'moreinformation'); Verify that QuickTime movies are compatible loadTOCNode(2, 'moreinformation'); You can use Microsoft Media Player to verify that a QuickTime movie is compatible with PowerPoint.
Note Microsoft Media Player (Mplayer.exe or Mplay32.exe) is a different program than Windows Media Player. Microsoft Media Player is included with various versions of the Windows operating systems, and is an MCI-compliant device. Windows Media Player, however, is a new technology that does not rely on MCI to play various forms of media. Windows Media Player can play a wider range of video and audio formats than Microsoft Media Player can play.
To determine the compatibility of the movie, follow these steps:
  1. Click Start, and then click Run.
  2. In the Open box, type the appropriate command for your operating system:
    • In Microsoft Windows 98 or Microsoft Windows Millennium Edition, type mplayer.exe, and then click OK.
    • In Microsoft Windows NT 4.0, Microsoft Windows 2000, or Microsoft Windows XP, type mplay32.exe, and then click OK.
    Microsoft Media Player starts.
  3. On the File menu, click Open.
  4. Select the QuickTime movie that you want to verify. Click Open.
If the QuickTime movie is compatible, Microsoft Media Player opens the movie. If Microsoft Media Player opens the movie, but PowerPoint does not, there may be a problem with PowerPoint or with the MCI settings. If Microsoft Media Player does not open the movie, and then you receive an error message in Media Player, the movie is not compatible and cannot be played in PowerPoint. You may be able to make the movie compatible by using one of the methods described in the WORKAROUND section of this article."
Sep 06, 2011 | Philips GOGEAR SA6045 MP3 Player
Need 64 bit Win7 drivers for my aardvark LX6
all devices which work with XP should work with 7... this is the way microsoft designed windows 7... download realtek high def audio drivers and install em.... this should solve the problem...
Apr 01, 2010 | Aardvark Direct Pro LX6 Sound Card
Windows XP drivers for Aardvark Direct Pro 24/96
Go here: http://www.drivers-fix.net/aardvark.php
Oct 14, 2009 | Aardvark Direct Pro 24/96 Sound Card
I need the LX6 Direct Pro Driver for windows vista. All of the drivers i have tried say there do not support that OS. Do you have this driver or know where i can get it. Also do you know if the...
Aardvark had went out of buisness about 3 to 4 years ago. Unfortunately they didn't last long enough to write a driver for vista. Sorry to be the bearer of bad news. I love aardvark I had the LX6 and still have the 24/24 and Q10. Too bad they only work up to XP. Sorry. driverguide.com still has the XP driver.
Oct 01, 2009 | Aardvark Direct Pro LX6 Sound Card
Each channel is only either L o R pan
I am confused. I took a look at the specs for this via a google search and it is describing something ancient designed for Windows 95/98 with a 5 pin Din socket, phono and one quarter inch stereo jack and one quarter inch mono jack - yet the accompanying illustration clearly shows something entirely different, more as you describe.
In order to be able to comment usefully it would be necessary to see an internal wiring diagram and/or be privy to more detailed specs than available in the articles I just viewed. Perhaps the operating manual would provide more detail.
It occurred to me with a name like Pro LX6 it could really have been aimed at the professional. The best sereo recording and reproduction is when the two channels are electrically isolated from each other and there is no crosstalk.
In the world of stereo, separation is the name of the game, both during recording and reproduction. The best method of achieving separation so the depth and direction of a performance can be more fully reproduced is to record from a number of sources from a number of places and ideally each source will be a mono source and stereo doesn't happen until much, much later...
I think you have more to learn about your sound card and the sort of sofware that suits it the best.
Apr 15, 2017 | Aardvark Direct Pro LX6 Sound Card
Direct PRO LX6 driver download
http://members.driverguide.com/driver/detail.php?driverid=330595
if helped rate fixya
Jul 12, 2008 | Aardvark Direct Pro LX6 Sound Card
Aardvark Direct Pro 24/96 Audio effects problem
Checkout your sound mixer setting in windows control panel (if you have windows) or in "Preference" or "Advance setting" tabe in adobe audition software
Check your connecting cables have appropriate jacks
Mar 19, 2008 | Aardvark Direct Pro 24/96 Sound Card
Aardvark Direct Pro Q10 wont intall with windows xp
I NEED A AARDVARK, DIRECT PRO Q10 INTERFACE (CONNECTOR) HOST TO BUY. CAN YOU HELP ME FIND ONE?
THANK YOU,
BRIAN MCBEAN
Feb 17, 2008 | Aardvark Direct Pro Q10 (bundle) External...
Aardvark direct pro lx6 on vista
Nov 08, 2007 | Aardvark Direct Pro LX6 Sound Card
A|WDM driversfor Aardvark Direct Pro 24/96
Hi, try Drivers.com [found on google] you will need to sign up for free membership but they have thousands of drivers uploaded by members. Regards mistyman
Sep 30, 2007 | Aardvark Direct Pro 24/96 Sound Card
Aardvark Direct Pro LX6 Sound Card Logo
144 people viewed this question
Top Aardvark Computers & Internet Experts
David Payne
David Payne
Are you an Aardvark Computer and Internet Expert? Answer questions, earn points and help others
