Question about Panasonic PV-L680 VHS-C Analog Camcorder
Snow on playback
I keep getting "snow" or distortion on the playback in the camera.  I have run a cleaning cassette through and it has not solved the problem.
2 Suggested Answers
SOURCE: can not playback
what kind of smack???
Posted on Apr 03, 2008
SOURCE: Cassette load issue
I have recorded two casettes with DCR TRV480. In midst of recording the 1st cassette, I got this flashing reinsert cassette issue. I removed the battery and put it back on and the problem disappeared and I was able to complete the recording. While recording the second cassette, I again got the same proble. This time removing the battery did not help. I was unable to complete the recording on the 2nd tape leaving unused space. While trying to play it on TV, I am getting the same problem with the two cassettes and even with an earlier cassette (which I had played earlier). When I insert a new cassette the problem does seem to appear. I need help as I am unable to play any recorded cassettes!!! any input would be really welcome.
Posted on May 18, 2008
0 characters
1 Points
Sony handycam ccd-tr9 video playback is distorted
the video head problem, try to clean it with head cleaner cassette. play the cleaner cassette several times, test, if still problem must change the video head.
Jan 20, 2016 | Sony Video Cameras
Tape Wont Play
My advice is that you should by a cleaning cassette. Put this in the camera and run it for 10 to 20 seconds only. running the cleaning cassette for a long time may damage the head.
good luck!
May 10, 2009 | Sony Handycam CCD-TRV58 Camcorder
TRV-350 playback problem
Sounds like dirty heads. Get a head-cleaning tape and run that.
Dec 29, 2008 | Sony Handycam DCR-TRV350 Digital Camcorder
Blue Screen or Pixelated on Playback
Check Canon's Website. There's a known problem with video chip on several different models...including zr80...a loose connector from the CCD.
I know what I'm talking about because I just got one fixed...for FREE.
Aug 29, 2008 | Canon ZR80 Mini DV Digital Camcorder
Won't playback
Use good quality video head cleaning cassette because video head seems dirty/ clogged. If it doesnt solve the problem, video head need to be replaced.
Jun 25, 2008 | Sony Hi8 CCD-TRV138 Camcorder
Problems with playback of HI8 tapes...
What's happening is that the tape in the cassette is being chewed on one side by the camera's tape transporting mechanism during playback, hence the distorted image and sound. The mechanism might be damaged (misalignment) or just dirty. Try not to play other tapes on this unit because they will become permanently damaged. The best way is to find another camcorder (if cleaning does not help). Note that some old cassettes of long recording time will exhibit this behavior more often because of thinner tape used.
Dec 06, 2007 | Video Cameras
No pic or sound when recording
Please get a Hi 8 cleaning cassette and run it in the camera for a few seconds. you may have to do this several times for the head to be completely cleaned unfortunately for Hi8 you will not hear the sound when there is no picture on playback.
Sep 27, 2007 | Samsung SC-L906 Camcorder
Horizontal snow lines on record and playback
the symptom is caused by a dirty video head. sometimes cleaning tape cannot do all the jobs, especially when the dirt is so much that any cleaning tape cannot remove it. open the cover, use a clean white paper dampened with a little alcohol. use your finger on the paper and gradually move the head drum back and forth. donot move the paper up or down. just move the drum slowly. good luck!
Jan 31, 2007 | JVC GR-FXM38 VHS-C Analog Camcorder
Tape Cleaning on-screen warning
Depending on the age of the camera/cassette, it may be that the heads are not just dirty, but are actually worn down. The gray bars are the DV equivalent of snow - data has been lost or at least cannot be displayed. If cleaning doesn't solve the problem, the heads probably need replacing. Depending on the age of the camera, it may be more cost effective to upgrade to a new camera.
Apr 02, 2006 | Sony Handycam DCR-TRV520 Digital Camcorder
Bad playback quality
Some possible cause of lines, noise or pixelation during playback are: 1. Dirty heads on the recording machine. If the heads were dirty at the time of recording, the dirty heads didn't record a strong enough signal on the tape. The damage is done for this tape and recovery is unlikely. Best advice here is to use only premium grade new tapes and keep your camcorder clean by occasionally running a cleaning tape. 2. Physical tape damage. Any distortion of the tape will result in mistracking and subsequent loss of data. 3. Built up oxide deposits or other debris in the guidepost corners can also result in tape edge damage. Keep your machine clean! 4. Improper tape storage - Even short term exposure to high temperatures over 130 deg f. can permanently damage the tape. The black cassette housing readily absorbs the sun's infrared rays and internal cassette temperatures can soar even if left in direct sunlight on just a warm day. It doesn't take much heat to slightly distort the plastic shell or ruin the tape contained within. * Try other tapes to ensure the problem lies within the tape and not the camcorder. * If the problem becomes apparent on all tapes, try a head cleaner. After cleaning the heads, the tapes may not play cleaner if the recording was done while the heads were dirty.
Sep 06, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
Panasonic PV-L680 VHS-C Analog Camcorder Logo
15 people viewed this question
Top Panasonic Video Cameras Experts
Lawrence Oravetz
abdul rauf
abdul rauf
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
