Question about Acer ScanPrisa 640P Flatbed Scanner
Cable connectivity with my laptop through a "parallel to usb cable". My laptop has no parallel port but only usb ports.
I've an Acer scanprisa 640p scanner which I would like to use with my laptop which has no parallel port but only usb ports. I purchased a Parallel to USB adaptor cable but it doesn't work with it. Probably it only works with a printer and not a scanner. Can you please help me how to sort out the problem??
  • thefraternit Jun 01, 2009
    The cable I purchased did not come with a USB to Parallel Port driver. Can you help me find a driver for such a cable??
    Sergeant:
  • 145 Answers
Make sure you follow this step :
1. install driver USB to Paralel port (LPT1) before the cable connected to PC
2. After the driver installed, install the cable - and it supposed to be detected
3. the last think u have to do is install the scanner/printer driver
if it is not work, i guess the problem is on the USB to paralel adapter, or the driver not installed correctly
Posted on Jun 01, 2009
SOURCE:
One cable would fit into my pc the other into my monitor- that is how i'd hook up my 640 p acer flatbed scanner for xp windows. cool. now ive changed my monitor and it doesn't have a port. what do...
If your pc is lack of usb port. You can buy usb card to enhance usb port in your pc to connect your scanner...I presume that your scanner is usb supported cable
Sep 19, 2011 | Acer ScanPrisa 640P Flatbed Scanner
I wish change parallel port to USB port. I have a ScanPrisa 640P Scanner and my computer use USB ports. What can I do ?
you will need an adapter like this one. But first make sure you have the current drivers available on the scanner before you connect the adapter. Refer this site for the drivers and instructions.
Jan 04, 2011 | Computers & Internet
Acer scanprisa 640p paralel to usb port problem
Push the parallel end of the cable adapter onto the parallel port of the printer. ... Ensure that the clips for the parallel port and cable are in the locked positions. 3. Unplug the USB end of the cable from the USB port on the computer, and then reinsert it.
Also look here-
https://yourbusiness.azcentral.com/use-parallel-scanner-usb-7712.html
Jan 06, 2018 | Acer ScanPrisa 640P Flatbed Scanner
Scanprisa 640p driver
You can download your dirver here:
http://www.scanner-drivers.com/drivers/79/79801.htm
If your computer don't have parallel port you can add one.
This will fix your problem.
Don't forget to rate my help! :-)
Thank you for using FIXYA!
Pablo
Oct 15, 2008 | Acer ScanPrisa 640P Flatbed Scanner
It does not work. The computer dos not recognise it
Hi Sir,
I have Acer Scan Prisa 640C Flatbed Scanner ,which is having parallel port. When I installed the driver ,start to scan ,the computer does not recognise the port ( Parallel Port ).
So please help to solve this problem step by step instruction.
My operating system is Windows XP Professional.
Computer is Intel P 4 --3000
Hdd 80 GB
DDR 512
Thank you.
Jun 01, 2008 | Acer ScanPrisa 640P Flatbed Scanner
Mac compatibility
scaner driver acer prisa 640 driver windows xp
Jan 04, 2008 | Acer ScanPrisa 640P Flatbed Scanner
How to hook up?
This scanner may have a parallel and a USB port. Use the USB port, if it exists. If not, connect the scanner to the parallel port, then connect the printer to the pass-through port on the scanner. This can be problematic, requiring changes to the BIOS and driver difficulties. A USB scanner is a better solution, and they are cheap nowadays.
May 21, 2007 | Acer ScanPrisa 640P Flatbed Scanner
Acer ScanPrisa 640P Flatbed Scanner Logo
592 people viewed this question
Top Acer Office Equipment & Supplies Experts
jasbo
jasbo
Ekse
Steve Allison
Steve Allison
Are you an Acer Office Equipment and Supply Expert? Answer questions, earn points and help others
