Question about Wolf Range fs-0-27-ft36 Gas Kitchen Range
Oven door blew open, late ignition and broke the door
Lucky my wife had just moved out from in front of range or she could have been injured severly. Gas build up no ignition. Also burners sputter on med heat.
help
    President:
  • 1,902 Answers
Call the gas company have them come and look at the system since it built up presssure and blew the door pen is not something you want anyone online talking to you about. Or get a tech this is a very serious problem and thankfully no one was injured in this situation
Posted on Jun 01, 2009
I have a ge spectra self cleaning oven the door does not lock when cleaning process begins it flashes locked and starts beeping but hook does not move into the lock position. I tried to unplug oven ho
If your GE Oven will not lock during the self clean cycle count yourself lucky. If it will go through the cycle then let it self clean and just make sure no one opens the door while it is hot. Most ovens fail locked and there are several possible faults - one of the two switches may have failed, the oven temperature sensor may have failed, the motor that drives the lock may have failed (most likely your issue), the plastic gear may have stripped. There is not a manual lock or unlock over ride and to unlock the oven manually you have to take the stove apart which is difficult when it is locked.
Jan 22, 2015 | GE Kitchen Ranges
We have a kitchen aid KGSA906PSS00 gas range. for the first time today the wife decided to run the self clean function. At some point through the self clean the oven shut off and the control panel died....
Sounds like my problem two days ago. I have a Kitchen Aid free standing gas oven/range model
KGRI801PWH00. I read online that the thermo-fuse might've blown. I found the thermo-fuse after removing the rear panel. It was at the top/center. Mine is T-O-D (brand) 60F24; Westinghouse #8300802. I ordered mine from appliancepartspros.com for only $34.75; arrived in 36 hrs with regular shipping!! Easy to fix, sure beats several hundred $$ to repairman.
Don't bother to call Kitchen Aid - they'll just blow you off just like the hundreds of complaints said that I found online.
Jan 27, 2011 | KitchenAid KGSA906PSS Gas Kitchen Range
Power went out, now ovens are 'locked' - how to unlock?
I DO know the lower oven door can be released by lifting gently up and to the right, and a little 'joggling' will allow the door to be opened. It seems the lock latch swings to the (almost) locked position unpredictably and intermittently. I hate this @#$% stove. So does my wife.
The upper oven door has never seized. Upper oven has burned through several elements, and it's dangerous to replace. NEVER TRY ANYTHING WHEN CIRCUITS ARE STILL LIVE.
I hate thjis stove. I REALLY DO HATE IT.
Nov 08, 2010 | Maytag MER6772 Gemini Electric Kitchen...
Roper Gas Range Oven Makes Sound
check you have ventilation. i.e. try with the window open
Feb 14, 2010 | Roper FGP305 Gas Kitchen Range
Gas oven wil not unlock after cleaning
Hello. I may be able to assist you. There are several possible fixes to your problem. Hopefully one of these will work for you. The oven door lock needs approximately 1 hour to cool down before the oven door can be opened after a self cleaning cycle has finished. If the lock does not open after the oven has cooled down, you can try....1) Unplugging the range or shut off the circuit breaker for 5 minutes. Plug the range back in or turn on the circuit breaker. Set the clock and try moving the door lock lever or opening the door. 2) Set the self-clean cycle again and only allow it to work for 15 minutes. Cancel the self-clean cycle and allow the oven to cool. Gently try moving the door lock lever or opening the door.
Most ranges today use 3 different types of door locks...one is a solenoid controlled lock ( you hear a loud buzz noise when setting or unlocking the lock and has a arm that you must move to set the lock )...another is a heat sensitive lock ( has a arm that you must move to lock and un-lock, makes no noises and has a spring that slowly moves to lock the door will the oven is heating up )...Some locks are motorized ( no handle to move, the motor locks the door by it's self when you set the range for self clean )... If the motorized and heat sensitive locks fails to open after the self clean cycle, you must access the lock and move it yourself to open the door. On the free standing ranges, most times you must lift the cook top to access the lock mechanism. On built in ovens, the oven must be pulled out to remove the top access panel to get at the lock mechanism. Some build in ovens can have the control console removed to access the lock system. On the heat sensitivestyle of lock, there are no electrical parts to operate the lock, usually you will need to replace the lock. On the motorized style of lock, you will have to use a ohm/volt meter to test why the motor will not work. On the solenoid style of lock, the solenoid is often mounted on the back of the range and can be accessed by removing the rear panel, some may be mounted at the front, such as in a built in oven. The failure of the solenoid style of lock is normally caused by a bad lock solenoid. In order to get your door open, you must operate the door latch mechanism manually. Unplug or remove power from the range. Take the rear cover off the range. Locate the door latch assembly and operate it manually and open your door. Then check continuity of the solenoid. Some of the latch assemblies have micro switches to supply power also. You may need to check them. You should be able to get the door open and use your range until you can get a tech to repair if you can not repair yourself.
Dec 07, 2009 | Jenn-Air JGR8775QD Gas Kitchen Range
Self-cleaning oven door won't open
Most ranges today use 3 different types of door locks...one is a solenoid controlled lock ( you hear a loud buzz noise when setting or unlocking the lock and has a arm that you must move to set the lock )...another is a heat sensitive lock ( has a arm that you must move to lock and un-lock, makes no noises and has a spring that slowly moves to lock the door will the oven is heating up )...Some locks are motorized ( no handle to move, the motor locks the door by it's self when you set the range for self clean )... If the motorized and heat sensitive locks fails to open after the self clean cycle, you must access the lock and move it yourself to open the door. On the free standing ranges, most times you must lift the cook top to access the lock mechanism. On built in ovens, the oven must be pulled out to remove the top access panel to get at the lock mechanism. Some build in ovens can have the control console removed to access the lock system. On the heat sensitive style of lock, there are no electrical parts to operate the lock, usually you will need to replace the lock. On the motorized style of lock, you will have to use a ohm/volt meter to test why the motor will not work. On the solenoid style of lock, the solenoid is often mounted on the back of the range and can be accessed by removing the rear panel, some may be mounted at the front, such as in a built in oven. The failure of the solenoid style of lock is normally caused by a bad lock solenoid. In order to get your door open, you must operate the door latch mechanism manually. Unplug or remove power from the range. Take the rear cover off the range. Locate the door latch assembly and operate it manually and open your door. Then check continuity of the solenoid. Some of the latch assemblies have micro switches to supply power also. You may need to check them. You should be able to get the door open and use your range until you can get a tech to repair if you can not repair yourself.
If you've interrupted the clean cycle or have accidentally set the clean cycle with the oven door open, the latch may have engaged and now the door can't be closed because it will hit the latch. There may be a door activated* switch on the front face of the oven. In this case you may need to manually press that door switch with your finger while at the same time canceling the clean cycle to get the latch to retract so the door can close fully again.
May 15, 2009 | Ovens
Oven door
replaced oven igniter without removing oven door
Jan 08, 2009 | Tappan TGF657 Gas Kitchen Range
Amana Range ARG7300W -- igniter problem back??
I am sure you noticed where it is located. A gas oven cycles the same as an electric. depending on the number of times the door is opened and the length of time you operator the oven. Our furnace was acting up one night last winter and I turned the oven on warm with the door cracked open until I could get the part for the furnace in the morning and our igniter went out on the oven. Also try not to touch the element on the igniter when you install the new one.
Dec 02, 2008 | Amana RanARG7302 Gas Kitchen Range
SMEG A 2.5 Range Oven
sound like the TOD to me. have a technician replace it.
Dec 22, 2007 | Smeg A2.5 Dual Fuel (Electric and Gas)...
Lower heating is not working
Replace the igniter even if it "appears" to be working. Bright red isnt hot enough. It has to be bright white. Goodluck...
Dec 17, 2007 | Hotpoint RGB745 Gas Kitchen Range
Wolf Range fs-0-27-ft36 Gas Kitchen Range Logo
296 people viewed this question
Top Wolf Range Kitchen Ranges Experts
Ismael Rodriguez...
John Rodgers
John Rodgers
Dan Webster
Dan Webster
Are you a Wolf Range Kitchen Range Expert? Answer questions, earn points and help others
