Auto adjustment in progress in my HP LCD monitor 1940
SOURCE: no white color on my hp lcd monitor
check the output of your power pack .you are having voltage drop in your output supply
SOURCE: HP 1940 LCD Monitor power and other manual controls do not work
there's an internal hardware problem in your monitor - cold soldered / defective electronic part/s. I suggest to bring the unit to an authorized service center for proper diagnosis & fix the problem. best regards
SOURCE: auto adjustment in progress popping up and
Right click on your desktop, go to properties, and navigate to the settings tab. There, try to set the monitors resolution to the largest available. That should fix your problem. If it doesn't just try some other resolutions until ou find one that works. I hope this helps, Yannick.
SOURCE: how i can to open the cover of lcd hp L1706
1.- remove 14 screw on back
2.- remove front cover con un desarmador plano pequeño, como si pucharas hacia afuera y luego al frente por toda la orilla.
3.- quitar la base es solo con un simple apreton y click y listo, sale la parte de abajo y luego aprietas la parte de arriba y estiras. y ahi vas a ver unas tuercas te puedes ayudar con una llave española o perica pequeña.
y listo.
SOURCE: samsung 20" LCD monitor B2030
OSD Lock & Unlock Basic LCD monitor and TV troubleshooting guide: Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you. Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
When pressing the AUTO button after locking the OSD
When pressing the MENU button after locking the OSD
This is the function that locks the OSD in order to keep the current states of settings or prevent others
from adjusting the current settings.
Lock : Hold down the MENU button for more than five (5) seconds to activate the OSD adjustment
lock function.
Unlock : Hold down the MENU button for more than five (5) seconds to deactivate the OSD adjustment
lock function.
Please leave rating if it helps.
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
