Question about Kenmore Elite 45986 Front Load Washer
F25 code for brand new washer
Help! We just had our new washing machine installed and after starting a washing cycle, F25 is flashing.  No one at Sears technical support (by phone) can explain what this problem is.  Could you please advise a.s.a.p.?
Thanks
  • z305610 Nov 21, 2007
    Have Same problem. Ran on normal like it says to in the book. Worked fine. Put in a load of Whitest whites and worked just long enough to get t-shirts and undies soaked. Had to ring out by hand. I got an HE 2 washer. Unplugged and waited about an hour and retried. Got 45 minutes into cycle and darn thing did it again. Sears guy coming tuesday, let you know what he says.
  • nautcruise5 Sep 21, 2008
    F25 Error
  • 4,889 Answers
F25 is a keys stuck error code which must be covered under warranty..The only option is to replace the keypad..I suggest that you pester those customer support fellows so that you can get it fixed as it is a pretty complicated process to do it yourself..
Posted on Oct 23, 2007
Code F25 on my whirlpool washer
F25 is a MOTOR CONTROL error . check for past posts in Search as there were some in 2007 shown on Fixya . or check throgh Google / Internet explorer by stating F25 Washing Machine error
Jan 09, 2018 | Whirlpool Washing Machines
Hi Have a WEC7500VW whirlpool front load washer shows a F25 code . Looked at the tech sheet in washer does not show that code what is it? Also washer will not spin out on high at end of cycle. Did the...
Not sure what you mean but if the washer doesn't spin then it's probably the switch that controls the spin action.
On most washers, when you open the lid or door the spin cycle stops for safety's sake. In many cases, there is a small extension on the door or lid that engages the switch when you close it. Look where the extension is supposed to engage and that's the switch. I was able to fix my broken switch on my GE washer by cutting the edge of the plastic on a pen and gluing it to the extension so it pushed the switch mechanism down further to start the spin cycle.
Hopes this helps.
Paul
Sep 29, 2014 | Washing Machines
When starting any cycle, water fills, time counts down, but never washes or spins.....then, the letter ''F'' flashes along with the number ''25''
Error F25 is a "DRIVE MOTOR TACHOMETER ERROR" If the control is unable to properly detect motor speed, the
machine shuts down.
This could be as simple as a loose wire connector inside the machine. Or it could be something serious. I would recommend calling a service tech. If I can help you in any way please let me know.
Mar 20, 2010 | Kenmore HE2 Plus Front Load Washer
My he5t is giving me f25 code. i have pressed stop and tried to drain but i get f25 again. do i need a new belt?
Here is the info on "F25":
f25_code.jpg?t=1177554999
When you open the top of the washer, look at the black rubber hose leading up to the pressure switch. If the hose is kinked, it will fool the pressure switch into thinking the washer is either full of water or it did not see a water level change after the water valves have been on for a period of time. These failures generate the F20 / F25 codes.
To Clear the F25 Fault. Disconnect & Connect the "Water Level Presure" switch plug, a couple of times, Give it a couple of light "Taps" Reconnect again, and see if that works, it should.
Feb 16, 2010 | Kenmore Elite HE5t Washer
Error code f17
Sears are a department store not a manufacturer, they contract other manufacturers to build the appliances for them and these are then sold under the Sears/ Kenmore brand.
To find who made your appliance, check the first three digits of your model number against the list below and this will give you the manufacturer of your appliance.
There is a site to help identify you washers "real" maker
The Link is here to cross reference it.then look up f17 and f25 on that make and model for better results
http://www.appliancefactoryparts.com/applianceshvac/help-center/fault-codes/fault-codes-washer.html
the Sears/Kenmore part is almost in the middle of the page. Then keep me posted by adding comments if you have any other questions
I hope this helps you out
8-)
Jun 07, 2009 | Kenmore Elite 45986 Front Load Washer
Fault code F25
If you remove three screws along the bottom front the bottom panel comes off.
On the inside, on the right wall, is a plastic bag with a paper labeled "FOR SERVICE TECHNICIAN ONLY".
This has a section titled "FAILURE/ERROR DISPLAY CODES" with all the error codes along with an explanation and recommended procedure. For F25, this is:
If the control is unable to properly detect motor speed, the machine shuts down.
If a failure occurs during high-speed spin, the door unlocks after 3 Minutes.
Possible Causes/Procedure
1. Verify the shipping system including shipping bolts, spacers and the power cord are removed.
2. Unplug washer or disconnect power.
3. Check drive motor tachometer resistance. It should be approx. 115 ohms.
4. Check wire harness connections between the drive motor and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU).
5. Plug in washer or reconnect power.
6. Check the MCU by looking for operations of the drive motor.
7. Check the drive motor for powered rotations.
I got this working for many on this site :)
Thanks
Fame !
Apr 25, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Could you help me i haven't got a manual for my hoover nexta optima wash system hnl 6166 if you could just give me some basic instuctions i would be very gratefull thankyou.
Just purchased this morning. Will not start, does not throw error code. does not do anything but the cycle red light flashes. All other options will change and such, but the washer will not start. No matter what cycle you choose.. service can't come out till morning.. help. .................................................................................................................................................husband is gonna be pissed, brand new set.
Feb 19, 2008 | Washing Machines
F25 error code
this is scary. I got a brand new whirlpool duet sport I ordered from Costco.com. After 19 days of waiting for delivery it finally arrived and was installed by the whirlpool dlvy people. I read the instructions and started my 1st load within an hour of being installed. It never worked. Ok it work 6 mins and stopped on every cycle I put it on and then I got the error code 25. I called their customer svc number and they could not even tell me via the phone what that meant. I am suppose to have another delivered here HOPEFULLY next week but after seeing others having repeated problems I do not know if I should just say no take it all back.
Jan 27, 2008 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
F 25 Code
F25 is a motor tachometer code. In simple terms, the machine control does not know how fast the motor is turning so it shuts down. The problem could be in the motor, motor controller, the main control, or a wiring harness problem. Since it is new, I expect it is something simple like a connector that is not plugged in properly. I am seeing a lot of this kind of problem lately. They are getting in too big of a hurry at the factories I think.
If you can't wait for service, unplug the machine and remove the lower front cover and check the connections at the motor and motor controller. You can remove the top and check the connections at the main control. Just be sure not to change anything, just make sure all the plugs are pushed in to the connectors properly.
Let me know what you find out.
Mike
Jan 06, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
1,144 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
