Question about Canon Bubble Jet i80 InkJet Printer
Sounds/looks like it's printing but paper comes out clean - there's lots of ink and I've changed the ink levels
My Canon i80 has new ink (I have changed the levels) and looks/sounds like it's printing but the paper comes out blank - can you help?
    Problem Solver:
  • 15 Answers
Hi, have you checked to make sure you removed the sticky tape cover from the end of the cart?
Sounds silly I know but I have done this before & it's easy to forget when your in a hurry :-)
Cheers
Sham
Posted on Jun 01, 2009
My Canon ip3600 has full ink, there is paper in the tray. It will print the page I want it to print. However, there isn't any ink / text on the pages that are being printed
It sounds like either the ink cartridges are clogged, or if you've installed new ones, it could be you forgot to remove the tape that covers the ink jet on them. If clogged, you can use alcohol on a Q-Tip to clean the jets.
May 06, 2011 | Canon PIXMA iP3600 Photo Printer
I installed the Canon i80 driver and the printer is recognised by my PC however when i try to print the i80 does all the actions but no ink is shown on the paper. I have checked the print heads and the...
I know it sounds daft.. i had this on a word document... although the text was showing in black it was printing in white. try changing the text colour to black... hope that helps
Jan 10, 2011 | Canon i80 InkJet Printer
My Canon i80 inkjet printer hasn't been used for some time. I've put in new ink cartidges (both black and colour). The black is not printing at all and the magenta is very faint. This happened before and...
Got it..... Tka ethe ink cartridge out and LIGHTLY use an alcohol swab and wipe it over the ink port, this will loosen andy clogged up ink..... Please let me know if there is anything else you might need, happy to help! Guy :)
Sep 23, 2010 | Canon i80 InkJet Printer
Hi, my canon i80 printer wont feed paper through
There is only one solution to the problem with the i80. Here it is: there is nothing jammed. This problem is the result of the top of the printer being pushed down, effectively crushing the paper feed path by a sixteenth of an inch, right at the center of the machine. Likely this is the result of being carried in a travel bag full of other stuff, like the power supply, or from things being placed to rest on top of the printer. The solution is to open the two top covers, to grasp the main steel bar that runs the entire width of the printer with a pair of long-nosed pliers and to simply apply upward pressure. This will, in turn, lift a black plastic paper guide that has been pushed down into the path of the paper by the slightly bent metal. The printer will happily feed paper after this relatively simple fix. Mark the problem up to bad industrial design (though the mechanisms of the printer are otherwise ingeniously well thought out).
Sep 16, 2010 | Canon i80 InkJet Printer
Need to replace Waste Ink Absorber on a Canon i80 printe. A window keeps coming up and now I can,t print any thing untill I replace this absorber. I can't even find it.
The absorber on this model runs across the back and looks almost like a C cell flashlight. It's called the drain pack assembly, #QL2-0194-000. It's tough to change and after you need to access the service mode to reset the counter.
Dec 31, 2009 | Canon i80 InkJet Printer
My i80 canon printer not printing in black ink only in color. what is the problem? Rebecca
I think you have to check the settings on your printer, maybe it is set to print color alone, so you need to change it to print both black and color.
you can equally remove the black cartridge ink and clean the surface, maybe it is stock with dirt,
I wish you best of luck
Dec 22, 2009 | Canon i80 InkJet Printer
Splotching and spotting ink
The roller cleaning will require you to remove cover to clean the full roller with alcohol to remove ink build up. Have you tried to just run/feed a blank piece of paper through to see if you have roller ink roll off?
This also sounds like a bad cartridge with clogged jets...
Jun 15, 2009 | Canon i80 InkJet Printer
Printer prints blank paper. I have cleaned and changed all ink. It was suggested to remove the print head and wash it. Where is the head? Please help. Need this for my home office. Thanks
It appears that the print head nozzles are blocked, it is difficult to clean, it may be cleaned with a ultrasonic cleaner. Most likely you will need to buy a new print head, these are not cheap and you may find it better to buy a new ink jet prnter.
Inkjet printer heads tend to block up if used infrequently, inkjet printers should be run/used every several days to prevent nozzels blocking. If this is your case and you only want to print black & white, I suggest you get a laser printer. It is cheaper to run and don't suffer from infrequent use.
Nov 18, 2008 | Canon i80 InkJet Printer
I80 black cartidge not printing
get a q-tip and wet one end in water.  run wet q-tip along head a few times.  then take dry end and run along head again to dry it.  then run wet end again on the absorber side of head.  then dry with dry end.  replace parts, do a deep cleaning, and try a test print.
Apr 27, 2008 | Canon i80 InkJet Printer
Both colored & black ink tanks are new but nothing comes out
I have had this problem before. Try removing print head and cartirdges. get warm water in bowl and swirl head in water until water remains clear. Need to empty and refill water a few times. Pat dry with absorbent paper. Re-install head and cartridges and do a clean.
Dec 27, 2007 | Canon i80 InkJet Printer
Canon Bubble Jet i80 InkJet Printer Logo
90 people viewed this question
old marine
old marine
