Question about Kitchen Ranges
The oven no longer works - this thing isnt that old! When you try to turn it on you just hear a few clicks from the control panel. The cook top works just fine. It is a kenmore Mod# 665.9214 electric range.
    Brigadier General:
  • Kitchen Ranges Master
  • 3,614 Answers
on such case like your, it seems that you have a faulty control board on your unit.. a possible problem on the fuse near the control board or the main board was damaged that need to be check and fix.
sometime this happen when you do a self cleaning on the unit, and an improper termination of the task may result with this
hope this initial info helps.
Posted on Jun 01, 2009
I have a KitchenAid Superba KEMC308KSS0 that is about 9 years old. In the past few months it has been cooking really slowly. Whereas in the past, in convection mode, things cooked faster than...
I have a Superba built-in YKEBS 177 D56 ( dual convection/convention)...I think it might be about 10 years old. I noticed the same thing starting last year..the temperature seems a litlle off and the cook time on the convention seems to take longer. I've never used the conventional oven so I don't know if the temperature is OK on that component.
I don't have a manual. and I've been searching for it...does anyone know which one I need?
Sorry I couldn't help with your problem, mine is similar to your though!!
Jan 22, 2011 | KitchenAid KEMC308K Double Oven
5E (SE) error showing on my samsung C106FL micowave oven (2 years old). None of the other keypad buttons are working. I unplugged the oven & re-plugged next morning but still saem result. Pls help.
The "SE" error indicates a shorted membrane keypad.
You can find support from Samsung in India here.
Dec 18, 2010 | Samsung MC5694 Microwave Oven
I have just moved into a 10 year old house. It has Blanco gas cook top and a Blanco wall oven. My problem is the electric starter for the gas top does not work. and the Oven indicators eg. top element,...
#1 You may have a blown fuse which sets all these issues together
#2 Your sparker may need to be tested, try a voltmeter to it and see what it reads. If voltmeter reads voltage, then it's a simple adjustment of distance to contact. If no voltage, then you'll need to replace sparker.
#3 as far as your indicators, that has to be an internal fuse.
I agree with you for not replacing these appliances, I love to cook with gas
Dec 16, 2010 | Microwave Ovens
The bottom heating element won't heat up
If the new element is good then the next thing to check is the selector knob (COOK/BROIL) and the thermostat for the oven.
To check the thermostat, turn the selector to BROIL and turn the thermostat up until the top element begins to heat. Let it heat up a little then turn the thermostat down until it clicks off. If this works then your thermostat is working.
The problem then must be your selector control. Remove and replace (turn power off at circuit breaker box first!).
Of course, if the thermostat won't turn on the upper element either then it must be the thermostat.
There is a possibility also that a loose/broken/burned wire is causing the problem. You should check for this when you open up the control panel (after turning off the circuit breaker!).
Oct 28, 2009 | Ovens
No broil or oven cook top works
try checking the ignitor or the thermostat in the oven.
Sep 16, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Inglis Niagara oven not working since power outage
try pushing cook and hold button once until lock comes on, then push cook and hold button again. The lock should be removed.
Aug 13, 2009 | Maytag MER6772 Gemini Electric Kitchen...
My oven doesn't work.
before you replace the control panel, take a quick look inside the oven at the ceramic spark starter.. when you (tyr to) turn your oven on you should hear a bunch of little snap sounds.. sparks trying to light the burners inside the oven..
if you try to use the element (broil) without the gas - you'll get a better bearing on whether or not the gas element(s) are lighting or not inside the oven..
hope that helps..
Apr 05, 2009 | KitchenAid KGRI801PBS Gas Kitchen Range
Our refridgerator is no longer cooling.
Is it not cooling at all? Like you to try a few things to help locate the problem. Look inside the fresh food compartment where the controls are and try to turn the defrost timer clockwise. May be hard to find but inside the controls panel where light and thermostat are located look for a small opening or plastic plug about the size of a pencil. Turn the timer by putting pencil eraser or something big enough to turn it until you hear a click and the refrigerator stops running or if the refrigerator compressor begins to run. Let me know, Thanks Sea Breeze
Mar 24, 2009 | Frigidaire FRT21S6A Top Freezer...
Viking microwave has digital lights but will not turn on to cook?
Hi the problem will be with the touch panel membrane or the controller. if yoiu can hear a click when the start button is pressed then the touch panel is OK asnd you should look at the controller which can be replaced as a unit or if you are up to it it's probably the main cook relay that has failed.
Jan 29, 2009 | Viking DMOC205SS Microwave Oven
Oven stops after a few seconds
I like the information you give.
If the unit will work with the control Panel at a 45 degree angle it tells me you have a loose connection. The 45 degree angle puts enough pressure on the connection to keep it completed. With the Control Panel in it's normal position, the loose connection Heats and Opens the connection. After it cools connection is again made until it Heats up again. Remember Expansion, Contraction. I do not believe you have a Magnetron issue!! A Magnetron does not know if the Control Panel is at an angle.
Can you hear a slight "Click" when the unit shuts down? If so this is a relay opening. When you say you replaced the Control Board. Was this the Control Panel PC Board, or was it the Cook-Relay Control Board? A Door Switch not making solid contact can do this. Is your Door latching down solid? Check for loose connections, not open LOOSE.
Jan 27, 2008 | GE JVM1650 1000 Watts Microwave Oven
Kitchen Ranges Logo
35 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
