Question about Epson STYLUS R350 Photo Printer
Epson r350 printer does not print thick paper or inkjet paper
Please help me this.
My epson r350 printer can only print thin paper. If i use thick paper such as inkjet paper(card paper), it dones not pick by pickup roller.
Please help....
  • grace zalewski
    grace zalewski May 12, 2014
    wkhy not the card paper never happened before does anything with window 8 have anything to do with it
    Problem Solver:
  • 15 Answers
Hi, this printer is "clever" in that you don't adjust the thickness setting it does it itself.
It does this based on the paper type you set in the printer properties, see the table below for the different types of paper it will accept & the setting you need to use.
For this paper Select this paper type setting Plain paper, sheets Epson Premium Ink Jet Plain Paper Epson Bright White Ink Jet Paper plain papers Epson Ultra Glossy Photo Paper Epson Ultra Glossy Epson Premium Glossy Photo Paper Epson Premium Glossy Epson Premium Semigloss Photo Paper Epson Premium Semigloss Epson Glossy Photo Paper Epson Glossy Epson Matte Paper - Heavyweight Epson Double-Sided Matte Paper Epson Matte Epson Photo Quality Ink Jet Cards Epson Photo Quality Ink Jet Epson Photo Stickers Epson Photo Stickers Envelopes Envelope
Hope this is of help.
Posted on Jun 01, 2009
  • eazy_finity Jun 08, 2011
    shamoo!! this one freaking works well!! i just need to initiate a little push but he feeding did differ when the settings changed.. thanks a lot man!!
Why won't my Epson WF-7620 print on thick paper when fed from the rear slot
Are you setting the printer to A3 when you hit print? When you select print you will get a on screen box where you can change options and then confirm by clicking print. Most printers are set to default legal size.
Aug 07, 2016 | Epson WorkForce WF-7620 Wireless Color...
R320 printer won't print on thick photo paper anymore. Regular copy paper works fine. Are there rollers or sensors that I can get to so I can clean and check? Is there a fix for this problem?
  • Make sure that the paper meets paper specifications of the product.
  • Spray compressed in air.
  • If it is a non-Epson brand paper, try Epson paper
  • Make sure that settings are setup properly, Some Epson products have a Thick paper and envelopes or Thick paper to allow it accommodate thick media
Feb 14, 2013 | Epson STYLUS R230 InkJet Photo Printer
I cant print on white vellum paper on my epson stylus nx420 i need to print some invitations and it is just folding my paper
Try placing some standard paper behind the vellum paper, it might assist in holding correctly while printing.
Being so thin the paper I would guess is folding up under the print head? if so look through all the printer properties, under the maintenance section there may be a "set Plattern Gap" (set to wide) or "Thick Paper Setting"
Selecting these raises the print head up to allow for thicker paper to pass through, but can also help thinner paper from folding up under the heads.
I hope one of these works for you.
Regards GM
Apr 12, 2011 | Epson Stylus NX400 InkJet Printer
What does H mean when I try to print on Epson CX4800 printer?
Your paper thickness level is set to H for envelopes. Rest to L for paper printing.
Hope this helps
* Please rate this solution with Thumbs up and Testimony to help us improve providing support
Dec 15, 2010 | Epson Stylus CX4800 All-In-One InkJet...
Printing thin black and blue lines across cd
my epson stylus photo r350 prints, but it has a line
Oct 02, 2010 | Epson STYLUS R350 Photo Printer
Epson stylus c87 plus only feeds thin paper why?
Good day!Try mixing thin and thick paper..see if it still choose thickness..
Mar 26, 2010 | Epson Stylus photo C87 InkJet Printer
Epson Stylus R350 in Custom Big Paper
in printer properties, specify the paper size, and or demand for the print to fit paper size, in the printer properties
Mar 22, 2010 | Epson STYLUS R350 Photo Printer
I was printing on a A4 thick (invitacion Card)
Make sure there is 1/16 to 1/32 inch space on each side of the paper in the paper tray.
Move the paper type selector back and forth 5 times, to make sure it is not stuck.
Feed the tray with a minimum of 20 sheets of paper and try to see if it loads paper through.
The paper thickness lever has two settings, one for plain paper, (thin paper 20# to 24#) and one for envelopes and thick paper.
It should be on the 0 setting for thin paper and on the + setting for thick paper and envelopes.
The paper adjustment lever may be adjusted in between the two settings to accommodate paper that is not standard or that the operating/environmental conditions have changed.
Make sure the paper is loaded far enough into the printer to ensure good contact between the paper and the paper feed mechanism.
Dec 05, 2009 | Epson Stylus Color 600 with GT-5500...
Printer won't accept Card Stock
Nothing to adjust feed mechanics. If it's temporaly print, you must feeed paper 1 by 1, and when printer grab paper, push paper by hand. If it's routine print, you can adjust the pick up rubber at paper feedr mechanic. Add double tape ( 1 mm, soft) below top rubber. I have done it, and printer can grab/feed paper up to 350 grams.
Jun 29, 2009 | Epson Stylus CX5400 All-In-One InkJet...
EPSON 1280 SILVER INK JET PRINTER, Stopped printing on glossy
Problem with paper feeder. Replace paper feeder or replace just pick up rubber at paper feeder mechanics. You can add thickness of rubber by adding black double tape (flexible) (about 1mm).
Jun 15, 2009 | Epson Stylus 2200 InkJet Photo Printer
Epson STYLUS R350 Photo Printer Logo
1,567 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
