Question about Maytag MDE2600 Electric Dryer
Periodic high-pitched whine from Maytag Electric Dryer
I have a relatively new (~1 yr old) Maytag electric clothes dryer. Recently it has started making a very high-pitched noise which lasts for 3-4 seconds, and then goes away for several minutes, only to come back again. It doesn't sound like a belt squeal -- it's more like the noise an old camera flash used to make while charging. Very high pitched. The dryer otherwise seems to be working fine. Any ideas? the dryer makes an alarming sound before or when the cycle ends. Is this normal?
4 Suggested Answers
hunter19_46m
  • 7482 Answers
SOURCE: Maytag Dryer model#MDE6000AYW makes a high pitched
ALWAYS UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS
Your problem sounds like drum rollers have flat spots on them or in need of lubrication, or maybe your drum belt has slipped off of the idler arm pulley.
If you have a front loading machine, Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer. Be REAL CAREFUL not to knock any of the wires off of the timer switch. Then remove the top of the dryer. Remove the front of the dryer. This will expose the drum and belt. Remove the drum and belt and this will expose the drum rollers, idler arm pulley and motor. Now is a good time to check the belt to see if it has slipped off of the idler arm pulley and also to check the belt condition for wear. Be sure to note the route of the belt, this will come in handy when you go to reinstall the belt. Check your drum rollers for flat spots or wear, if they have flat spots or wear on them replace them. If the drum rollers don't have flat spots or wear on them then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve your noise problem. I will include these two websites for parts and further help: http://www.partselect.com/ http://www.appliancepartspros.com/index.aspx Both also have chat assistance 24/7. I will also include this website...it has the breakdown of the drum and rollers plus parts and prices:http://www.partselect.com/ModelFrames.aspx?ModelID=123926&ModelNum=MDE6000AYW&mfgModelNum=&ManufactureID=1&Selected=51311&Position=6&mfg=Maytag&Type=&Mark=6
Good Luck, I hope this helps Please rate me, Thank You
Posted on Jan 05, 2010
marka19
  • 1430 Answers
SOURCE: Maytag MDE5500AYW 220V Electric Dryer. Makes a
Your dryers uses rollers or wheels to support the clothes drum. When these rollers are worn, they can be noisy. You should replace the whole set of rollers at the same time. Idler pulley your dryer has a tension or idler pulley that keeps tension on the main drive belt. When it's worn, it can be noisy. When that happens, don't lubricate it. Just replace it. Rear drum bearing. There are videos of the testing and replacing of these parts at www.appliancehelponline.com/servicemanual.html this will walk you thru the troubleshooting and replacement of these parts Blower wheel Your dryer's blower wheel pulls air over the heat source, through the clothes drum, and past the thermostats, then pushes it out the exhaust duct. This brings us to the last problem could be the blower wheel, which is usually plastic, may wear out over time.To check this grab the wheel and see if theres any play . But if it's noisy, it may simply be clogged with lint. Clean the blower and test to see if the dryer is still noisy. If it is, you need to replace it. If you need diagrams or illustrations of your specific model you can also enter your model # there.
Posted on Mar 31, 2010
Testimonial: "Good advice fast. Thanks very much."
  • 14 Answers
SOURCE: Maytag electric dryer is making a high pitched noise
Maybe your problem is coming from the bushing shaft part. Mine was so used that it made a terrible and high pitched sound.
Try to look behind your machine, remove the part hidding the bushing shaft and check if everything is ok.
My bushing shaft was make of metal, and I replaced it with a teflon one. Everything is working fine right now.
Have a good day.
Posted on Sep 13, 2010
Clothes Dryer makes high pitched sqeak
Most driers have to be disassembled from the back and work your way forward. Try that.
Feb 03, 2014 | GE DCVH480EKWW 4.0 cu ft electric dryer
The electric dryer will heat up to dry the clothes but it has a high pitch noise when you start it and periodically during the drying time it will make that sound. At first I thought it was the belt but...
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Aug 25, 2011 | Maytag Dryers
Hi. My Neptune dryer was not sounding as I remembered it. A higher pitch than usual while it was drying clothes. Then I noticed it was reluctant to start when pushing the "start" button, with...
burning smell is because the drum is not rolling and the motor is trying to turn, hopefully it did not damage the motor: more then likely it the drum rollers/glides, might want to check the idler arm here is a website that will help. depending on fast you need your dryer a good and cheap place to buy parts is on eBay, of course they can be purchased locally, Good Luck Tim:
http://www.partselect.com/dryer+dryer-wont-tumble+repair.htm
http://www.partselect.com/dryer+dryer-tears-clothes+repair.htm
Jan 10, 2011 | Maytag Neptune MDE5500AY Electric Dryer
Maytag dryer will not start. The light comes on when the door is open, but when the door is closed and we push the button, it will not start. The dryer is about 1 yr old.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer is not Turning
Dryer Repair - The
heatman101
Dec 30, 2010 | Maytag PYE2300AY Electric Dryer
The squealing noise is from the belt tensioner. Replace the pulley only on the tensioner along with a new belt. The bearing in the pulley is causing the squeal. Sears will sell this in a kit. The top and the front panel of the dryer will have to be removed to replace these parts
Jul 16, 2010 | Maytag Dryers
High pitch squeal-metal on metal contact
A lot of dryers have plastic or felt slides on the drum. This is to reduce friction as it rotates. They are probably worn off.
Dec 24, 2009 | Maytag MDE4806 Electric Dryer
We have a three year old Maytag electric dryer. It has started a high pitched whine. Still drys and tumbles. Venting works well. Suggestions?
maytag dryer's are also amana dryer's.that has a main bearing in the back of the unit.this is the first indacation that your main bearing is going bad,.do a service call now and save your dryer.
Nov 16, 2009 | Maytag PYE2300AY Electric Dryer
Maytag SE1000 Dryer - high pitch buzz, then total non-start
Often, after a power surge that exceeds the parameters of surge suppression devices on the circuit board, the unit will do this. You will more than likely have a failed control board now and will need to replace it.
Dec 03, 2008 | Dryers
Duet Dryer (GEW9200LW) Control Panel doesn't work (all the time)
WHAT IS WRONG WITH YOUR DRYER?
small_8_19.jpg For a detailed Dryer illustration, click below.
Gas Whirlpool Style Version 1
redarrow.gif Gas Whirlpool Style Version 2
redarrow.gif Gas Maytag Style
redarrow.gif Gas GE Style
redarrow.gif Electric Whirlpool Style Version 1
redarrow.gif Electric Whirlpool Style Version 2
redarrow.gif Electric Maytag Style
redarrow.gif Electric GE Style
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
Gas dryers aren't very complicated. Here are some common symptoms you may experience with your dryer.
There's an error code on the digital display
It doesn't work at all
There's no heat
It won't tumble
Drying is too slow
It overheats
It seems to run forever
It's noisy
It won't start
The light doesn't work
My clothes smell bad!
My clothes are marked or torn
Hope this may help;
DON'T FORGET TO RATE
Aug 25, 2008 | Whirlpool GEW9200L Electric Dryer
Dryer won't start
/WK, sounds like a thermal fuse. Pop the top of the dryer by pushing on the clips in right and left front top. In the back you are going to see the heater and on the right side about 4 inches down a small thermal fuse. You can ohm it out or jump it to verify that is the problem. If you jump it, don't leave it that way, it's a safety device. Part number for fuse is LA 1053, Catriver..post back.
Aug 17, 2006 | Maytag PYE2300AY Electric Dryer
Maytag MDE2600 Electric Dryer Logo
127 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
