Question about Philips 42PF7320A 42 in. Plasma HDTV
Black vertical bar about 4 and a half inches wide down center of screen
I have a black vertical 4 and a half inch bar right down the center of my TV screen. My model number is 42PF9630A/37 Please advise.
  • jcarabillo Jun 01, 2009
    Do you think it's worth contacting a repair person - would this be an expensive repair?
    Problem Solver:
  • 10 Answers
Your display is bad you have vert and horz ribbons on top or bottom and on right and left side of display the prob most likly is bad display but could possibly be a bad connection on ribbon
Posted on Aug 12, 2009
  • 744 Answers
Hi...
It sounds like an Intergrated Circuit (IC) has fried.
Your best bet in this situation is to contact ur tv service operator and let them recommend an authorized service center in your area....
rate me!!
Posted on Jun 01, 2009
  • Prakash Ram
    Prakash Ram Jun 01, 2009
    hi..
     yes its a costly repair. but there is no particular reason for this vertical lines problem in ur tv... a technician will identify and do it for u...
How to fix Westinghouse WD32HD1390 tv when black vertical bar show up on display?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Aug 19, 2017 | Westinghouse Televison & Video
42 inch philips plasma HDTV vertical bar on screen
does the vertical lines appear like solid vertical bard infront of the pictire??
Jul 08, 2008 | Televison & Video
Black Vertical Stripe Our Hitachi plasma TV has just started displaying a vertical black stripe about three inches wide right down the middle of the screen. This stripe comes and goes every hour or so,...
try doing white wash feture in options see if u can get it out this way 1st before having to take aprt cheak cables are using old style sumtimes they do get glitch do factory reset thx for using fix ya . nick
Feb 03, 2008 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
A black line running verticall down the middle of
There is no invertor board on a plasma tv. The fault is the X address buffer board. This is located on the bottom of the screen and runs horizontally the whole width of the screen. If you remove the heatsink plate that covers the x address boards and you need to look at the screen ribbon at the same position as where the bar is (in the middle).Vary gently lift the Xbuffer ribbon lock and gently take out the ribbon.Clean the contacts very carefully with a fibre pen or an electrical cleaning fluid.Insert ribbon back and heatsink and check.Here is a picture of the board and ribbon
a 1 inch bar is associates with 1 ribbon fault. So if the bar was 3 inches in from the left of the screen, the faulty ribbon will be 3 inches in from the right working from behind the TV. If cleaning dont cure the fault, then the Buffer IC will be blown and order a new centre buffer board (you can buy off Ebay)
Feb 17, 2010 | LG 42PG20 42 in. Plasma HDTV
How to center a screen?
Horizontal centering is performed in the service menu. Beware! You can mess up a lot of stuff in this menu.
Aug 02, 2009 | Toshiba Televison & Video
Vertical black bar down the middle of hitachi plasma tv
Ok if your hitachi TV dies with no power anywhere try this:
Some models have a kill switch under the bottom edge. It's like a gray switch like a small light switch press it back in and voila let there be LIGHT. Saves you at least a $200 trip to repair shop!!
Jan 05, 2009 | Televison & Video
Acer 2410 display having 3inches wide black vertical line at the right end
Hi...there,
The problems.. your panel are damaged. Don't bother to replaced...will cost you a lots of $$$.... It's time for retired...
Oct 14, 2008 | Acer Refurbished 11 3 STN LCD DISPLAY **...
Philips plasma tv vertical black stripe
Hi
If there is no picture behind the stripe and the edges are well-defined, then one of the display driver ICs has failed. Philips displays can be made by several manufacturers - usually Samsung. The ICs are bonded to the flexible ribbon in most cases, and replacement is an expensive specialist job - and in many cases is simply not possible.
A shadow on the picture is much better - usually due to interference.
Glyn
Jul 22, 2008 | Televison & Video
Ok did this happen the first time u turn on the TV. ? If so u might have a ribbon cable disconnect from the logic or u might have a defective Plasma panel. If u have a defect like your describing the IC's on the panel short out and no longer work causing that section of the screen not to function. Only fix then is replace panel
Apr 26, 2008 | Philips 42PF9630A 42 in. Plasma Television
Philips 42PF7320A 42 in. Plasma HDTV Logo
869 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
