Question about Impact Photography
Impact 3218 Light stand repair part needed
I have an "Impact" tripod type light stand that needs a new primary locking lever.  It is the one that tightens the boom extension and has a large plastic lever for tightening.  The lever is missing the friction washer.
Any hope??
Alan
    Top Expert:
  • Impact Master
  • 46,069 Answers
Fixya does not sell Impact 3218 repair parts.
Posted on Jan 06, 2018
jcdill
  • 121 Answers
SOURCE: problem removing head from tripod
Look on the underside of the platform where you screwed on the head. It should have 3 small screws in it. These are tighened and loosened with a jeweler's screwdriver. You may have one screw that is just *barely* tight, so you were able to hand tighten the head until it "locked" into place with the screw. When you loosen each of these screws a few turns the head should come off.
If you can't locate these screws, or you can't remove the head, you will need to take the tripod to a large camera store for assistance. Their rental or repair department can help you remove the head. If you need help locating a large camera store with a rental or repair department in your area, I may be able to help - I would need your location (e.g. city/state/country/zip or postal code).
Posted on Jan 01, 2009
SOURCE: Vivitar tripod V900 has a broken friction level
ok, never used this site before and not sure I know what I am doing. Did you get your tripod fixed? I have the exact same tripod but am no longer using it.
Posted on Feb 14, 2009
  • 685 Answers
SOURCE: Missing Tripod parts
Without knowing the brand of tripod i cannot help. There are some brands of tripods that are made for the retailer and the name is licensed, so the name brand does not support or stock repair parts. Especially if the tripod is an inexpensive one. Because of the model and make of you tripod, I would recommend you throw it out and buy another one. In my opinion Slik and Manfrotto are two very good ones. Slik for the lesser expensive and Manfrotto for the more durable, expensive, parts are almost always available unless is it really old tripod. Find some Manfrotto tripods at: www.BogenTripodParts.com
Posted on Jun 25, 2010
SOURCE: the tightening screw for the main pole of my
I had the exact same issue. I found a snapper tubing clamp at an aquarium store that works perfectly. Do an internet search on "snapper tubing clamp" or "snapper hose clamp", you'll find many suppliers. These clamps are good because there are many sizes, they are fairly adjustable, and easy to release. I set up the tripod, slide/attach the clamp on the main pole right above where the screw used to be and tighten the clamp until it doesn't allow any sliding.
You might also get lucky and find an adjustable tube clamp at a bicycle store or music store.
Posted on Jul 27, 2010
  • 48 Answers
SOURCE: Giottos VT 806 tripod
The long pan handle tightens and loosens front to back moves. Are you using it? If you are in the USA and need help call us at 800 735-4373
Posted on Oct 21, 2011
My camera is falling forward off tripod when I let go of it after a few seconds. I've tightened all the knobs and I need to fix this today..
Without knowing the make and model of the tripod and the type of the camera, I can only be general/
The camera may be too heavy for the tripod head. Heads are rated to hold so much weight. If the camera/lens combo is too heavy for the head. it will tip forward. Many department store grade tripods can handle only light cameras.
The locking mechanism may be damaged/broken.
If you need more info, please repost the question, specifying the make and model of the tripod and the type of the camera. If it takes interchangeable lenses, also include the make and model of the lens.
Dec 27, 2016 | Photography
Is there a "lock" position on on the 3 leg spread of this tripod?
-Providing that the image shown is the tripod you own..., the top leg lock levers on each leg is designed to lock the spreader angle of each leg.
-If this is not holding the leg at the correct angle...., either you are putting more weight on it than it was designed to hold..., or the 'cam' on the various locks has worn.
-A 'stop gap' fix for this problem is to insert a very thin wedge between the lever & the leg tube..., thus providing a greater amount of pressure on the tube, (this would need to be done every time the tripod is set up).
-Replacement parts are not available for this tripod & they were not designed to be user serviceable ...., sorry!!!
Peter
Aug 25, 2014 | Velbon Aef-3 Tripod
How do I connect a Manfrotto - 026 Swivel Umbrella Adapter (Lite-Tite) to a tripod?
Deborah
If you bought the Manfrotto #026 Lite-Tite new, it should have come with (2) brass adapters..., ((1) with male 1/4-20 & 3/8-16" threads & (1) with female 1/4-20" & 3/8-16" threads). All universal photo tripods made in the last 30 years use these (2) thread sizes. All you should need to mount this unit to a tripod is the 'female' adapter spud. If you are missing this item..., it is a Manfrotto #119 adapter (available through most photo dealers).
Peter
Jan 29, 2013 | Bogen Manfrotto 026 Swivel Umbrella...
The leg clamp on my tripod is broken i need to find a replacement
They were not made to be serviced. They were made to be disposable essentially, but you might contact the folks at B&H to see if they may have a solution.
Otherwise depending how it broke, it might be able to be cemented, or reconfigured to accept a different type of clamp. I had a no name type of tripod that required some caredul filing to restore a lip on a clamp so it would lock after the original lip snapped off.
Jul 07, 2012 | Dynex 60" Universal Tripod
How do you install the batteys in the stanley tripod legs?
To replace the batteries in each side of the 3-in-1 tripod light, you'll need to slide each light out of the central frame. Once each individual light is out on its own, you should be able to easily unscrew its bottom, giving you access to the battery compartment. Unlike the original Stanley tripod light, the actual tripod legs no longer hold the batteries.
On the original Stanley tripod LED light design, the black tripod leg tips simply unscrewed after you popped them out into the "stand" position. Much simpler to figure out.
Jun 25, 2011 | Stanley 3in1 Tripod LED Flashlight 95155
Impact 807 tripod
It costs 35 $ new.
If you put on e-bay don't expect more than 18$
Best regards,
PDG
May 10, 2010 | Impact 807 Tripod
Meade #882 Tripod locking cam the locking cam lever has broken off need to replace the cam.
Don't try to...buy a new unit it's cheaper...where are you from ...ALDI has a great unit for less than 15 quid... if you need help contact me and i'll organise ....
Oct 02, 2009 | Meade Field 882 Tripod
Need bottom section for 2 Bogen3218 monopods any suggestions
Individual parts (and the parts list) are availble from Bogen-
http://www.bogenimaging.us/Jahia/site/bius/cache/off/pid/14084
You can get the parts list from: http://www.manfrotto.com/Jahia/spareparts/site/manfrotto/cache/offonce
but the "search" doesn't seem to work when you put in the code (3218), so you may have to scroll thru the 1300 docs til you get to yours- are you sure it's a 3218- they don't show one, but they show a 3216
Aug 23, 2009 | Bogen Communication Photography
I need to buy a new tripod but it seems that everything I see online is either 57" tall or they don't list how tall it will get. I am 69" tall and don't like to have to bend way over to see through my...
I purchased a great tripod on ebay from a gal who has a million different types from tabletop to professional grade. Just log on to ebay and type in camera tripod and you 'll find dozens of suppliers with exactly what you want. Hope this helps.
Dec 31, 2008 | Celestron (93604) Tripod
Focal tripod
I have a Focal tripod model # 20-08-87 that is missing the quick release plate. I cannot seem to locate a replacement. Can you help me locate one??? Thanks, Jackie
Mar 01, 2008 | Sanford Traveler Tripod
Photography Logo
564 people viewed this question
Top Impact Photography Experts
pontelemon
pontelemon
TC CAMERA REPAIR.Com...
Are you an Impact Photography Expert? Answer questions, earn points and help others
