Question about Craftsman 42 in. Deck 19.5hp Lawn Tractor
Clicking noise lawnTRACTOR, WON'T TURN OVER, CAN IT BE THE COIL AND HOW DO I CHECK? mower wont start - replaced solenoid makes clicking noise
  • rjivaro May 11, 2010
    It sounds like a dead battery.
Removed engine cover - found starter was hung up, this seems to have fixed the problem it starts and runs fine now.
Posted on Jun 02, 2009
My truck won't start
Click means loose or dirty connection. Use a ohm meter, when turning ignition to starting. Should read atleast 12v Read voltage at big termial on starter. If no or low voltage. Check solenoid, both sides to proper voltage.
Mar 25, 2014 | Ford 8n,9n,2n, Tractor Starter With Drive
Craftsman Tractor solenoid clicks but won't start
could be a safety switch or a ground problem check the ground for corrosion and make sure it is tight at all places then check each safety switch they usually have one for the seat,mower deck and clutch/brake pedal
Jun 19, 2013 | Garden
I have a simplicity 1691931 riding mower with a new battery.it wont start.
check the wiring again possible bad -corroded positive line to solenoid or have a bad key switch -check the inline fuse to the solenoid
May 23, 2013 | Garden
When I try to start the car it makes a click sound and will not start. It only makes the click sound one time. I have changed the battery and replaced the starter and it still wont turn or even make a...
Did you also change the starter solenoid when you changed the starter? That is a possible cause.
Can you turn the engine over by hand from the crankshaft pulley to make sure the engine is not frozen or blocked? You will need a large socket to do that, but if you can't turn the engine over by hand, the starter won't be able to turn the flywheel either. The one click is probably the solenoid firing the starter piston to the flywheel but then nothing makes me think the engine is frozen in some way.
But if the starter and solenoid and battery is trying to turn a frozen flywheel, you should notice some drawdown of light intensity. Do you notice any change?
Jun 06, 2011 | 1991 Oldsmobile Ninety Eight Regency
Have probleming starting the 12hp riding mower change battery and check spark plug but still won't start. It makes a clicking noise.
sounds like the solenoid. take a screwdirver and with the key on place it on both posts at the same time if it turns over replace solenoid
Dec 24, 2010 | Craftsman Garden
My LA 125 riding lawntractor ( going on 3 years old ) stopped in the middle of mowing the lawn - the igntion only clicked when we tried to start it - we attempted to boost the battery - it turned over but...
hello there:
try replacing the coil on it this should solve the problem had same thing happened after researching i found that the coil was bad replaced it and have had no problems...hope this helps you out sincerely D.Jones
Jun 08, 2010 | Garden
Murray 18hp 42 deck wont start
Hi.
The best advice here is to put your battery on charge, and, while it is charging, remove each connection, and clean the terminals back to "bright and shiney". The clicking noise is probably the solenoid trying to pull in to provide power to the starter. There also sounds like the comnnection to the starter needs to be removed and cleaned. If this connection is dirty or loose, it can arc and smoke without cranking. Also, if the terminals at your solenoid are corroded, the motor cannot recharge the battery on the run, and loss of power to the battery will result. Clean your connections, and try again!
This should correct your issues. In extreme conditions, it may be necessary to replace your wire from the solenoid to the starter, if it is significantly deteriorated, but I'd clean it all up first.
Best regards, --W/D--
Aug 11, 2009 | Briggs & Stratton Garden
Husqvarna zero turn mower won't start
Usually if all you hear is a clicking noise, it is the solenoid itself that has gone bad...if you can jump the solenoid and the mower turns over, it is the solenoid.
May 01, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Craftsman 42 in. Deck 19.5hp Lawn Tractor Logo
409 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
