Question about Xerox Phaser 8500/DN Printer
Phaser 8500N Text looks like a shadow or an echo effect
Blurred output inter mitently. More like the first page then the rest that follow are ok. Text looks like a shadow or an echo effect. Text looks like a shadow or an echo effect. Does not happen to every page all the time. seems to come around in cycles. Or in the middle of that important job.
  • tompryts Jun 02, 2009
    Thanks tryit,
    This is the best idea I have had on what is causing this problem.
    How big is this encoder? I have some denatured alcohol from another job. Facing the printer is it on the Rt. side? My clean out tray locks in when power is off do the Matain. and clean out need to be removed before opening the rt side?
    President:
  • 2,072 Answers
There is an encoder on the end of the drum drive shaft. located on the right frame of the machine.
It becomes contaminated with the silicon lubricant from the maintenance kit, and off the rotating drum.
You remove the power from the machine, remove the encoder, and flush it thoroughly with alcohol. Then give it time to dry well, and put it back on the shaft. That WILL correct that problem. It is possible the encoder is bad, but I really do not suspect that because your problem is intermittent. But that is your problem, I guarantee it.
Posted on Jun 02, 2009
  • Rick Kasper Jun 02, 2009
    Locate the drum opening then look for the shaft that runs to it.
    The encoder normally has a black plastic shroud around it and maybe 2 inches diameter.
    Once you locate the drum and shaft it is the only thing with wires running out of it.
    Yes, on the Right side, referencing from the front. I would guess just slightly less than half way back, almost mid way up on the machine.
    You can go to Xerox.com and look at documentation on 8400, and I think 8500 printers as a reference. Pretty much the same style encoder.
  • Rick Kasper Jun 03, 2009
    I am 99.99999999999 percent sure once you get the encoder clean your problem will be resolved. What happens is the silicon from the maintenace kit causes the encoder to speed up the drum whenever it feels like, causing intermittent blurring. Happens often to that product.
    What you want to do with a phaser printer, is to be 100 percent sure it is sitting level, take a level and place it on top of the printer, and be certain it is level both side to side and front to back.
    You can't believe how many problems you will prevent with that printer simply sitting level.
    Good luck. Let me know your result ok.
    If you need to replace the encoder, call 1-800-835-6100 and press the prompt for parts support. I doubt you will have to replace it.
Toshiba 46XV645U Shadow Effect Problem
thats usually caused by a flex tab bond on the panel itself especially if the screen appears slow motion in that area.
Aug 07, 2012 | Toshiba 46XV645U LCD TV
How to keep Phaser 8860MFP from printer the cleaning Page
Am using Phaser 8860 its a good printer but the problem am facing is that it is failing to clean the head or drum. The first testing page gets stuck on the head or drum. The drum is always dirt with colours of the first page. Kindly heal
May 07, 2012 | Xerox Phaser 8500N Printer
Xerox Phaser 7300 color misregistration
Apparently, turning the unit off for 30 seconds, then back on will force the Phaser 7300 to do a color alignment procedure (according to Xerox support).
Then, if the problem persists, you are instructed to follow a very detailed troubleshooting procedure which I will leave with you in the following link:
Xerox Phaser 7300 Misregistration Issues
I hope this helps!
Mar 15, 2010 | Xerox Phaser 7300DN Laser Printer
We have a Xerox Phaser 8500N printer. The yellow is printing out a dingy gold. I hav checked the yellow print blocks and there is plenty.
What it essentially boils down to is that you're not printing enough color. The blocks are melted into a holding bin and will discolor over time. To correct this, you will need to purge the color that is "stale". Go to this link http://www.solid-inks.co.uk/technical_support-phaser_850_860_8200.html?category_id=1 and download the pdf for your color (I would recommend downloading all four to keep on hand). You'll want to open the PDF and print 10 to 20 copies until the bad ink is replaced with fresh ink. You'll notice the color change as the ink is purged.
Jan 05, 2010 | Xerox Phaser 8500N Printer
Printer output has shadows, blurring, streaks, lines, poor color
Seem like blocked hole(s) on the color print head...
Most likely if there is a deep clean option then do it (may need a few times to unblock a hole or never).
Also get the printer physically cleaned up if you can see dusts inside (vrtical lines on color bars).
Mar 20, 2009 | HP DeskJet 9800 InkJet Printer
Xerox Phaser 8500N Printer Error 09,037.45:9085
You have to go into Diagnostics. Once in Diagnostics arrow down to function menu.
Then select
Then arrow down to ClearISCfaults hit OK
follow instructions on screen.
Nov 24, 2008 | Xerox Phaser 8500/DN Printer
5500 xerox phaser
Check the paper path for any and all debris. Use canned air to remove any debris. Also check the paper tray guides to see if they are matched correctly.
Oct 30, 2008 | Xerox Phaser 8500N Printer
Phaser 8550DN
dirty or sitting ink left on paper feed and ink cartridges makin first pages blured
try to clean with little rubbing alcohol
May 07, 2008 | Xerox Phaser 8500/DN Printer
Phaser 8500N color problem
There is a process called TEKCOLOR correction.
It is on the xerox.com site.
Search for phaser 8500 under the support, in support in the search area enter.
Solutions for Colors are Off or Wrong
This will take you through the process in the correct steps to resolve your issue
Nov 07, 2007 | Xerox Phaser 8500N Printer
I can't get rid of the margins when i print something
I'm guess you are printing from MS Word? Click File the "Page Setup" Click the layout tab the far right then go to the bottom and click borders and select the NONE option. You should have your borders removed!! =) That is if that is the type of border you are talking about.
Cheers!!
Feb 11, 2007 | Xerox Phaser 8500N Printer
Xerox Phaser  8500/DN Printer Logo
348 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
