Question about Kenmore 74602 Gas Dryer
Sears Gas Dryer won't run
For a while my dryer would run thru the entire time on dryer before it or you had to open door to stop it. now it wont start at all when you push the start button.
  • 530 Answers
Sounds like you have a bad fuse. does yours have a kick panel? sounds like you have a bad timer and fuse.
Posted on Jun 02, 2009
Dryer won't turn off
won't stop automatically? = timer problem
won't stop when you open the door? = door switch
Feb 08, 2013 | Maytag Atlantis MDG8400AW Gas Dryer
Kenmore Dryer stop heating, is not warming up.
It sounds like the heater coil is defective. You can purchase replacements at Sears. They are not teriibly hard to replace but if you don't feel comfortable, Sears can install them.
Lou
Sep 24, 2008 | Dryers
(2007) Frigidaire Affinity Gas Dryer won't shut off
mybe the star button stay stuck and the dryer tinks some one is puching the star button and it will continio to run. try to open the door and it will stop and then clouse the door if the dryer star whitout pushing the star then you now the star switch is stuck. goo lock
Feb 21, 2012 | Frigidaire Affinity 5.8 Cu. Ft. Gas Dryer
Whirlpool Ultimate Care II gas dryer won't turn off.
Dryer Won't Stop Running
  • Ultimate Car II Dryers are fitted with a mechanical timer that sends an impulse to the control circuit board to stop running once the set amount of drying time has elapsed. This is because, should an electronic timer fail, this would necessitate the replacement of the entire circuit board. Confirm that the mechanical timer is indeed broken by opening the dryer's door. If the dryer stops, the circuit board is working fine and is not the problem. Simply slide off the protective faceplate of the dryer, unscrew the control board beneath, and flip it over. Connected to the back of the timer's knob should be a small round device with two wires running to the circuit board within the body of the dryer. Unscrew this device from the back of the knob and disconnect the wires. A replacement timer costs a few dollars and should screw into place without trouble. Reconnect the wires and put the dryer back together. It should work fine now.
  • If you need a new timer the best place ti get it is from Rough River Appliance Repair
  • Phone number is (270) 230-1818 his name is Charlie and he is the best!
Nov 16, 2011 | Dryers
My amana DLG330RAW dryer won't stay on. it has a combo timer and start dial turn the dial to the timed settinG and push...dryer starts part way through the cycle, the dryer...
Hello PB,
What i would most suspect as being the problem of why the dryer just stops randomly before the cycle is done,is a problem with the door switch or the door catch...does the dryer restart as soon as you restart it?? if yes i would check that the door catch was broken so the door will pop open stopping the dryer. Also check the door switch using a meter set to measure ohms and see if the contact is burnt ( a good door switch will be zero ohms resistiance)
GENE
Sep 17, 2011 | Amana DLG330RAW Gas Dryer
My GE DHDSR46 gas dryer won't start, what should I
505 is the thermal limit.
Looks like this:themobilian_2319.jpg
Hunt for junk and clean that out, then replace this fuse if it is bad.
See the white button to the right of the driver?
Thats the door switch, if open, that dryer won't run.
More Here
May 07, 2011 | General Electric DHDSR46GGWW Gas Dryer
Gas dryer won't heat with cover off
The 2 coils on the gas valve , need to be replaced . After the dryer runs for a short time , the coils get warm from the electricity going thru them . The weaker valve , shorts internally , not letting the gas go thru . After the dryer cools down , and the coils cool down , then the short will close ( giving continuity ) , until they warm up again . If you had given the model number , I would have given you the part number .
Sep 17, 2009 | Maytag Dryers
Dryer not spinning
it makes a humming noise..defective motor,,also you need to replace door switch...onthejob
Jan 10, 2009 | Kenmore 72802 Gas Dryer
Whirlpool imperial series 6 cycle/3 temp electric dryer wont heat
My dryer is not heating, where is the cupling at in the dryer i have it open tho
Jan 10, 2009 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Kenmore 74602 Gas Dryer Logo
63 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
