Question about Ricoh Aficio 450 Copier
Will not staple
Ricoh 450 was recently moved to a another location. After move and install, the machine will not staple. It makes an imprint as though it's trying to staple, but will not staple the papers.
    President:
  • Ricoh Master
  • 990 Answers
Hello sir; Remove the staple cartridge check there have left over used staplers , just dump it out,also need to check vertical lifting motor moving smoothly.
Posted on Jun 01, 2009
When firing machine ricoh 551 immediately get an error SC124. I took off the engine scanner, scanner plate and main board power, all joined to another machine and everything is correct and working. In what...
tell me more please did machine do main scan or no and this proplem belong to hp sensor check built of scanner move or not possible causes 1-Harness between the SBCU,
scanner motor drive board and scannerm motor diconnected
2- close machine and unplagged all harness and plagged again and notice some in home position sensors
Feb 12, 2011 | Ricoh Aficio 450 Copier
I have recently move a Ricoh Aficio 250 from 1 location to another. Once I turn the copier on at the new location, a "Clear Misfeed(s)" message appears without giving a zone(s) (usually denoted by a...
If the copier worked fine before you moved it, you may have blown a fuse or damaged a board. Your best bet is to have a service technician take a look at the machine.
Before you call them, however, did you turn the machine off and unplug it, and did you open and close all of the doors and covers? It may just be a door that isn't closed all the way.
Aug 02, 2010 | Ricoh Aficio 250 Copier
How do I change the staples in the bizhub 200?
If you have the finisher pictured above: If the machine is asking for staples, press "Finishing" on the panel then "Add Staples" this will move the staple unit to the front of the finisher. If the machine is not asking for staples but is not stapling paper then you may have a staple jam. To get the staple unit out: Open front door of finisher, Locate green turn wheel (this is horizontal in bottom left of finisher front door and is connected to white gears) turn this green turn wheel and the staple unit will be moved to the front of the finisher. Remove blue staple cartridge and remove the staple jam. After you reinstall the cartridge into the staple unit just close the finisher door and the unit will move back to home position on its own.
May 13, 2010 | Minolta bizhub 200 All-In-One Printer
My Savin 2527 won't turn on. I recently moved it to a new location, and shut it down normally. When I attempted to turn it on at the new location it did not turn on. I waited a few seconds and turned it on...
SIMILAR PROBLEM AS RICOH 2027/1027/1022/270
THIS IS DUE TO TERMISTOR PROBLEM.UCAN E MIAL ME HOW TO CHANGE THE TERMISTOR IF YOU KNOW THE TECNICALLITY.
Mar 16, 2010 | Office Equipment & Supplies
I need to change staples
Jan 06, 2010 | Minolta bizhub 200 All-In-One Printer
I have a Ricoh Aficio and I cannot find how to use the stapling feature.
Are you sure it has stapling?
Some machine may show it on the control panel but it is an option that may or may not be installed.
Is there a stapler in the sorter?
If it does, then the stapling should come up as a finishing option when making copies.
On your control panel, there will be a Sort, Group and a Sort/Staple option.
Select this feature and it should staple your copies.
If you select this and it doesn't staple then it may be out of staples or the copy is not the correct size or orientation to allow stapling.
Apr 15, 2009 | Ricoh Office Equipment & Supplies
Ricoh Aficio 450
Its coming from your finisher. Its a stapler error. Make sure the cartridge is in all the way. If you open the door make sure it is parked in the home position for you to access it.
If you changed the cartridge recently, make sure it is inserted all the way.
Jul 17, 2008 | Ricoh Aficio 450 Copier
Ricoh Aficio 450 copier
Wrench means "call for service" More information may help Ed
Jun 14, 2007 | Ricoh Aficio 450 Copier
Ricoh Aficio 450 Copier Logo
176 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
