Question about Samsung HCN4727W 47" Rear Projection Television
Power light comes on and blinks then tv shuts down.
I am currently having the same issue as another member (Pserrano) with the same model tv. I have copy and pasted his question below.
   "My television will not turn on.  If I plug it in, or press the power button the red led lights up 10 times.  Every other blink is slightly longer the the other.  Are you familiar with this problem?  Thanks you in advance for your help."
Thank you for your time.
Jerrelle
  • 2 more comments
  • beniah Dec 24, 2007
    having the same problem wont turn on , need to know what part to change
  • dziekan7 Mar 26, 2008
    I am having the same problem with my television. Thanks for the advice...
  • Anonymous May 12, 2008
  • Anonymous Jun 12, 2008
    TV will not come on, just the blinking red light. We have replaced the STK chips, but there is no change.
It is a board convergence ic
Posted on Jan 06, 2008
Panasonic 46" Plasma hDTV power light keeps blinking...in excess of 60 times. Power comes on then shuts down again then the red light blinks. I changed the power board and the same thing happens.
Hello, If you will look the power light blinks in a pattern. depending on the model number it has either a bad "SS" or "SN" board in it, it's the board on the right side looking from the back. This is a common issue with these sets....tks
Dec 31, 2014 | Panasonic Televison & Video
Power in house was shut off today, when restored, the timer led light by the power switch has been blinking constantly and the power to the TV will not come on...
Thats a common issue for that model which is caused by weak DM capacitors. When the power is down the caps discharge then they cannot recharge when power is restored and the led blinks non stop. Thw WS48511 - WS65511 DM repair kit from www.tvrepairworld.com has the caps and the repair instructions which usually solve that issue.
Aug 04, 2011 | Mitsubishi WS-55511 55" Rear Projection...
The red light to the left blinks. The tv will come on but will shut off and then the light blinks. The right power light turns green but the left doesn't. HELP!!!!
It's the problem of overheating in the power supply board of the TV.on the power supply board of the TV there are few capacitors and IC.any of this ic is got short or may be weak.so due to this when you start the TV the current passes from electric outlet to the power supply board of TV.but when the current passes from that weak/faulty part at that time current gets stopped or slow and the board overheats and TV shuts off. this is a common problem faced by many other users too.the possible option to solve this issue is to check the power supply board by a meter and continuity tester and replace the faulty component on the board which is short due to which power supply board is getting overheated.its bit technical job but yes its not at all a costly repair to do or get it done by the technician. for required parts it can be easily available from local electronic hardware shop.
I hope this will help in solving the problem......
Jun 09, 2011 | Supersonic SC-491 7 in. LCD SDTV
Television keeps shuttting off and on green light appears
I have a Sony Grand Wega 55 HDTV, Its 6 years old. Problem is as follows: I press the power button and the TV warms up and goes on for about 30 seconds than shuts off to a no power screen , with the power light flashing green. Than after about 60 seconds the TV comes back on for about another 30 sec and shuts off again. The longer i leave the TV on the longer it stays off when it starts blinking the green light. Can anyone tell me if its the sensor or something else? Is the part I need attainable with the ability to replace it myself.
Look forward to your replies.
Louie
May 20, 2011 | Sony Grand WEGA KDF-55XS955 55" Rear...
About a week ago it started shutting off i could unplug and plug in again and it would work now i get sound and red screen for a few seconds then shuts off and power light blinks
this sounds like a bad picture tube as it is shutting down becausethey may be drawing too much current fairly common issue with these older projection tv sets
Feb 19, 2010 | Televison & Video
Hello, We have the Panasonic project TV (PT-50LC14). We purchased a new bulb this past July. We're now experiencing problems with the TV. After turning it on for less than 5 minutes, the TV shuts off. ...
Hello well this kind of problem all the time is because you have a fan problem and you could have dirt inside of your tv and sounds also like a ballast problem i have this issue also and I got connected on the live chat that a web say has that they call discount-merchant they sell parts and lamps for TV they could help you they help me twice.
Regards
Jan 01, 2010 | Panasonic PT-50LC14 50" Rear Projection...
Red light blinks 9 times on Panasonic TH-42PZ77U
hello, panasonic plasmas have a safety shut down circut to protect the main panel when a short is present or internal circut panel is non functional some info i found in the service manual for 10th generation plasma
if your tv is still under warantee take advantage of the pany free service other wise it is a matter of exchanging the defective board then you will need electronic skills for this repair if you plan to do it yourself. it would be wise to have a skilled tech check it out and give you a estimate there are some techs that will come out and check it for free and give you a repair price.
here are some repair manual tips for blinking panasonic .. i didnt find 9 blinks on this manual i may be using a different manual but these are panasonic plasma blinking fault tips for 10th gen
becuase all models have different blinking codes you may need the model specific service manual
for 10th gen model some models 2008,2007,
8 Blinks SOS:
Pin 91 of the MPU IC9003 monitors the status of the SS board. During normal operation, pin 8 of connector SS23 outputs a low to pin 91. If the SS board becomes defective, a high is provided to pin 91. As a result, the unit shuts down and the power LED blinks 8 times.
9 blinks panel config sos
10 Blinks SOS:
The SUB5V and DT9V sources created on the A board are monitored by IC1100. If they are not present at pin 30 and 34, the MPU shuts down the unit. The power LED blinks 10 times.
10 Blinks SOS:
The F_STB_15V of the P board, as well as the derived SUB5V and DT9V sources are monitored on the A board for excessive current. If a short circuit is developed in one of the supplied lines, pin 114 of IC1100 receives a high. The SUB5V and DT9V lines are also monitored for excessive voltage. When an over-voltage condition is detected, a high is also output to pin 114 of IC1100. The DT9V is provided to a DC/DC converter to create the BT30V for the tuner. If the BT30V becomes excessive, a high is output to pin 114 of IC1100. A high at pin 114 of IC1100 causes the unit to shutdown and the power LED to blink 10 times.
hope this helps..
Nov 20, 2008 | Panasonic TH-42PZ700U 42 in. Plasma...
42" panasonic viesta plasma tv cuts off after about 30 minutes
Hello gws51,
This sounds like a shutdown circuit proble, which is caused by the draw of excessive current. I would suggest that you have a qualified TV repair person look at you set and repair it.
I hope this helps
Thank you,
Shuttle83
Jul 16, 2008 | Panasonic TH-42PX75U 42 in. Plasma...
Monitor goes off and on by itself
Hello bjaykaye,
The problems you are having are an indication of a Power Supply problem. The issue could be in the switching power supply or the High Voltage Power Supply. The shutdown circuit is activating which is allowing the TV to play until it detects an over-current event. When an over-current event happens the shutdown circuit will turn the TV off. I would suggest that you check the Horizontal Output Transistor, the HV Transformer, the Horizontal damper diode, and the capacitors that are in parallel to the damper diode. The important thing is to find the component that is causing the problem. If you do not have a background in electronics I would suggest that you get a qualified electronics technician to look at the set.
Thank you,
Shuttle83
Oct 29, 2007 | InFocus ScreenPlay 61" Rear Projection...
Samsung HCN4727W 47" Rear Projection Television Logo
112 people viewed this question
Jerry Greenberg
Jerry Greenberg
Demonic-2011
Demonic-2011
