Question about Haier Washing Machines
Error message 7
My machine says error message 7 don't know what the problem is i've lost the manuel
  • 10,515 Answers
HOW TO FIX ERROR 7 PROBLEM!
This problem is quite common on these machines, especially just after the machine has been moved. As a previous poster has said, Err 7 is a motor error. It is usually because the electrical connector has become detatched from the motor. Here is how to fix it.
  • First of all, PLEASE unplug the machine from the wall socket! And switch off the water supply too!
  • Pull the machine out from under the counter, and turn it so that you have access to the back of the machine.
  • Remove the 3 phillips screws that secure the back plate. You are only removing the small plate immediately behind the drum, not the whole back panel!
  • Look through the hole you have just created by removing the panel down towards the bottom of the machine. You will see the motor. Hopefully you will also see a 7 way connector not connected to anything, and a 7-way socket on the motor! (7 way means that it connects 7 different wires!)
  • Plug the connector back on to the motor. Don't worry, it will only go one way round, so you can't get it wrong. If the connector looks like it is connected, give it a little wiggle and a push to make sure it is fully home.
  • Replace the the small back panel, taking note that the top of the panel goes BEHIND the main back panel, and the bottom of it goes IN FRONT of the main panel. (This could be the other way round, I can't remember!)
  • Push the machine back under the counter, making sure that it is level (level it up by turning the 2 feet at the front of the machine until it doesn't wobble), reconnect the water and plug it in to the electricity supply.
  • Turn the machine on and attempt to operate the machine. (Top Tip: Select the wool or quick wash to test the machine, otherwise you will have to wait 3.5 hrs for the machine to go through a cotton/linen wash! Unplugging the machine won't help, because it remembers where it was when it gets a power cut!)
Thanks for using "Fixya".
Posted on Jun 01, 2009
I GET A "DRUM ERROR" MESSAGE... I'VE DON EVERYTHING... KEEPS SAYING... "DRUM ERROR." ALMOST NEW UNIT. WHAT?
Description HUM sensor failure Causes 1 Harness connection failure of THM/HUM sensor. 2 THM/HUM sensor failure. 3 Engine PCB failure.
Jan 02, 2015 | Brother MFC-9840CDW Laser Printer
How to change message n answering machine
Enter the model of your VTech system into the box at http://www.vtechphones.com/support/general/manuals to download a copy of the manual.
Jan 26, 2014 | Vtech Lands Phones
I've tried backing up my computer ...but I get a message everytime Error: back up failed. What can I do before my computer crashes?
Don't use the pre installed backup software, just grab an external HDD or a second internal HDD and do it manually.
Jan 29, 2012 | E-Machines eMachines Desktop PC
Eliminate a channel or restore one. I've lost the manuel
Hello
What is the Brand Name and Model Number of you Standard TV?
Jan 04, 2012 | Televison & Video
Hi there, I just purchased a Jura S9 One Touch. I've used it for a week, maybe making 10 coffees/day. Just yesterday an ERROR 6 message popped up. I don't know what to do, please help?
Hi, Error 6. Haven't come accross that one before. It sounds like brew unit problem.I do know error 7&8 are brew unit problems and 1 to 5 are water flow and heating errors. Try turning off the machine at the main power button and unplug it from the wall for a few minutes. This will reset the machine and right it self. They can do this from time to time. Dazza
Sep 23, 2011 | Jura Capresso Impressa S9 Coffee...
I lost my manuel and don't know how to record a
Select the model of your phone from the list beginning at
http://www.uniden.com/owners-manuals/dect-phones/scat/dectphones_mnl/
Jul 09, 2011 | Uniden DECT 6.0 Cordless Phone
I only have 7 pictures on here. I've tried taking the memory card out but still get the message that the memory is full. Don't know what else to do. Help
Check whether the sd card has the 'lock' switched on. Its a physical slide button on the side of the sd card which may sometimes cause this error. Thumb me up if I helped. :)
Jul 02, 2011 | Kodak EasyShare M853 Digital Camera
Lost sparepart
It is called a bobbin case and most sewing dealers will have this one. It should be a standard case with a finger sticking up from the top. If you have metal bobbins they probably have a lot of holes in them.
sewman7
Mar 19, 2009 | Sewing Machines
E90 on Front load washing machine
E 90 is an error code regarding the main pc board connection.
the solution is to secure all connection to and from the main board.
tighten the sockets and make sure they are not loose that could create a problem while vibrating and shaking.
tnx 4 using fixya,
drcool
Sep 24, 2008 | Frigidaire ATF6000ES Front Load Washer
Washing Machines Logo
126 people viewed this question
Top Haier Washing Machines Experts
Gerry Harvey
Gerry Harvey
Owen Barnes
shaun taylor
Are you a Haier Washing Machine Expert? Answer questions, earn points and help others
