Question about Kohler 3386-6 Rialto Skylight Round Front Toilet
Running toilet My one piece Kohler Rialto round front toilet is "running" all the time. It's NOT a flapper problem rather the water fills after flushing but continues to trickle resultng in water filling noises.
  • sanibelsal Jun 01, 2009
    $7.99, a little "learning curve" but job done -thanks!
  • 24 Answers
Mine does that also, here's what I found.; I am on a well and occasionaly sand gets caught in the valve thingy... Take the tank lid off, turn the arm that attaches to the float assy. 1/4 turn towards the back of the tank and take it out. Rinse off the gasket and pin as well as inside the hole. Reassemble and it should solve your problem.
Posted on Jul 04, 2009
    President:
  • 1,902 Answers
You need to replace the float system. This will fix the problem will take you about 15 minutes and will cost you about 15 dollars to due it yourself. This is not the flapper, rather this is the float and the water inlet system
Posted on Jun 01, 2009
How to disconnect flapper on kohler k3386DA
You just need to slide the arms of the flapper while rotating away and upwards off the bars; the arms are flexible so they pull away quite easily.
There are some illustrated installation instructions on the Kohler site that may be helpful.
Go to: http://helptopics.us.kohler.com/ics/support/default.asp?deptID=5712
On the left side menu click on Bathroom Fixtures; click on Toilets, click on next under the questions to move to question 18, How Do I Install the 84995 Flapper?
Mar 02, 2011 | Kohler K-3386-0 Rialto one-piece...
Not sure the model, but when I flush the handle stays down? This is happening on two out opf three toilets
Water pressure in the house may be to high and not allowing flappers to drop. check pressure and adjust as needed.
Jan 04, 2011 | Kohler 3386-6 Rialto Skylight Round Front...
I just installed a Kholer Rialto toilet and the water doesn't shut off, it keeps running even though the tank fills with water.
My toilet is running, how do I fix it? To solve this problem, you'll want to ask the following questions:
  1. Is water running into the overflow tube? If so, lower/adjust the float valve. By doing this it will float higher closing the inlet valve.
  2. Is the chain too slack or too tight? Make sure the chain has only 1-2 beads of slack.
  3. Has the water in the home or surrounding area been recently shut off for some reason? This could cause debris to come up through the water pipes and settle into the diaphragm seal of the fill valve. Flush out the diaphragm seal.
This is not an unusal problem; here is a video that may provide more assistance:
Dec 16, 2010 | Kohler K-3386-0 Rialto one-piece...
I have Kohler 3386-6 Rialto Skylight Round Front Toilet problem is that tank filling is very-very slow, perviously it used to fill in few seconds now it is taking 15 min. please let me know how can...
There is a screen @ the inlet to the vavle where the water connects that may be plugged or contact Kohler they will send you a repair kit for the fill valve.
Dec 12, 2010 | Kohler 3386-6 Rialto Skylight Round Front...
HOW DO I CHANGE FLUSH SEAL ON KOHLER ONE PEICE TOILET
The flush seal is the rubber gasket between the tank and the bowl. You do not have one. So I am guessing you mean the wax ring on the floor?? They usually only get replaced when the toilet is changed, unless you spring a leak. Or are you talking about the flapper inside the tank that holds the water till the flush lever is pulled? Get a new flapper, if it is just the flapper you need, otherwise you will have to buy the whole thing, all these parts are available at the hardware store. I think it is held on by a couple screws in there, might just be a press fit, we don't see too many one piece toilets. And the wax ring is about $2, but the toilet has to be unbolted from the floor and water disconnected, clean off the old wax, put on the new ring, smoosh it back down and bolt it back it up. Don't for get the water line. Check to make sure you have no leaks. Hope this helps.
May 23, 2010 | Kohler K-3386-0 Rialto one-piece...
New water valve makes ahigh pitched whistling
I had exactly the same problem. Just turn down the water pressure @ the valve on the water inlet line. While you have the toilet lid off, you may want to remove the fill valve (1/2 turn counterclockwise on the plastic nut attached to the water-in line), and clean the rubber diaphrams (there are 2). They will sometimes get gritty and this will cause some fill noises and leaking.
Oct 25, 2009 | Kohler 3386-6 Rialto Skylight Round Front...
Water running off and on and comes out from top piece.
you unfortunately need a new fill valve. I say unfortunately because they are expensive, (about $120), for that model and not everywhere sells them. It it was a "regular" toilet, the part would be a any home store and cost about $10. Sorry to be the bearer of bad news. How old is the toilet? You may consider replacing the whole thing.
Aug 10, 2009 | Kohler 3386-6 Rialto Skylight Round Front...
Toilet fill runs periodically works well but wastes water
Sounds like your flapper is leaking causing the water in the tank to lower until it triggers the fill valve. Replace the flapper (they're cheap and wear out easily).
Jul 03, 2009 | Kohler Toilet - One Piece with Ingenium...
Valve adjustment
You need to replace the flapper and you will need to purchase one specifically for the Kohler toilet. I have the same toilet and tried using a generic flapper and from experiance, it didn't work until I bought the correct one and I'm a plumber! Have a great night.
Apr 01, 2009 | Kohler 3386-6 Rialto Skylight Round Front...
Kohler 3386-6 Rialto Skylight Round Front Toilet Logo
1,071 people viewed this question
Top Kohler Home Experts
Donni Steen
john h
Tim Whalen
Are you a Kohler Home Expert? Answer questions, earn points and help others
