Question about Kenmore Dryers
The dryer makes a loud noise and also a rubber smell develops after a 1/2 hour of use
The Dryer makes an loud noise when turn on. The noise is so loud that we have to close the door,
My dryer did the same thing. I had to replace the front support glide assembly and needed 4 teflon glides.
The front part of the dryer runs over this plastic piece seen here upside down.
this part is about $50 CAN there are 4 plastic or teflon glides that fit into this.
My dryer had worn through the teflon glides and start wearing away this piece.
My dryer is a GE front load dryer. And I did get a burning smell because the dryer was wearing away the plastic. After the teflon strips wore down.
Hope this helps
Posted on Jun 02, 2009
  • 744 Answers
the motor is overheating. i recommend inspecting the motor windings for splits or separation within the strands. make sure all wire connectors to the motor are not corroded or lose. replace the motor if there are signs of windings failures or discolored copper strands....
rate me!!
Posted on Jun 01, 2009
My dryer used to squeal loudly and smell like burned rubber. It no longer smells or squeals, but now it takes forever to dry. Can you help me?
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
May 01, 2011 | Hotpoint Dryers
I have an LG DLE5932W. I've been trouble shooting the dryer the past couple of days. It is making a loud vibrating noise that seems to be coming the element side of the dryer. Today I turned it on, went...
A vibration tells me it may be the idler pulley(s). If the pulley seizes, the belt will burn and break. If it smelled like burning rubber, then thats what happened
Feb 02, 2011 | Dryers
Loud grinding noise and burning rubber smell
Could be damage to drive belt which is made of rubber
Dec 21, 2017 | Kenmore Dryers
Bosch WTMC3500UC Gas Dryer Dryer...as it is turning makes LOUD clanging banging noise. Will make the noise when turned by hand does not make the noise when tuned by hand in the other direction.
heatman101
gkjlgkj
Feb 15, 2010 | Bosch WTMC3500UC Gas Dryer
Our dryer has started making a loud thumping sound and smells like rubber burning?
It sounds like you your dryer may have a bad Blower Wheel, which is causing the banging noise that you are hearing (especially if the banging noise continues for a few sections after you turn your dryer off).
Hope this is helpful.
Jan 16, 2010 | Microsoft Windows XP Home Edition
Belt/Drum Noise
The belt can be replaced as follows.
1 remove top and front of dryer shell
2 belt goes around drum around motor pully then under tentioner wheel
3 replace front and top of dryer
(top pops off use a slotted screw driver)
Thanx for using Fixya Please take your time to rate me
Jun 15, 2009 | Asko T761 Electric Dryer
Burning rubber smell and the dryer will not turn on
sounds like you need a new belt for your dryer, the smell of burning rubber is the belt slipping, thats my guess
Feb 09, 2009 | Dryers
My dryer drum stopped turning. The dryer will turn on
it does sound like the belt is broken. you will need to access the inside of the dryer by removing the front. they all come apart differently. Make and Model would help me tell you more.
Dec 26, 2008 | Dryers
Dryer problem
you need a service call on it the smell could be a buid up of lint on the element.
Aug 26, 2008 | Dryers
Dryers Logo
243 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
