Hi, I already have a Sony DAV-DZ840 (1000 W) DVD home theater system. Some how I am not much happy with the sound after hearing Yamaha amps performance. I want to know if I can attach the Yamaha amplifier to my Sony home theater system and will it make a significant difference in the performance?
SOURCE: home cinema
yes kilshpsh ones at best buy 299 whole set they rock or u want whole system x40 samsung very nice sound ok 199
SOURCE: hi, i have a problem
My amplifier turns off after 5 seconds, what should I do to fix this problem
SOURCE: 14 speakers hooked up to home theater reciever,shuts off .5 vol
Try less speakers.
The impedance will be to low for this amp.
Regards,
Gerard
SOURCE: I have a Sony Bravia KDL-46X3100 tv set which I
all you need is one set of the red and white rca cables.your tv should have an audio output with a red and white hole.plug in red and white wires to those holes at the back or side of your tv.plug the other end to your auxilary red and white holes at the back of the stereo....if your stereo doesnt have aux holes then you can plug into L.d.,VIDEO outputs at back of stereo.you then turn your select button,nob on your stereo to either the aux,ld or video.hope this helps
SOURCE: Hi We have an Allen &
'Splitting' leads is never the best way to distribute a signal. The best solution is to use the parallel inputs of the Yamahas to chain them together: mixer to amp1, amp1 to amp2, amp 2 to the Cloud. You should only need to use one input on the Cloud to drive all the channels, using the input switches at the rear.
Let me know if you need any clarification on this.
Register and download the manual for free at
retrevo.com59 views
