Question about Sony Mavica MVC-CD350 Digital Camera
MACRO FOCUS HOW TO TURN THE MACRO OFF - MY CAMERA WILL FOCUS CLOSE IN BUT NOT AT A DISTANCE. I HAVE AN ERROR MESSAGE E61:00
  • donna baby Oct 24, 2007
    re focus problem---
    the flower button removed the flower from the screen but did not allow the camera to focus
    the reset button shut down the camera and after restart the focus problem was the same.
    i can see the telephoto lense move when using the w and t switch, but i cannot see any movement when the camera is first turned on.
    it may be that the lense is locked in the close-up view position because the only in focus view is about eight inches from the camera. still need help
    Scholar:
  • 151 Answers
 It requires a mechanical reset.  Whacking the barrow of the lens twice on a solid surface should be sufficient
All da best
Posted on Oct 24, 2007
  • 709 Answers
Hello Donna baby,
Turn your Mavica on with the dial on top set to Camera, not CameraP.  While looking at your display, press the thumb pad on the 3 O'Clock side, A Flower design is on the thumb pad, and you need to press it to get the Flower to turn off in the display.
Posted on Oct 23, 2007
  • Greg Stokes
    Greg Stokes Oct 23, 2007
    Hi Donna Baby,
    SparkGap is right and posted before I got my post in, basically he and I on the same page and all.  I agree on his post about resetting.
  • Greg Stokes
    Greg Stokes Oct 24, 2007
    Glad you got the Macro out of it.  I found some stuff on possible reason the Focus does not work.  Check out the graphic here to see if you are in Twilight or Landscape modes.
  • 363 Answers
Please download the manual here:-
http://www.retrevo.com/search/v2/jsp/downloadPage.jsp?doc=1c6c4980e80fcb495c014b5150b0bc22&q=Sony+MVC-CD350 To turn off the Macro function, look at page 26.
To attempt to clear the error E61:00, press the reset button on the underside of the camera with a fine tipped object. This is also described in the manual.
If you have trouble downloading the manual or you are not happy with this solution please comment soon and I will try to help more.
Everything in the distance is out of focus
looks like the macro setting is on.
Disable the macro setting this will be usually denoted by a flower.
Feb 26, 2014 | Nikon Coolpix S6100 Digital Camera
The distance focus ring, is it supposed to turn all the way to the macro symbol when you are focusing on a subject that is very close?
If you're right "on top" of the subject - then, yes - it should indicate "macro". Macro focusing is for "very up close" photography and is exactly as you describe. You simply physically move the camera a little closer to or further from the subject to focus.
Not all lenses are capable of macro focusing. The vast majority of these non-macro lenses are required to be at least a couple (or more) feet away to focus. Macro lenses on the other hand can usually get just inches away - which is a great capability.
Enjoy your macro lens!
Oct 12, 2010 | Canon EF 28-80mm f/3.5 -5.6 USM Lens
When zooming in for a close shot it will not focus
When using the tele, the closest you can be to a object is probably more that one meter. If you need to get closer you should switch to macro mode.
Oct 01, 2009 | Canon PowerShot SD850 IS Digital Camera
Hi, i have a photo camera fuji s6500fd and its showing this message ' focus error '. what shall i do? L.
Consult your trouble shooting section in your manual. Alternatively check you are having it at the correct minimum distance when taking the pictures as this can cause a problem. For example there are set distances with the macro and super macro options.
Good luck.
Jan 17, 2009 | Fuji Finepix S5800 Digital Camera
Focusing problems
You may be beyond (up to close) the focal capability of the lens. Even though there is a macro setting, the lens may not have the capability to focus on an object that close (without adding an external macro lens). The specification on the minimal distance for focus should be listed in the owner's manual.
Mar 04, 2008 | Olympus SP-350 Digital Camera
Focus in Macro mode
1. Do not use the zoom while using macro. 2. When clicking the Macro button, click it again, only for 2 more seconds at the second click, it goes to 'Super macro' mode for zero distance. This works in the Canon S3 IS, I hope it will help you in the older S2 IS. 3. Use a tripod. 4. Use the timer for no movement when using a tripod. 5. Try using the manual focus, it does the trick when the camera doesn't focus automatically. Good Luck!
Aug 13, 2006 | Canon PowerShot S2 IS Digital Camera
Minimum focusing distance In the Super Macro mode
In super macro mode, pictures can be taken as close as 2 inches. Subjects measuring up to approximately 1.9 inches by 1.4 inches can be captured on the monitor.
Sep 04, 2005 | Olympus Camedia C-8080 Wide Zoom Digital...
Focusing distance in macro mode
The Macro Mode operating range is 8 inches to 20 inches. This means the camera must be between 8 inches and 20 inches away from the subject for a picture to be in focus.
Sep 01, 2005 | Olympus Stylus 410 / ? 410 Digital Camera
On a D-575 camera, The Macro Mode operating range is 8 inches to 20 inches. This means the camera must be between 8 inches and 20 inches away from the subject for a picture to be in focus.
Sep 01, 2005 | Olympus D-575 Zoom Digital Camera
Aug 31, 2005 | Olympus Camedia D-395 Digital Camera
Sony Mavica MVC-CD350 Digital Camera Logo
85 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
