Question about Dyson DC07 Animal Bagless Upright Cyclonic Vacuum
Beaters stop when vaccuming rug...didn't when new
Vaccum runs fine on all surfaces except lately when we vaccum a large rug it will run for a bit and then the brushes stop. I have to tip the vaccum back to the upright position and mess around with the brush on/off toggle switch on the handle. After a bit of fiddling with that it will work again until i vaccum a little further and then it stops again. It works fine on the carpet in my house and it used to work fine on this same rug.
  • 1,041 Answers
I believe you need to change the belt that drives the brushes. When it gets stretched out, it will just spin on the axle of the motor or spin on the brush and smoke.
Jim
Posted on Jun 04, 2009
  • Jim Parker
    Jim Parker Jun 08, 2009
    Did thi solution solve the problem?
    Jim
Why won't my shark navigator cordless vacuum pick anything up?
Sometimes everything seems to be fine. The brushes turn, but if the brushes aren't cleaned of hair, rug tangles and so on, the brushes on the vaccum get filled and it won't puck up anything. ON THE OTHER HAND if the brushes are clean, did you check all your hoses from thr base of of vaccum where things get sucked up to the bin?
Jan 27, 2016 | Shark Vacuums
It is a dirt devil Royal which I use to vaccum stair steps. it is a new vaccum . not it will not work, the brush will not rotate. I looked to see if some hair was the problem but no hair or fuss. ...
Hi, I am sorry it took this long to get back to you and I promise I will get right on this. We are having issues with our e mail notifications.
You say this is a new vacuum, do you mean brand new? never used before? I am going to look into the dirt devil problems and see if we can narrow down the causes. I assume you tried this in several outlets to make sure it is not the outlet. Does the motor run at all? or is it running but the brush not turning and not picking up dirt.?
Nov 07, 2011 | Vacuums
Vaccum problem
No sound at all? or the motor runs but no vaccuum?
did it stop while using it? might have overheated due to dirty filters... strange that the light comes on but no motor at all... that would suggest to me that the motor is shot...
Here is a link the the manual.. there is no reference to any user accessable fuse or breaker...
Peace,
Mar 07, 2010 | Bissell 6594 PowerForce Bagless Upright...
Unplugged vaccum hose and head of vaccum but still no vaccum what could be the problem
if the motor is running and you have checked airway then you may need a filter
Feb 27, 2010 | Kenmore 34721 Upright Vacuum
Hello, I have a Hoover 3200 Turbo Power vaccum. while the motor appears to be working fine the vaccum no longer picks up the dirt. I turned the vaccum upside down and the belt appears to be broken. would a...
take the vacuum head off the end of the tube , turn the machine and place your hand over the end of the tube
if it sucks your hand onto the tube , the machine is working as a vacuum machine
then check fro a blockage in the elbow section near the head
if there is no vacuum , junk it and get a new one
Jun 30, 2017 | Hoover Vacuums
A noise coming from the motor when I`m ready to vaccum
if it were m i would take it back and insit on a new one.something new shouldn't have to be fixed thatd why we buy it new
Dec 31, 2008 | Hoover U8145-900 Savvy Bagless Upright...
Kenmore vaccum cleaner
Switch number is 4369051 . You can go to sears.com, click on the parts link, put in the part number and you can order it thru them. Or put in you model number, click on dust compartment and a parts list and a picutre diagram will come up. You can order there also.
Mar 20, 2008 | Vacuums
Bissell vaccum problem
Could be plugged, check the hose and at the bottom by the brush roll, the inlet maybe clogged. Also check the filter under neath the dirt tank. There are filters above the dirt container, clean those out. If after that it is still loud, then maybe the motor fan or bearins are bad and will have to be replaced, part #2031214 sells for around $55.
Jan 16, 2008 | Bissell 3594 CleanView PowerTrak Bagless...
Rainbow vaccum
Make sure the bowl has the pin on it. The Vacuum has switch in the bottom that keeps the Vacuum from running if the bowl in not on or the little pin is broken off.
Ralph Wakeman
Ifix@shentel.net
Oct 18, 2007 | Rainbow 75th Anniversary Canister Vacuum
Dyson DC07 Animal Bagless Upright Cyclonic Vacuum Logo
244 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
