No power to dvd player
When i try to turn on my dvd player, the power light comes on for1-2seconds and turns off again. can you help me? Toshiba DVD VideoPlayerSD-310V.
  • 2 more comments
  • jam1 Nov 04, 2007
    My Sanyo DWM-395 turns on for 1 second and then turns off. I can't even get my DVD out! I've only tried unplugging it and plugging it back into a different outlet.
  • jclarke833 Jul 09, 2008
    no power to my dvd player
  • wur6 Sep 27, 2008
  • Anonymous Nov 20, 2008
    I cant get my main screen to come on. It will turn on for a couple of seconds then go off again.
5 Suggested Answers
SOURCE: Toshiba SD 3960 DVD player
Sounds like an inverter problem. If the power supply is internal replace the capacitors coming out of the voltage regulators. These are usually 1000mf and/or 470mf. If that doesn't do the trick look up the numbers on the 8-pin chips that drive the secondary transformers on the inverter to see if they are getting the right voltages.
Good Luck!
Posted on Feb 20, 2008
  • 4 Answers
SOURCE: dvd wont load
my dvd players one audio port not working
Posted on Jul 19, 2008
  • 376 Answers
SOURCE: philips dvdr 3320 v DVD Player Unlock region codes
In DVD mode, press System Menu
Go down to the "Lock " icon
While lock is highlighed press zero "0" for 7 times ( i.e 0,0,0,0,0,0,0)
There will be pop-up window that asks you confirm. Press "OK"
Posted on Aug 12, 2008
SOURCE: DVD unlocking code
thanks ididthe same thing!!!!!!!! really happy!! put the instructions here!!
Press "Setup"
Scroll to "Preference" using the Left/Right arrow key
Press "138931" and a popup screen will appear
Use the Up arrow key and select 0 for a region free DVD player. Press "OK" Done.
Posted on Oct 04, 2008
Unlock Toshiba DVD player SDP93S bought in America to play Australian DVD's
Thanks for understanding. Please let me know if you require any clarifications.
Jul 09, 2011 | Toshiba SDP93S Portable DVD Player
Toshiba 22lv505 TV/DVD Region Code Error
maybe the spindle motor is turning defect causing not to spin the disc naturally,its time to have to check that to the Toshiba service center
Jun 20, 2010 | Toshiba 22LV505 22 in. LCD TV
Power on but nothing works
It may havenot been used for sometime.There could be a few answers to this, so i`m trying likeliest first.
I think or we have to eliminate the build up of condensation in the dvd.
Put the dvd and remote in a warm room plug in, and leave for 2-3 hrs,then fingers crossed try the dvd again.
Dec 03, 2009 | Harman Kardon DVD-22 DVD Player
Hi When I turn ON my Toshiba SD-P1900 player,with
I brought my dvd player to the Toshiba repair center. To be continued...
Nov 26, 2009 | Toshiba SD-P1900 Portable DVD Player
Need the code for one for all universal remote to
The code for a URC-3021 to control a Toshiba DVD player is 0503.
To setup your URC-3021 for the DVD player, these are the steps:
1. Turn on your DVD.
2. On the remote control, press DVD once.
3. Press and hold SET until the LED (red light) blinks twice,
then release SET.
4. Enter the first four-digit code for your device. If performed correctly,
the LED will blink twice. If the LED did not blink twice, repeat steps 2 through 4 and enter the same code again.
5. Aim the remote control at the device and press POWER once. The device should turn off.
Hope that helps.
Oct 25, 2009 | One For All URC-3021 Remote Control
Dvd player shuts off during movie
Look at the power supply capacitors to see id any have a bulged top. Those need to be replaced.
Sep 03, 2017 | Toshiba SD-2705 Multi-disc DVD Player
My Toshiba Laptop won't turn on
hi dear
it's about multi tasking, you pened some program at same times,
just restart your computer . try another player . or install a new codec to your video file
Mar 25, 2008 | Toshiba Satellite A105 Notebook
Toshiba SD-220E
Have you tried unplugging the player completly for 2 minutes? Plug it back in and try again. Also, you could try a new remote code or just replacing the system. P.S. some players have a cap/switch or button that needs to be removed or pushed in order to accept input.
Feb 08, 2007 | Toshiba SD-220E DVD Player
DVD player froze, now only turns off
Sounds like the power supply in the dvd player has failed. It works just well enough to turn on the led infront but as soon as you go to do anything it shuts off. This is common in cheaper dvd players. Unless you can troubleshoot electronics. Or know someone that can. Your best bet is to unplug the unit and disassemly and retrieve your dvd.
Jan 13, 2007 | Philips DVP642 DVD Player
Televison & Video Logo
1,258 people viewed this question
Top Televison & Video Experts
