Question about Whirlpool Calypso GVW9959K Top Load Washer
Is there a filter and how/do I need to clean it?
I bought the house with this machine in it, so have no documentation. I have a number of pets with lots of bedding, therefore, lots of hair to accumulate during washing. I'm concerned about a filter clogging somewhere. Is this a valid concern, and if so what do I need to do to rectify it? Thanks. lint trap needs cleaning and i can't find it
    President:
  • 1,136 Answers
Hi, These do not have filter that can be cleaned or changed. If you notice water draining slow at any time, you will need to open up the pump (not hard to do) and clean out any lint.
I hope this helps you. If I can assist you further, please let me know.
Vic
Posted on Jun 01, 2009
    Problem Solver:
  • 9 Answers
A while ago, Whirlpool changed the pump design. If you have the old style pump, it is very difficult to clean lint and dog hair if the pump is clogged (try a bent wire). I had this happen several times. I replaced the pump impeller mechanism, a non-servicable molded plastic part, a couple times, then replaced the whole pump. The new pump can be disassembled unlike the original one. However, this clogs just as easily, but it is "easier" to clean out. You'll need to tilt the machine back at about 45 degrees (against a wall), sponge out the water from the tub, remove the bottom panel, Disconnect the two hoses, one white and one black, drop the bottom off the pump and clean it. Use a large sheet cake pan to catch the water because there isn't much room under the machine unless you lay it down, then you can have water running out the top. Reassemble and you should be good to go.
Posted on Mar 15, 2010
My machine will spray from the hose attachment, but not when I am doing floors.
Check Flow Indicator Filter under the Flow Indicator. Turn Indicator cap counter-clockwise, remove rotor. Filter is under rotor and pulls out. Clean filter. Additionally, check LINT FILTER in the clean water tank cap. Check you User's Guide if you have more questions or call the Bissell Consumer Care at 1-800-237-7691 The other thing you can do in this case is reseat the tank. It may be blocking the housing connection but the sprayer connection is smaller and open. Cleaning the filters after each use though is recommended.
Dec 06, 2015 | Bissell ProHeat Pet Upright Deep Cleaner,...
Bissell pet hair bagless instruction manual
Do you mean the Bissell Pet Hair Eraser bagless vacuum cleaner? The user manual for this vacuum is available from the product page: http://www.bissell.com/pet-hair-eraser-vacuum/ . Look on the right hand side of the page. The direct link to the English version of the manual is: http://www.bissell.com/assets/0/132/134/228/e5babada-7240-40ea-93c0-90427ed32741.pdf . Note: you will need Adobe Reader or a similar product to access (read/print) the manual.
Bissell has a number of vacuums for cleaning up after pets. Look for your vacuum here: http://www.bissell.com/pet-vacuum/ . The manuals for most are on the product page. For example, there is also the Bissel Pet Hair Eraser OptiClean Cyclonic vacuum. The manual is here: http://www.bissell.com/assets/0/132/134/228/dd4a7280-504f-4483-84a1-bfcc3a239f45.pdf . Older product manuals may be available here: http://www.bissell.com/customer-support/ . Scroll down to the Users Guide search box.
I hope this helps.
Feb 07, 2013 | Bissell Vacuums
Why does my filter collect so much dog hair and decreases the suction of the machine. I clean and change (alternate) filters everytime I vacumn, that isn't normal, is it? It seems like I have a seal or...
You obviously have a pet and it's good to see your machine is doing it's job. The only reason you could lose suction while collecting pet hair is due to the pet hair being a solid mass and air not been able to flow through the filters.( must be a lot of hair). Suction loss is only when the particles passing through your machine are dense therefore it will reduce suction and airflow . Very common on vacuum cleaners. Do not worry too much . Also check to see if you have Amy cracks in the seal between the drum and the vacuum cleaner itself
Jul 15, 2011 | Dyson Vacuums
Hello, I have bought a house with a Hotpoint
(extract from my filter and motor guidance pre-typed notes!)
If you are unsure where the filter is, it is often behind the front lower (kick) panel LHS or RHS (or in some machines at the rear in an awkward position!) and held in by a round cover/knob.
Manual-
You will need to type into your search engine/web browser '(make) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount. During the process you will be asked for the actual model number!
Good luck with both!
John C
Mar 03, 2011 | Hotpoint WF430 Front Load Washer
I get a message stating that the tv is overheating and eventually turns itself off. What needs to be replaced?
The problem could be that the filter on the back of the TV needs to be cleaned. Remove the pop out door and clean the foam filter. Do not get it wet, just use the vaccum or blow the dirt out. There is a fan behind the filter, so any dust and pet dander is filtered before the air is sucked into your unit. I make it a habit to clean mine every 6 months. I'd do it more often if your house is in a dry dusty location.
Sep 10, 2010 | Zenith E44W46LCD 44" Rear Projection...
I want to take apart and clean my D4C Rainbow and my E series 1 speed, I bought both of them on Ebay, and both have odors,( They are suppose to be the vacuum that cleans and purifies the air) that leaves...
Sorry, but a Rainbow D4 has no filtration at all. The E series has a HEPA filter that needs replacing. You can put liquid Lysol in the water on the D4 and that will help
Apr 30, 2010 | Rainbow E series Canister Wet/Dry Vacuum
I bought two of these washers and they both have this problem. The worry is not only the horrible smell but the fact that these washers are not killing germs but rather creating bateria and mold.
have teck come and clean out filter, mold, etc behind seal, then clean about 1 time a month by running wash cycle with hot water, no clothes and 1 cup bleach, always leave door open til washer drys, careful if small children or pets are in the house they may climb in
Nov 19, 2009 | Frigidaire GLTF2940ES Front Load Washer
Our Infocus sp5000 is shutting down because it is getting too hot. We had just cleaned the filter.
you also need to clean out the machine with canned air. also check to see that all of the fans are running. if they are not all running, they need to be replaced. also, the temp sensor near the lamp housing may also need replacing.
Oct 24, 2009 | InFocus SP5000 Home Theater Projector,...
Bissell Lift OfF Brush Roller Stops Rotating
They make the worst machines, the rollers are cheap and they make it so you cant take them apart to clean them. You don't want a dyson either, they aren't any better for pets. With all that hardwood floors you should get a good canister vacuum, sebo and miele are the best.
Aug 24, 2009 | Bissell Lift-Off(R) Revolution(R) Turbo...
most washing machines have a lint trap that is easy to find. I don't know this model, but open the lid and find where the recirculating water falls out from a hose or plastic tray above the wash tub. somewhere below this point, in the path of the falling water, is a lint trap. remove it and clean it
May 25, 2007 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Calypso GVW9959K Top Load Washer Logo
481 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
