I have had a lady tell me that they jump started a car using her 2006 hilux and it has blown the main 50amp fuse. she has asked me to order her in a whole new fuse box however I believe she only will need the fuse replaced is this correct? all she has described to me is a part in the box that has a lot of copper strips she wants replaced... please shed some light on what she is after?
I think she needs some re-wiring done. Sounds like not just the fuse, but "a lot of copper strips" sounds like several terminals in the fuse box were also destroyed, the ones that accept the fuses spade ends.. I may be wrong, but a new fuse box would just have empty slots for the wiring connectors, wouldn't it? In that case, she needs an experienced electrical wiring person. Blowing a 50 amp fuse sounds pretty awesome-lol.
SOURCE: need fuse diagram for 1996 nissan 200sx
you could try searching the google website or ringing your local nissan dealer also what sub model (K's, Q's)?
SOURCE: 2001 pt cruiser limited won't crank
needs a battery but be careful cause sometimes a bad alternater will cause the battery to go bad
SOURCE: reversed polarity while jumping lexus sc430..HELP!
its very possable the ecu is damaged, but you will need to check all the fuses and or fuseable links
