Question about Texas Instruments TI-84 Plus Calculator
I used a "hook" program and connected the calculator to a motion detector. The graphing function was working fine before I used that program.
I know how to use the graphing function on my TI 84 plus. However, each time I attempt to graph a function I get this message: ERR:INVALID DIM 1: Quit How can I fix this?
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 88 Answers
Press the 2nd button, then the plus button, the 7, then 1, then 2. This will reset your calculator.
Posted on Aug 06, 2009
Graphing doesnt show
Depending on the function you are drawing, it is possible that the graph is out of range of the windows dimensions. Try Zooming out to see a bigger portion of the plane. If you know where the function intercepts one of the axes, you might want to center the graph around that point.
Jan 16, 2012 | Texas Instruments TI-84 Plus Calculator
My calculator wont graph more than one function at a time, how can i fix that?
Hi Lexy,
Chances are, your calculator has a program called "Transfrm" on it that is preventing the calculator from graphing more than one function at a time. Luckily this is easily remedied.
1) Turn calculator on and press the "APPS" key.
2) Scroll down (towards the bottom of the list) and find the "Transfrm" program.
3) With the program highlighted, press the "Enter" key.
4) Highlight the "Uninstall" option and press "Enter".
Once the program is uninstalled, the graphing function of the calculator should be working correctly, allowing you to graph more than one function at a time.
Hope this helps :-)
Dec 01, 2010 | Texas Instruments TI-84 Plus Calculator
How to use graphing calculator?
The casio FX-300Ms calculator cannot do graphs. To tell you how to use a graphing calculator TO DRAW GRAPHS we need to know the exact brand and model number of the calculator.
  1. Most graphing calculators basically function the same way.
  2. You select the graph type (function, polar,parametric, sequence, 3D, wire mesh, slope field, etc.)
  3. You enter the algebraic form of the function you want to draw.
  4. You press a button or menu to GRAPH
  5. The graph is drawn.
  6. If you want to see a particular part of the graph, you use a ZOOM function, or you enter values for the WINDOW dimensions.
  7. Most graphing calculators have a TRACE function that allow you to follow the curve you have drawn to read off values of coordinate points.
  8. You can also use the calculator to find zeros roots) of functions, calculate derivatives at some chosen points or calculate the area "under the curve", find the minimum and maximum of a function.
In addition to its graphing capabilities, a graphing calculator can be used as a scientific calculator. Sometimes it can also do statistical and financial calculations, matrices, list manipulations, operations on complex numbers, text editing,, creating programs etc.
Aug 13, 2010 | Casio FX-300MS Calculator
Won't Graph Exponential Function
Ok, try these two things and you should be just fine.
1.) Check your range for your graph. It is possible that the range you are using isnt large enough to show the curve. Also try using Z-fit vs Z-st. These are options that your calculator will give you once the equation is graphed.
2.) Place a parenthesis around the 2x, make sure that you and the calculator are both using the same order of operations. This move mill ensure that the calculator will multiply the variable, x, by two and then do the exponential.
This should do it!
Happy Graphing!
Jul 25, 2010 | Texas Instruments TI-84 Plus Calculator
How do you plot two liner equations on a ti-84?
I use one of the graphing APPS or do through a program. I have a users manual for TI 84 silver Edition that shows you how to archive\ unarchive to run programs here at this site. Usually, I tell people to just forget about the programs and use the simple concepts so, that they could operate their calculator better. But, if you notice in those program are actually more powerful than the programs you get on the web, because I wrote them to be flawless, or I only used programs that I knew would not clash and were very well written. Won't y1=(2/5)x-(11/5) and -3x+8 work?
Sep 29, 2009 | Texas Instruments TI-89 Calculator
I'm trying to graph a line. For the
Reset the memory to defaults and you will not get the error.
[2nd][MEM][7:Reset][Defaults] [2:Reset] [ENTER]. Press [CLEAR] and them [Y=] to enter the function. No need to set Zoom. Defaults work fine for y1= 4X+3.
Press [GRAPH].
Hope it helps
Sep 26, 2009 | Texas Instruments TI-83 Plus Calculator
Deleting the 3D function
I heard of instructor disabiling APPS but, not functions. One reason I can't see that is I can download a program that does the same thing and hide it w/ instructor even knowing its there unless he ran a search in ever folder or open a lot of programs
Mar 24, 2009 | Texas Instruments TI-89 Calculator
Graph won't go away
There is an instruction to clear graph
When in Graph mode Press [F6:Draw] and [1:ClrDraw].
Hope it helps.
Feb 09, 2009 | Texas Instruments TI-89 Calculator
Graphing trig functions
Put the calculator in radian mode and it will graph trig functions just fine. If you don't know how to change it to radians, then go to mode and cursor over to select radians. I am assuming you know where the sine, cosine, tangent, etc. keys are.
Dec 31, 2007 | Texas Instruments TI-84 Plus Silver...
Texas Instruments TI-84 Plus Calculator Logo
299 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
