Question about Motorola Mobility H500 Wireless Headset
Pearing h500 What buttons to you press to place the unit into pearing mode
    President:
  • 2,961 Answers
The main blue button is to be pressed and held in for 3 seconds, it will then light up a steady blue, this is pairing mode, find the device in your phone settings enter 0000 for the passkey and then the light will flicker and then flas intermittently to tell you it has paired.
Posted on Oct 23, 2007
How do I pair my Motorola H500 headset to my Iphone 4s, it keeps searching> Is is compatible
Turn your h500 off. Then long press the multifunction button untilnit lights up steady blue. Then search on your phone to locate and pair with the headset.
Mark
Motorola Support
Jun 17, 2015 | Motorola Mobility H500 Wireless Headset
Motorolla h500 no steady blue light
Starting with your headset turned off, press and hold the call button for some 6 to 10 seconds, until the indicator light is steadily lit (it will flash some times as if it was being turned on, but don't release the button at that phase). With the light steadily lit It is in pairing mode. Now make your phone's bluetooth application search for new devices. After a while, the H500 should appear on-screen. Select it and make it connect. If a pairing code (or PIN, or passkey) is requested, enter '0000' (four zeros). If the pairing process is successful, the indicator light will flash rapidly, and then, it will enter the stand-by mode. Otherwise, turn your headset off, and go through the whole process again.
By the way, if your headset's user guide happens to be missing, feel free to download it from this location.
Hope you are able to sort your problems out.
Regards, Carlos
May 11, 2012 | Motorola Mobility H500 Wireless Headset
Can not connect H500 bluetooth with Nokia 2680 slide cell phone. Need Motarola instructions.
Here are the steps to connect your Motorola H500 to your Nokia 2680 phone:
1. Switch off your H500 by pressing the main button for few seconds. 2. Put the H500 in discovery mode. To do this, press and HOLD the main button till it glows a solid blue light (no blinking). 3. Open bluetooth in nokia phone. Go to Menu, settings, Connectivity, Bluetooth. 4. Select "Add a new Device" and search for H500 5. Click on the name select pair. 6. it will ask for pairing code. Enter "0000"
You are done. Revert in case you have any problem
Jun 09, 2011 | Cell Phones
I got the H500 given to me but not manual to show me how to make it work w/my cell phone
Starting with your headset turned off, press and hold the call button for more than 6 seconds, until the indicator light is steadily lit (you'll notice that the light will flash as if the headset was being turned on, but don't release the button at this step). You headset is now in pairing mode. Now, make your phone's bluetooth application search for new devices. After a while, the H500 will appear on the phone screen. If a pairing code (or PIN, or passkey) is requested, enter '0000' (four zeros). You just have to pair any two blueotooth enabled devices once. All subsequent connections between them should be achieved by bringing them both within range, with their bluetooth radios turned on. If they fail to do so, a simple press on the headset's call button should suffice to established the link.
Hope it works for you.
Regards, Carlos
Jun 14, 2010 | Motorola Mobility H500 Wireless Headset
Motorola h500 sch-r350 forgot code
Starting with your headset turned off, press and hold the call button for more than 6 seconds, until the indicator light is steadily lit (you'll notice that the light will flash as if the headset was being turned on, but don't release the button at this step). You headset is now in pairing mode. Now, on your phone, go to 'Menu > Tools > Bluetooth > Registered List > Add New Device'. If the phone's bluetooth radio is off, you'll be prompted to turn it on. Do it. After a while, the H500 will appear on the phone screen. If a pairing code (or PIN, or passkey) is requested, enter '0000' (four zeros).
Cheers! Carlos
May 21, 2010 | Motorola Mobility H500 Headset
How to set over ear motorola H500
Cheers! Carlos
May 19, 2010 | Motorola Mobility H500 Headset
H500 wont go into pairing mode
are you holding the call button until the light stays lit/ That is about 6-10 sec and press find devices after it stays lit from your handset
Aug 15, 2009 | Motorola Mobility H500 Wireless Headset
How do you set the H500 Bluetooth device in discoverable mode?
press the talk button for 11 seconds see how the light start blinking
Jul 20, 2009 | Motorola Mobility H500 Wireless Headset
How do you connect a Motorola H500 Headset to a motorola razor v3m
On your bluetooth headset, hold down the power button until the light stays on steady. (it will blink when you initially power it on, but continue to hold for another few seconds for the steady light!) Your headset is now in pairing mode.
On your RAZR, press Menu > Settings and Tools > Connections > Bluetooth > Handsfree > Look for devices. Your phone will then scan for any bluetooth devices that are in pairing mode. When your headset pops up on the list, highlight it and press ok to connect.
If the device asks permission to bond with the phone, select yes. It will then prompt you for a pin code. The pin will be 0000 .
Enjoy!
Jan 14, 2008 | Motorola Mobility H500 Headset
Motorola Mobility H500 Wireless Headset Logo
79 people viewed this question
Top Motorola Mobility Radio Communications Experts
Lawrence Oravetz
Dennis
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
