Water won't shutoff after depressing push-in button and poor water flow out bubbler nozzle.
SOURCE: oasis drinkingfountain - Why would fan run continually? Cools wel
The fan and compressor run at the same time.
Both get power from the on/off cold control termostat.
1.Defective thermostat.
2.Compressor not cooling.
If the water is chilling go to #1.
SOURCE: My Frigidaire refrigerator is model
Look up how the valves work. They are "servoed", that is a SMALL pintle is pulled by the solenoid from a small hole in a diaphram which then actuates the main valve seat. A tiny bit of crud in the pintle hole will block operation. These valves are used in many appliances such as dishwashers.
You MAY be able to clean the valve by removing the unit and disassembling where the diaphram is. Theree will be a spring behind the pintle so don't lose it when you open it.
Check stream height from bubbler. Stream height is factory set at 35 PSI . If supply pressure varies greatly from this, remove the (bottom cover plate) and adjust the screw on the regulator Clockwise adjustment will raise stream height and counter-clockwise will lower stream height. For best adjustment stream height should hit basin approximately 6-1/2" (165mm) from the bubbler.
