EPSON BX300F won't install print driver. It gets through the download and un zip and then fereezes saying 'installing print driver'. I've spoken to Epson who say they can install files in their Vista machine, so this must be a problem with my computer - Acer Aspire X3200 running an AMD Phenom 8450 triple core chipset. I've heard rumours that the problem is with the Phenom drivers - is this true? If so where do I get new driver for Phenom? I have the same problem but on XP did you manage to find a solution?
SOURCE: cant install epson c46 printer on vista
I have just got my epson stylus C46 working by just plugging in the USB from the printer and turning the printer on. I didn't download any drivers, vista searches and downloads a compatible driver for you when you plug it in. You may need to make it your default printer by going to control panel, printers, then right click on your epson and make it the default. Hope this works for you as it did for me!
SOURCE: Problem with Epson CX5000 Scanner Driver
Download in google for free registry repair for VISTA and repair ur registry and try to install again...
Still not working,Try to install driver's on another location
And rate me as FIXYA please
SOURCE: I lost CD for Epson CX6000, cannot install drivers for Vista
Vista 32 bits
ftp://ftp.epson.com/drivers/epson13097.exe
Vista 64 bits
ftp://ftp.epson.com/drivers/epson13098.exe
SOURCE: I have an Epson Stylus Photo R1800 printer tha I
Save the driver to a specific directory. Unplug USB from the printer, wait a minute and plug USB back in. When the wizard detects the new hardware, manually select the dirver from the specific directory. Do not let the wizard search for the driver. You select the driver manually. Good Luck
SOURCE: Epson d88+ driver doesn't work with vista and updates don't eithe
try compleately uninstalling the printer, then download and install the driver found here. http://www.google.com/aclk?sa=l&ai=CcXjLt3qESuzfAo6ysQP-oe2UCo3K4njxr7H5CtyOnQ8QASCCsvUDKAZQyKjGhgRgyY7_jOSk8BOgAaOS3foDyAEBqQJIMZVZytquPqoEG0_Q5-_Y2ajPvPB7B_mjtRdS0jp2wJkM5Zl6Wg&num=1&sig=AGiWqtwDpAtlRENDLPyEN1w5gSpEZLd07A&q=http://www.driverwizard.org/wizard/p/Epson/Stylus/printer%3Fgs.epsonbrandnameonly.wizard
http://www.epson.com/cgi-bin/Store/support/SupportIndex.jsp.
Now UN-install the drivers and then reinstall then connect printer and check for test print.
