Question about Whirlpool GU1200XTLS Stainless Steel Dishwasher
Scour lite stays on. Dishwasher does not work. Tried off and did not work.
Whirlpool Gold Dishwasher Mod GU1200XLTS2. Stoped working and HIGH TEP SCOUR light stays lite. I turned off Circuit Breaker for a few minutes and even overnite with little or no success. Sometimes powerof cycle seems to help by allowing another button to be pressed but then returns to SCOUR lite on. It there a way to reset (computer) circut board or is it dead?
markevans
  • 148 Answers
SOURCE: problems with Whirlpool dishwasher model GU1500XTKB0
will these units (silo and jtrip) start back on their own? if so, it is likely they are heating the water.
otherwise it sounds like a logic board, unless there is a defective door switch or sensor issue.
electronics seem to be a recurring problem with whirlpool.
i would ask whirlpool (electorlux) to either buy it back or fix it.
good luck
mark
Posted on Dec 28, 2007
  • 1073 Answers
have they checked the thernals on the bottom of the tub
Posted on Apr 12, 2008
aborcass
  • 2651 Answers
SOURCE: Whirlpool Dishwasher Model GU2500XTPS1
there s atechsheet / troubleshooter behind you lower kickplate assy-- this was taken from there
PROBLEM: WON’T RUN AND LED ABOVE KEY(S) IS FLASHING
RAPIDLY
Stuck key(s) or shorted
circuit(s) in keypad.
See Checking Keypad Operation, page 1. Shorted circuits or
connections on the control
that read the keys .check/replace keypad
1. Unplug dishwasher or disconnect power.
2. Check/replace control
Posted on Nov 03, 2008
aborcass
  • 2651 Answers
SOURCE: my soak/scour light is blinking and cant get my
generally any time a button continuously flashes, you either have a bad door switch that doesnt recognize door closing, therefore will not start, or the electronic keyboard/touch pad is shorted out, in which case youll need to replace the console assy
Posted on Apr 29, 2009
  • 6 Answers
SOURCE: sani rinse, power scour and air dry does not work
wat does it do?
Posted on Feb 10, 2010
Flashing clean light
check behind kick plate for service manual. To clear 7 blinking lights go into diagnostic by doing a finger dance, touch hi temp scour then air dry till it goes into diagnostic this will check all systems .Once finished you will most likely need to change the chopper and junk in or around the sump Cheers
Dec 08, 2013 | Whirlpool Gold 24 in. Built-In Dishwasher...
Control clean light keeps blinking and dishwasher will not function
Your dishwasher will do this as a safety in case the element is broken and feeding electrical current into the water. Sometimes just a false reading.
Reset your console by pressing: high temp wash, heated dry, high temp wash, heated dry
When all the lights are on you are set in diagnostic mode. Just hit cancel a you will be able to run your dishwasher as normal.
If this same light appears again then you have a bad element or thermostat.
Dec 06, 2010 | Whirlpool Gold 24 in. Built-In Dishwasher...
AS PER DIRECTIONS FROM TECH, I PURCHASED AND INSTALLED A NEW CONTROL UNIT. THIS WAS BECAUSE MY WHIRLPOOL DISHWASHER GOLD GU2300XTLB3 QUIT WORKING IN ALL CYCLES EXCEPT SHORT CYCLE. PUT EVERYTHING BACK...
This is a common problem with Whirlpool washers.If the clean light is the one flashing then your dishwasher could have a heater circuit problem (depending on the age) or this could simply just be water colder than it is used to getting.
Repeatedly press the Heated Dry and Hi-Temp Wash(scrub) which ever yours has until all the LED lights come on, press cancel twice and try the dishwasher again making sure to run the water at the kitchen sink till it is hot before starting the dishwasher, if this trips and locks you have a problem with the heating element, or temp sensor.
Press the heated dry button followed by the normal cycle button, and then repeat once. You should see all of the lights come on for a second or two, and then the dishwasher will work again.
If you haven't already, take a look under the kick plate in front to see if there is a schematic tucked in there somewhere. Whirlpool has put their diagnostics for specific models on these.
I don't have the specific repair manual for you model.
So, if the above combination does not work here are two more that have worked for me.
HiTemp Wash + Air Dry + HiTemp Wash + Air Dry in less than 5 sec
or
Hi Temp Scrub/Scour + Air Dry + Hi Temp Scrub/Scour + Air Dry in less than 5 sec
Let me know, if you need further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Nov 01, 2010 | Dishwashers
My Whirlpool Gold Dishwasher isn't cleaning
You need a new water valve. Call us for parts and supplies for your Whirlpool dishwasher. We will be sure to get the correct part out to you right away! We look forward to hearing back from you soon.
Sep 09, 2009 | Whirlpool Gold Black-on-Black 25.4 cu. ft....
I have a Whirlpool Gold, had 4years,had to replace
Thermal fuse mounted to the control board see if you have power on each side of it checking from post to ground,if you got power going in but none going out it's blown,and has a more serious issue somewhere.
Aug 12, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
Problems with Whirlpool dishwasher model GU1500XTKB0
Mar 14, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Error soak and scour light comes on wont wash
press and hols start button until it resets then try again.
Feb 20, 2008 | Whirlpool 24 in. GU1500XT - Multiple Color...
good luck
mark
Jan 09, 2007 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool GU1200XTLS Stainless Steel Dishwasher Logo
46 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
